01-07-2023, 08:41 PM | #23 |
Rep 3,043
You really do need to get to 2009 to avoid serious issues with porsche since the 996. Even then, still need a bore scope just in case.
Parts and labour are absolutely hideously expensive, even at an indy. I had two O2 sensors, oil change, MAF sensor done, was over $2K. |
01-08-2023, 12:21 PM | #24 | |
Rep 5,393
What does impress me about the 9A1 motor in my Cayman is that it's a forged crank, forged pistons, and closed deck block. That's nuts for a street motor and way over-built for a 2.9 liter.
Dino GT35139.00 |
01-08-2023, 12:32 PM | #25 | |
Rep 2,345
Drives: 9Y0 Cayenne S
01-08-2023, 01:46 PM | #26 |
Rep 5,393
I'd say this goes for ANY vehicle. Even though bore scoring isn't an issue in most engines, idling to warm up is just terrible for catalytic converters and the oil because the engine stays in a prolonged rich running condition which can foul the cats over time and put excess fuel into the oil. Some owners also incorrectly assume that because the engine is warmed via prolonged idling that they can speed off. That couldn't be farther from the truth as the transmission fluids are still stone cold. Driving is what heats up the trans and diff fluids, dummy!
01-08-2023, 01:50 PM | #27 |
General
61831
Rep 19,969
Porsche's propensity for keeping everything as light as possible is in itself a reason why wear and tear should be expected more frequently on these than others with a solid build.
Great when they're running perfect but sadly the worst marque for reliability over the pond here. |
01-08-2023, 02:18 PM | #28 | |
Rep 7,340
01-08-2023, 03:00 PM | #29 | |
General
61831
Rep 19,969
https://www.thecarexpert.co.uk/porsc...ble-car-brand/ |
01-08-2023, 03:45 PM | #30 |
Rep 5,393
Here's JD Power's Long Term Dependability study data for 2022 which shows Porsche and BMW are well above the industry average in terms of reliability.
https://www.jdpower.com/business/press-releases/2022-us-vehicle-dependability-study With that said, when we're talking about 10 year old cars, degraded plastics, rubber, hoses, bushings, suspension components, etc. will require replacement. Nothing lasts forever. |
01-08-2023, 06:04 PM | #31 | |
Rep 7,340
The bore scoring is just a design defect. Same thing with S65 rod bearings. People love to blame the user. Let's be honest, Porsche has a really bad history with cylinder linings / skirt coatings. People remote start and idle BMWs all the time and there's no bore scoring. Last edited by chris719; 01-08-2023 at 06:15 PM.. |
01-08-2023, 08:00 PM | #32 | |
Rep 3,043
That's why I had mine scoped. |
01-08-2023, 09:19 PM | #33 | |
Rep 7,340
01-08-2023, 09:47 PM | #35 | |
Rep 2,345
Agree scoring is a defect, caused by cost-reducing the cylinder coating. Aluminum cylinders with hard coating is a great lab research project with PhDs building the engines but not so great in mass production. MB has it also, read about the M278 and M157 V8s. |
01-09-2023, 01:26 PM | #36 | |
Rep 5,393
I do read reports of scoring being more common in cars driven in colder climates and obviously in cars driven hard when not warmed up. However, if you go down the bore scoring rabbit hole, there are plenty of cases of well-maintained motors in warm climates suffering from it. Late model BMW motors like the B58 and related motors have a plasma coatings instead of iron liners. There are instances of these coatings failing in the B58s, the culprit being leaking DFI injectors. I do have to wonder if the DFI 9A1 motors are getting bore scoring from a similar leaky fuel injector issue. Shame on Porsche for not pushing the easy button and sticking to iron cylinder liners. The fractional gain in mpg of using these cylinder liner coatings seems largely offset by a potential catastrophic failure of the short block at great expense to the owner.
chris7197393.50 |
01-09-2023, 01:29 PM | #37 |
Rep 5,393
These repair costs are just bonkers. There's nothing inherently special about the way these H6 Porsche motors come apart and go back together. If anything, a Subaru boxer motor is more difficult fully disassemble/assemble. Same for the parts costs. Yeah, they're high-revving 6 cylinder motors that can make good power, but Honda and Nissan have managed to make high revving 6 cylinders for the masses too and with similar power per cubic inch.
