M2 Technical Topics > Track / Autocross / Dragstrip > Custom 2NH Bracket (for fitting 18”)
      05-22-2025, 03:42 AM   #331
DetailDevil
Drives: F82 M4 COUPE
Originally Posted by StixR_ View Post
Thanks i was busy yesterday to make a long post like that
DetailDevil where are you from and where you drive the car ? It’s a easy job to shave the caliper …
Is this where its shaved? If so thats easy and I can do this NP
      05-22-2025, 03:44 AM   #332
StixR_
StixR_'s Avatar
24
Drives: BMW M3 F80
Yeah top and bottom same place but put everything on it see where it’s touching and shave it
Here is a caliper shaved to fit 400mm disc on 18
iG : StixR_
n8dgr84341.50
      05-22-2025, 04:18 AM   #333
DetailDevil
Ahh thanks dude!!!!
Oooo - are they the 2NH/F10 calipers? Can these also be used with my existing 400mm EBC floating discs? If so that will save me having to change discs, and keep existing set up. OK I have ordered the brackets from Track/S but Can sell these on?
      05-22-2025, 08:38 AM   #334
StixR_
StixR_'s Avatar
24
Drives: BMW M3 F80
Ahh thanks dude!!!!
Caliper are the same so yeah you can shave it the same like the picture but i will not feel save to do so i know 2 guy’s doing it on M2C but i don’t gonna take the risk to remove that much of material on caliper better to remove less as possible
iG : StixR_
      05-22-2025, 09:28 AM   #335
DetailDevil
Thanks buddy - thats a valid comment and I see a lot of shaving there so will just shave top/bottom and go with 380x36 Girodiscs
StixR_24.00
      05-22-2025, 11:15 AM   #336
comp2
Drives: m2 comp x5d
What brake setup you have on your car ?
its stock 2nh brakes right now.
      05-22-2025, 04:04 PM   #337
Track/S
Track/S's Avatar
3279
Drives: M2C, M4 GTS
Originally Posted by comp2 View Post
Track/S i have a 20 m2 comp. My goal is to clear 18" wheels. What would I need to accompany your brackets?
You need custom discs from paragonbrakes or girodisc 380x36mm
M2 Competition 6MT: MCS 3way, Full Kinematics, Custom LSD diff, Lift Kit, CF Propshaft, 513M 18x10.5 ET46 Square, CF Recaro's Pole Position, ST2 Hybrid Turbos, Keyed Crank Hub, CCB, Ti Pistons, 1465kg with half of fuel tank,
600hp/800nm.
      05-22-2025, 04:17 PM   #338
D_SheerDrivingPleasure
D_SheerDrivingPleasure's Avatar
1793
Drives: Very Fast F80 & G80
Emai Robin to order the custom girodisc rotor for the 2NH.
robin.adrianse@girodisc.com
Be sure to tell him that Derek referred you.
For every 5 referrals I get a set of free friction rings.
Dare I squeeze three at yo' cherry M3
Track/S3278.50
mattr832211.50
      05-23-2025, 08:45 AM   #339
DetailDevil
Wish I knew that as I ordered via Robin last night
      05-24-2025, 09:49 PM   #340
comp2
Drives: m2 comp x5d
yessir
      05-24-2025, 09:51 PM   #341
comp2
Drives: m2 comp x5d
how do i place an order for your brackets?
      05-25-2025, 04:02 AM   #342
DetailDevil
PM Him. Easiest way then you can sort your requirements
      05-26-2025, 01:10 PM   #343
DetailDevil
Guys, for those running the 2NH/F10 front Calipers with 380x36mm Girodiscs or Paragon Discs, what track pads are you using? I'm conidering
Pagid RSL29
EBC - RPX
Endless ME20
Advice,opinions welcomed
Thanks
Louie
      05-26-2025, 03:25 PM   #344
1793
Pagid RSL29
EBC - RPX
Endless ME20
Thanks
Louie
For track use I really like the PFC 332/331 (available from Bimmerworld).
Any pads that fits the 2NH caliper will also fit with the custom bracket and Girodisc/Paragon rotor.
