02-11-2022, 01:27 PM | #23 |
Rep 63
Which brand is recommend for Turbo inlet? I allready have charge and boostpipe from FTP Motorsport, rest is stock.
How is the change of the engine character with the inlet? More horsepower even with stock software? More spooling sound of the turbo? |
02-11-2022, 03:34 PM | #24 |
378
Rep 348
I would not bother with a turbo inlet unless doing DV, and I wouldn’t mess with DV unless upgrading the turbo.
I just haven’t seen any evidence that the juice is worth the squeeze. Once you’re tearing into the hot side, sure, but otherwise to hell with that job. |
02-11-2022, 03:51 PM | #25 | ||
Rep 7,543
Not really true, a DV will give you better throttle response and lowers WGDC, same with the inlet. These two together noticeably give better throttle response so I personally think they were worth while mods. So when you flush the coolant so do them at the same time, the job isn't that bad.
02-11-2022, 06:32 PM | #27 |
Rep 7,543
I stand corected
02-11-2022, 07:14 PM | #29 |
Rep 7,543
Yeah I remember seeing the dyno plot when pure first launched their inlets. I just slipped up answering the question and thought power gain as in from the diverter valve not considering the inlet.
02-12-2022, 09:46 AM | #30 | |
378
Rep 348
Do you think I’d see any power gains on a BM3 S291 setup? My assumption is no but as we all can tell, I’m wrong occasionally. Last edited by Wolfman’s Brother; 02-12-2022 at 09:53 AM.. |
02-12-2022, 03:44 PM | #31 | |
Rep 7,543
You'd likely gain more power with a tune vs. just being stock
02-12-2022, 04:53 PM | #32 |
Rep 203
How many hours labour would you guess a decent shop would charge?
02-12-2022, 05:30 PM | #33 |
Rep 7,543
I have no idea unfortunately. If I were to do it again I could do the entire job in less than a day. That includes a coolant flush.
Sundinisagod115.50 |
02-13-2022, 04:31 PM | #34 |
Rep 63
Oh Ok ich hope i understand ehat you all mean.
So, the engine will have a bit faster response to throttle changes?! No power gains, no sound, Ok. But what about the lower WGDC? Does this mean that the Wastegate is more closed in low rpm than whit stock inlet, so boost will increase faster? |
02-13-2022, 05:46 PM | #35 | |
22373
Rep 8,740
It brought my car to life even on a stock tune without running an intercooler Now that I have added the cooler to the equation it feels like a different car Revs nicely now all the way to redline
02-13-2022, 06:23 PM | #36 | |
Rep 4,218
///M TOWN22373.00 |
02-14-2022, 02:00 AM | #37 | ||
22373
Rep 8,740
Like sucking through a much larger straw
02-15-2022, 01:07 PM | #39 |
Rep 4,218
I think it costs me 200ish for the DV and inlet install at the same time, the mechanic stated it wasn't that bad.
Mods: Yes.
02-16-2022, 03:20 AM | #40 | |
Rep 660
02-16-2022, 03:40 AM | #41 | |
Rep 7,543
This occured a tiny bit with my pure section 1 inlet which is just the piece you have to use inconjunction with the stock inlet, but I have addressed the issue now. This is how I discovered this issue, and thankfully I caught it early or else it would have probably gotten worse. But quickly, to fix it I rotated the inlet a bit and now the accordian flex joint on the stock inlet has enough expansion room to move in and out as the engine rocks back and forth so there won't be strain on the inlet. I have also put alot of quality high temp ptfe lube on the inlet mouth to stop any galling and metal on metal rubbing that can occur between the inlet and turbo. I used super lube if you are interested, this is the best lube out there (super high operating temp range too), nothing compares and I could literally talk alot about this stuff. So this seemed to solve my issues. So yeah without this flex that a silicone inlet has, or the really flexibile accordian section the stock inlet has the metal inlet ring will eat up the turbo over time. So I don't recommend fully metal inlets, pure also powder coats the part that goes into the turbo which is stupid because as the turbo inlet is stressed that powder coating will flake off and will now be stuck around that turbo area. So the next time you take out the inlet and it is free it can get sucked into the turbo if you don't clean it carefully. FTP is a slight exception because they include a silicone ring for the turbo inlet part that prevents metal on metal contact, but it isn't perfect because there's no flex anywhere so it still puts alot of strain when the engine move.
02-16-2022, 04:00 AM | #42 | |
Rep 660
02-16-2022, 05:07 AM | #43 | |
Rep 7,543
I'm still running the pure inlet, the shorty version. I've just addressed the short comings and adjusted it so it doesn't cause me any more issues. But the key is to have the ptfe lube because that will stop the galling, I would reckon any metal turbo portion inlet would cause metal shavings to be produced over time just due to metal on metal contact (full metal ones will obviously be worse). The only way to fully stop it is with lube. I don't recommend the pure shorty inlet anymore, get something better like the most inlet.
02-16-2022, 12:34 PM | #44 | |
Rep 660