01-09-2023, 02:30 PM | #38 |
Rep 7,340
Porsche is just ahead of the curve. They seem to try stuff out before they become mainstream. I don't think it's for fuel economy only; it's for cost / ease of mfg and the arc sprayed coatings are actually superior.
05-11-2023, 08:13 PM | #39 |
Rep 5,393
5/11/2023 Update
Over the past couple of months I've done a number of repairs, preventative maintenance, and mods as noted below. I'm very happy with how the car is progressing. - New brake light switch - New clutch pedal switches - Replaced the 13 y/o air/oil separator (AOS). I disassembled the AOS and the rubber diaphragm still looked good. The car has never smoked on start up or otherwise - Replaced the vent line from the AOS to the throttle body assembly. The vent line had some oil residue on it which after further inspection was caused by a nearly impossible to see crack in the corrugated plastic. - Installed new coil packs. The original coil packs did not show any signs of cracking. - Installed satin Soul Performance exhaust tips and x-pipe - Installed Cayman R "Porsche" side decals - Rattle can painted the black plastic front spoilers Carrara white and clear coated with 2K clear. - Plasti-Dip the headlight washer nozzles black (originally chrome) - Cayman R-style headlight surrounds - Smoked translucent vinyl on the fog lights and running lamps - 8mm ECS spacers in the front and 12mm spacers in the rear - Black painted OEM muffler cans (they bronzed and had some surface rust) - 40% window tint Next up is the Function First shift kit and a new gas cap as the car has thrown the P0441 code twice now over the past 6 months and the gas cap rubber seal isn't in good shape. The Cayman R springs and shocks will be done next spring.
05-12-2023, 04:38 AM | #40 | |
Rep 2,345
Well done on the AOS and coils. I change coils at 100k miles regardless of their condition. They are wear items. The side decals look good. I don’t like them on all P-cars, but they look good on your Cayman. Last edited by chassis; 05-12-2023 at 05:24 AM.. |
05-12-2023, 07:13 AM | #41 |
General
61831
Rep 19,969
There's a black '13 718 a few doors away from a family members house and it looks great although always looking filthy lol.
If I'm not mistaken the 718 designation is the same for both the later Boxters and Caymans with the earlier Boxters at 986. |
05-12-2023, 07:14 AM | #42 |
Rep 3,043
Man that's a LOT of work, wow. You'd be broke if you were not doing it yourself. Looking good though, and we both have the same wheels.
05-15-2023, 12:35 PM | #43 | |
Rep 5,393
-Sachs clutch, OEM flywheel, and new muffler straps (originals were rusted) installed for $2900 - OEM engine mount, engine mount "bumpers", and transmissions mounts $650 - 4 hours - OEM updated shifter cables and associated updated mounting hardware $600 - 4 hours - Clutch switches (2) $60 - 10 minutes - Brake switch $30 - 1 minute - AOS $120 - 1 hour - Vent line from AOS to the throttle body assembly $90 - 5 minutes - OE coil packs $250 - 1 hour - New air filter $30 - 10 minutes - OEM coolant reservoir caps (2) and oil cap $80 - 5 minutes - OEM gas cap (leaking seal causing gas tank vent code) $20 - 1 minute Yep, over $4,800 in parts and labor. Luckily, Porsche Colorado Springs gave me a check for $3000 so out of pocket, I'm around $1,800. All the suspension bushings look fine, but I still need to address from suspension bumps stops. I'll do that when I install the Cayman R suspension next year. For now, I just cut off the degraded upper portion of the bump stop and installed a piece of left over bump stop from the M235. 5 minute temporary fix
chassis6690.50 |
05-15-2023, 12:36 PM | #44 | |
Rep 5,393
986 (no Cayman in this generation) 987 981 718
