| 05-30-2025, 02:14 PM | #353 |
![]() 3279
Rep 2,404
Giro uses a higher PCD in its rings, Paragon doesn't have that issue.
M2 Competition 6MT: MCS 3way, Full Kinematics, Custom LSD diff, Lift Kit, CF Propshaft, 513M 18x10.5 ET46 Square, CF Recaro's Pole Position, ST2 Hybrid Turbos, Keyed Crank Hub, CCB, Ti Pistons, 1465kg with half of fuel tank,
600hp/800nm. |
egparson202280.00 |
| 05-30-2025, 02:14 PM | #354 | |
Track rat, well-meaning but not all-knowing
280
Rep 337
Drives: ‘21 M2C, ‘18 Audi TTRS
21 M2C 6MT | Bimmerworld | Competition Motorsport | OMP | Lifeline | Stilo | HANS | RE-71RZ | PFC | Girodisc | @Track/S | Ground Control | SPL | MCS | Drexler | Rogue | VTT | Injen | Active Autowerke
| 05-30-2025, 02:17 PM | #355 |
280
Rep 337
If the Girodiscs spin freely with no interference, am I good to go? I don’t mind close tolerances but don’t want trouble.
| 05-30-2025, 02:46 PM | #356 |
![]() 14
Rep 49
I wish I knew that prior as was lead to believe that Giro custom make the hats to suit your brackets and to be able to run the 2NH/F10 calper without having to further modify. When you sa PCD do you mean that the Giro has a different dimension to the OEM disc?
| 05-30-2025, 03:13 PM | #357 |
![]() ![]() ![]() ![]() 1618
Rep 925
The pads overhang - which in simple terms means this is not a well engineered solution as the pads should be centralised over the friction ring.
The pics here clearly show that there is further room to move the caliper outboard, which would alleviate some of the inner pad overhang. The pads are not fully flush with the outer edge of the friction ring, yet they overhang the inner and are VERY close to the disc hats. |
DetailDevil13.50 |
| 05-30-2025, 03:42 PM | #358 |
![]() 3279
Rep 2,404
You won't have any problems, i have a local client with this setup for 5 months now, and no problems.
600hp/800nm. |
egparson202280.00 |
| 05-31-2025, 01:17 PM | #360 | |
Rep 25
ME20 Protrack One 18x10.5J ET27 with 12mm spacer F80 caliper ( Gold ) No issue also with already many laps on the Nordschleif the only issue i get for the moment it’s the brake pedale sometime hard sometime soft don’t know why i using castrol SRF and Goodridge brake line and i do flush with Abs process i will see next year since the car are stored at Nürburgring.
iG : StixR_
DetailDevil13.50 |
| 06-01-2025, 03:03 AM | #361 | |
![]() 14
Rep 49
![]() So do the Girodiscs have custom hats, or just regular hat Is the caliper the 2NH/F10 6 pot caliper Reason I ask is I am wondering if I may be able to use my existing 400mm EBC discs, and shave caliper the same as you have? |
StixR_24.00 |
| 06-01-2025, 03:13 AM | #362 |
Rep 25
Like i have ? I don’t think so … i shave it just a little with the Oleg bracket you will not be able to install 400mm and yes custom girodisc hats.
iG : StixR_
| 06-01-2025, 05:13 AM | #363 | |
![]() 14
Rep 49
1, So you have 400mm custom girodisc hats 2, You have Oleg's modified brackets 3, You have shaved calipers as per you pictures 4, You're running 18in 10.j et27 Protrack one wheels Regarding point 1 - What is the item code for the custom girodisc hat, and I assume these are mated to a 400x36mm girodisc fritction ring? Regarding point 2 - Are these the normal modified brackets Oleg supplies to allow the use of the F10/2NH caliper with 18in wheels |
| 06-01-2025, 06:32 AM | #364 | |
Rep 925
There is ZERO chance of getting a 400mm disc under 18" wheels - unless you take a significant amount of material off the caliper body. |
DetailDevil13.50 |
| 06-01-2025, 08:42 AM | #365 |
280
Rep 337
Yes and no. The Girodisc piece is a new combination of off the shelf components. It’s an F87 hat with G87 rings.
StixR_24.00 |
| 06-01-2025, 09:20 AM | #366 |
Rep 25
Yeah but it’s custom so not available in the standard catalogue
iG : StixR_
egparson202280.00 |
| 06-01-2025, 09:28 AM | #367 | |
Rep 25
iG : StixR_
DetailDevil13.50 egparson202280.00 |
| 06-01-2025, 09:37 AM | #368 |
![]() 14
Rep 49
| 06-13-2025, 08:08 AM | #369 | |
![]() 14
Rep 49
Hey Tom, Think it may have been you that replied to my email regarding EC-7 wheels with shaved 2NH calipers and 400mm discs?? Another query, are the inner barrel dimensions/clearence on the EC-7 identicle to the EC-7RS? Thanks Louie |
| 06-13-2025, 10:36 AM | #370 | |
4483
Rep 7,316
Posts ![]() |
No, they are not identical. Some of the profiles are similar, but the forged wheels carry better clearance through a longer portion of the barrel than the flow formed wheels. The differences vary depending on the size and offset though. -Tom
DetailDevil13.50 |
| 06-21-2025, 09:47 AM | #371 |
![]() 14
Rep 49
FOR ANYONE LOOKING FOR THIS SET UP :-)
https://f80.bimmerpost.com/forums/sh...6#post32163606 https://www.facebook.com/marketplace...9679478521494/ https://www.facebook.com/marketplace...9811422773032/ |
| 06-22-2025, 09:42 PM | #372 |
280
Rep 337
I’m making progress. After installing the Track/S caliper bracket and the custom Girodisc rotors, I did a test fit with a Bimmerworld TA16 18x10 ET33 wheel. As expected the clearances are tight, but there is no interference.
The next step is to mount 275-35-18 RE71RS tires. That’s when I’ll fine tune with spacers. For now I have 12mm and 20mm spacers on hand. I may need 15’s to clear the brake deflectors. We’ll soon see. Anybody with firsthand experience?
| 07-10-2025, 09:47 PM | #373 |
![]() 64
Rep 118
| 07-11-2025, 03:13 AM | #374 |
![]() 14
Rep 49
| Bookmarks |