      05-27-2025, 05:05 PM   #345
StixR_
StixR_'s Avatar
24
Drives: BMW M3 F80
PFC08 or PFC11 are good i try ME20 on mine next time will use MA45B expensive but last longer and a little bit more better than ME20 for my use ( Nordschleif )
iG : StixR_
      05-30-2025, 10:12 AM   #346
DetailDevil
Hey folks, some help and advice needed. This is the email I have sent to Robin @ Girodisc after conducting the test fit.I await his reply.
Hey Robin, i hope you're well.
We have today concudted a test fit using the Girodiscs I purchased, the modified caliper brackers & 5mm shims from Oleg (Track/S on Bimmerpost) my F10 6 Pot Calipers, currently housing EBC yellostuf pads, and an 18in 10j et25 Protrack One wheel.
The first observation is that the pad is VERY close to the hat bobbins, and i mean VERY close. Its not making contact with the pad, but to me its too close.
We have checked the outer friction ring edge, and the pad is aligned perfectly. Can you advise if this is correct, as I am concerned that when on track, and with the additional heat created that will expand the brakes, the pads could come in to contact with the hat bobbins?
I messaged Track/S and also StixR_ and they mentioned shaving the pads, but this isn't something I have seen mentioned on any forums? I will eventually be installing Endless ME20 pads, but assume tthe pad size would be the same as what I am currently running with my 400mm EBC floating discs, and have 20in wheels cyrrently.
With regards to the inner barrel/caliper clearence we have had to skim the top & bottom of the caliper, which was expected, and this isn't an issue
StixR_24.00
      05-30-2025, 10:15 AM   #347
DetailDevil
[ATTACH]undefined[/ATTACH]
      05-30-2025, 10:56 AM   #348
egparson202
Track rat, well-meaning but not all-knowing
egparson202's Avatar
280
Drives: ‘21 M2C, ‘18 Audi TTRS
I haven’t heard prior mention of shaving the pads to help clear the hat/bobbins. Maybe it’s a Girodisc-specific issue. Or maybe it’s that particular set of pads. Have you compared yours to the photos in this thread and found them to be even closer?
21 M2C 6MT | Bimmerworld | Competition Motorsport | OMP | Lifeline | Stilo | HANS | RE-71RZ | PFC | Girodisc | @Track/S | Ground Control | SPL | MCS | Drexler | Rogue | VTT | Injen | Active Autowerke
      05-30-2025, 10:59 AM   #349
StixR_
StixR_'s Avatar
24
Drives: BMW M3 F80
I add picture for DetailDevil since he have a issue
iG : StixR_
n8dgr84341.50
      05-30-2025, 01:08 PM   #350
DetailDevil
Thanks buddy - I have ordered some M12x1.5mm & 2mm flat washers as i reckon that the caliper can come back that amount without impeading the outer edge of the friction disc. Will do a mock up on this, and will likely need to shave some of the caliper bridge as its alreay close to the inner barrel. I am still waiting for Robin @ Girodisc to advise, but I would have thought this info should have been shared prior to me purchasing the discs with the "custom hats" I'll also have a look at othe rthreads too.
Thanks to StixR_ for posting the photos for me
StixR_24.00
      05-30-2025, 01:24 PM   #351
egparson202
280
Soon enough you’ll have it resolved and begin realizing the benefits. Until then, try your best to enjoy the experimentation. I’m looking at it like this is something of a group collaboration with a number of moving parts, any of which can create enough change to disrupt the balance (aka consume more than their share of the precious space we’re toying with). There are some combinations that are working for some people and others that haven’t yet been proven. Maybe the Paragon rotors would be a better fit for your combination than the Girodisc. Or maybe it’s the pads, and others would yield a slightly better fit. In any case, it sounds like you’re within striking distance. Hang in there.
StixR_24.00
Track/S3278.50
      05-30-2025, 01:35 PM   #352
DetailDevil
Thanks egparson202
I echo your comments, and if it wern't for this forum I'd be none the wiser!!!!
I will keep the faith, and the build continues in readiness for my 3rd trip this year to the Nurburgring in August!!!!
