M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > BMW n55 new pure turbos (pure 500 and pure 750)
      05-01-2024, 08:02 PM   #331
VGSON
VGSON's Avatar
Drives: F87 OGM2
Originally Posted by ThreeStripes View Post
You might consider the OTS Supersprint mid section that’s 3.1in diameter and mates to factory bits in that case.
https://www.turnermotorsport.com/p-1...gFkoNlDB0VPAlY
I personally would look at 4N’s f8x midsection & adapting your current DP to match….or get something made. It’s honestly not that much $$ especially compared to what these aftermarket setups run.
M2guru425.50
      05-01-2024, 08:14 PM   #332
ThreeStripes
Drives: X3M
Big single sure does sound good.
M2guru425.50
      05-01-2024, 10:47 PM   #333
AmuroRay
AmuroRay's Avatar
2379
Drives: M235i
Originally Posted by M2guru View Post
Not sure about the map. I do have a question into my tuner about the power delivery/lag.
Intake is stock. Exhaust is stock except for the catless pipe.
I haven't seen an intake that would perform better in terms of bringing in cold air. Maybe I am missing it or I should be looking at flow more than temp...?
I would love to open up the exhaust, but not sure what is best. I might try to make one myself because I'd like to try, but I don't think that's in the cards. Now that I am not driving it on the street, I only have to worry about noise ordinances at tracks or my ears.
The CTS intake had a measurable impact on WGDC and IATs. My RK intake even more so - I compared them in the MILVS thread I believe. The only issue with the RK is if the filter will block airflow to the radiator. neonbrown said he didn’t have any issues with his coolant/oil temps after installing it and it cut his IATs down by an additional 15-20F? He made a thread where he was talking about it.
On the exhaust, the biggest restriction is after the downpipe. There was a guy selling a complete AWE exhaust for like $1.3k? Including midpipe and muffler. Again, for me, this was a measurable decrease in wgdc.
My wgdc is about 10% lower than someone with similar mods due to these changes.
Mods: Yes.
M2guru425.50
      05-02-2024, 12:44 AM   #334
ZM2
Drives: 2017 LBB M2
Haven’t seen that the CTS intake has much of an impact vs the stock M2 intake that is closed under the hood and already has cold air routing to the nostril area. An aFe scoop will grab more of that cold air.
Guessing the RK intake has some impact for the M2, if you’re OK with the looks and don’t need clean air to the radiator. I’ll pass.
My WGDC stays 85-90% on track even on my near 500whp tune, so not sure why M2guru is hitting 100%. Boost leak?
M2guru425.50
      05-02-2024, 10:44 AM   #335
ericlr1225
ericlr1225's Avatar
Drives: 2018 M2 LCI 6MT
Stock box + stock intake are fine, I'd assume somewhere is leaking or it's the tune. Check WGCD calibration too. Small turbos could hit 25-26psi with 90% at 6k. 100% is def not right. I've seen Pure750 logs 30psi+ at 90s%.
VGSON222.00
      05-02-2024, 01:40 PM   #336
VGSON
VGSON's Avatar
Drives: F87 OGM2
when i had a real boost leak i could hear it and could also see it very clearly in logs..He/you may have what i did..My wastegate wasn’t actually closing, was open by about 2mm..People had me chasing leaks. We put it on the lift, took of the dp and cycled it with ista. then adjusted it..His hits 100 briefly then drops to 90’s..which its supposed to do. Gate closes til target is reached, then opens..I can’t see a log to see a full detail, but if you’re always in the 90-100 range and at 21psi…check your wastegate.
M2guru425.50
      05-02-2024, 04:05 PM   #337
M2guru
2018 BMW M2  [10.00]
I appreciate everyone's thoughts. I'll check the wastegate then boost leaks. I didn't check the wastegate after I installed it - only measured per the manual and sent it.
Now to figure out how to check/cycle the wastegate...not feeling like learning the software-side of things...might bring it to an indy shop. Next track day is a week away.
VGSON222.00
      05-03-2024, 02:57 AM   #338
Sparky68
Sparky68's Avatar
699
Drives: 2016 M2 Alpine White
2016 BMW M2  [0.50]
2017 BMW F30 330D  [0.00]
2014 M135  [0.00]
2007 BMW 335i  [0.00]
Thinking about replacing the stock turbo with the Pure500. Seen online that you need to reset the WG via BMW software , is that correct ? If so does it make it a shop only install ?
