12-06-2021, 12:33 PM | #23 |
847
Rep 1,962
Could you describe how in a bit more detail? Mine refuses to let me measure the oil level until I've done the specified longer drive.
12-06-2021, 06:42 PM | #24 |
Rep 212
After a drive or at least when the engine is well warmed up, drive the car to the place where you want to perform the measurement and switch off the engine. Then wait at least one hour before taking the oil reading.
You will then see that the oil level check tab is greyed out, so it is indeed not possible to immediately start the oil level check. So the trick is to be patient and keep waiting (with the engine running of course) until the tab with start the oil measurement lights up, and that waiting time will be several minutes. It simply comes down to the fact that there is a certain waiting period after the engine temperature has cooled down and the more it cools down the longer the waiting period. Waiting an hour to an hour and a half before taking the oil reading is more than sufficient. PS: In the winter, I would not wait longer than an hour before taking the oil reading due to the stronger cooling down. With a completely cold engine, you will not get a reading anyway.
F87 M2 LCI
EX: e92 335d: 350hp@4400rpm and 698NM/521 ft lb@2760 rpm. Last edited by JMM; 12-08-2021 at 10:21 AM.. |
12-06-2021, 07:03 PM | #25 | |
New BMW owner
328
Rep 846
So in short wait for 2 hrs after a drive before running the measuring process to get an accurate reading. Hmmm. I think I would have forgotten by then.
12-06-2021, 07:08 PM | #26 |
Rep 212
Less than 2 hrs is already sufficient and if you keep forgetting then you will never know..
F87 M2 LCI
EX: e92 335d: 350hp@4400rpm and 698NM/521 ft lb@2760 rpm. Last edited by JMM; 02-10-2022 at 10:01 AM.. |
12-08-2021, 10:31 AM | #27 |
Rep 212
Have you succeeded in doing the measurement now?
F87 M2 LCI
EX: e92 335d: 350hp@4400rpm and 698NM/521 ft lb@2760 rpm. |
PackPride851119.50 |
12-08-2021, 06:43 PM | #28 | |
Rep 147
12-10-2021, 11:06 PM | #29 | |
Rep 7,537
6.9 is the rounded up quart value which is a slight overfill. In terms of the oil level sensor use a live readout via ista if you don't want to wait until the car warms up, it won't be entirely accurate but if you get a measurement when the car is cold before and oil change and while it's hot you will get a better idea on measurement metric. In summary you during an oil change 6.5L is the volume you should be replacing. If you measure the drained oil volume you may have less than this if your car burns oil. So generally it's best to refill to 6.5L. if you let your car sit a really long time and drain it cold you might have more than 6.5L as all the oil from the head etc drips down. So at that point you should fill the drained volume which would be a bit more than 6.5L - but this is why you should change oil when it's hot. But in general 6.5L is the safe BMW specified number for an oil and filter change, where no measurement is required.
///M TOWN22129.00 |
12-10-2021, 11:22 PM | #30 | ||
22129
Rep 8,717
And the reading was spot on Thanks for the correction
F87source7362.50 |
12-17-2021, 05:13 PM | #31 |
Rep 212
Yep, I have done it several times and now today i did the test again... When I follow the procedure that BMW prescribes, the oil level is at max, when I follow my procedure, the oil level is about 50% between min and max...
F87 M2 LCI
EX: e92 335d: 350hp@4400rpm and 698NM/521 ft lb@2760 rpm. Last edited by JMM; 12-31-2021 at 08:15 AM.. |