OG M2 7sp DCT Masata FMIC - Masata Boost Pipe - Cobra Catless DP - Powervalve Exhaust - Devilsown Methanol Injection BM3 Stage 2
      05-03-2024, 07:22 AM   #339
ThreeStripes
Drives: X3M
Nope that can be done with several different solutions that are available to you including ProTools and other advanced scanning tools.
Mine is coming along but likely will be another 3-4 weeks before I’ve got meaningful driving impressions and video.
Sparky68698.50
      05-03-2024, 11:14 AM   #340
VGSON
VGSON's Avatar
Drives: F87 OGM2
You should be able to turn the nut very slightly, more closed & check a log. See if there’s improvement or not. Like I mentioned; mine was open 2mm and had no codes..If you get a code, just reverse what you did…
M2guru425.50
      05-03-2024, 07:15 PM   #341
M2guru
2018 BMW M2  [10.00]
I just did exactly this. Will find out in a week how it works during my next track day. I'll keep you posted! Thanks for mentioning this!
VGSON222.00
      05-04-2024, 01:24 PM   #342
M2guru
2018 BMW M2  [10.00]
Boost pressure test complete - one small issue resolved. This along with the wastegate adjustment (without ITSA) will give me something to test on Friday to see where my WGDC ends up.
How do others go about plugging everything to pressure test the intake? I had to use a couple odds and ends to: 1) plug the PVC hose (because I connected at the hard intake tube to the turbo that includes the PVC hose instead of directly at the turbo intake) and 2) plug the hard, narrow plastic tube that goes from the near the intake manifold to the near the air filter.
VGSON222.00
      05-04-2024, 07:22 PM   #343
AmuroRay
AmuroRay's Avatar
2379
Drives: M235i
Do you need a copy of ISTA?
Mods: Yes.
      05-05-2024, 06:21 AM   #344
M2guru
2018 BMW M2  [10.00]
Probably. But more than that, I need a copy of "how to not be lazy" or "how to prioritize cars over other things."
      05-05-2024, 07:36 AM   #345
wheela
wheela's Avatar
Drives: 2015 BMW X1 35i M-sport
If you find some copies of those, please post some links🙂
      05-05-2024, 12:00 PM   #346
AmuroRay
AmuroRay's Avatar
2379
Drives: M235i
https://f30.bimmerpost.com/forums/sh....php?t=1995702
I’m still working on the last part.
Mods: Yes.
      05-05-2024, 03:24 PM   #347
wheela
wheela's Avatar
Thanks for that link
      05-07-2024, 12:41 AM   #348
Sparky68
Sparky68's Avatar
699
2016 BMW M2  [0.50]
2014 M135  [0.00]
Thanks @ThreeStripes Have you come across any guides of how it is done as never used coding software before ?
      05-07-2024, 08:35 AM   #349
ThreeStripes
Drives: X3M
Haven’t done this personally. I’ll have to defer to others for a detailed guide but I did find this poking around: https://f30.bimmerpost.com/forums/sh....php?t=2078019
Sparky68698.50
      05-08-2024, 12:35 PM   #350
ThreeStripes
Drives: X3M
Tuning is progressing nicely. Bend Cal says logs look great so mechanically the car seems to be in good order which is huge.
I’ve been able to let it eat up top and can confirm Pure500 performs better above 5250 according to butt dyno. It’s still early days but I’m feeling confident in the Pure500s ability to make 460+ on emix. Dyno charts should be ready late May at this rate.
As I was parking it up last night I couldn’t help but think this setup is exactly what I was after:
- Safer tune than BM3 OTS
- Carry power better above 5
- Maintain stockish time to boost and amplify the original character of the OG M2
M2guru425.50
      05-10-2024, 06:44 PM   #351
ThreeStripes
Drives: X3M
Installation laps this weekend. Stoked to shake it down on pump gas.
F87source7367.00
TUDMG24.00
      05-11-2024, 03:39 AM   #352
samsamdar
samsamdar's Avatar
Drives: OG M2
2018 BMW M2  [6.67]
ThreeStripes how’s the lag on the P500?
