| 05-21-2025, 10:51 AM | #309 |
![]() 1049
Rep 1,351
The shim is used with the F10 M5 caliper to compensate for the 5 mm deeper milling on the M5 caliper mounting surface compared to the 2NH caliper. So in reality with the shim your calipers have become 2NH spec.
This is the only account I have on Bimmerpost, I will never post my e-mail publicly. If you want to contact me send a PM or you can find me on Instagram: @andre_westersund or @westersund_motorsport
BMW M2 LCI -18 | BMW 520DA Touring M-Sport -12 | BMW Z4 M Coupe -06 | BMW 330i -05 | BMW M3 -02 | BMW Z3 Coupe -99 | BMW 740i/6 -96 | BMW M5 3.8 -92 | BMW M535i -87 |
| 05-21-2025, 11:57 AM | #310 | |
![]() 14
Rep 49
Thank you for that explenation! So without sounding dumb, I am guessing that as I have effectively now got a 2NH caliper, purchasing the Protrack One wheels 18x10j et25 should fit? or would I need a different et? |
| 05-21-2025, 11:59 AM | #311 |
![]() 1049
Rep 1,351
I don't know about the wheel, but you can compare with everyone else that has the 2NH caliper.
| 05-21-2025, 12:10 PM | #312 | |
![]() 14
Rep 49
| 05-21-2025, 12:13 PM | #313 |
![]() 14
Rep 49
And can anyone confirm if these are the correct variant of 380x36mm Giro Discs that are required for use with the brackets from Track/S using the 5mm shims
https://girodisc.com/bmw-f8x-m2-m3-m...-front-rotors/ Last edited by DetailDevil; 05-21-2025 at 12:20 PM.. |
| 05-21-2025, 12:19 PM | #314 | ||
![]() 285
Rep 170
egparson202280.00 DetailDevil13.50 |
| 05-21-2025, 01:00 PM | #315 | |
Rep 25
295/30R18 CRS And you will need to shave the caliper and will fit like that
iG : StixR_
| 05-21-2025, 01:36 PM | #316 | |
![]() 14
Rep 49
TeeeeeeDub284.50 |
| 05-21-2025, 01:39 PM | #317 |
![]() 14
Rep 49
I don't understand why I need to shave caliper? I am using F10 (Blue) calipers with 5mm shims, so surely if this is the case I install without the 5mm shims? I want Sq set up, not staggered, and 275/40/18 with Protrack One 18in 10j et25
| 05-21-2025, 01:41 PM | #318 |
Rep 25
If you don’t want to shave it don’t buy Protrack One the 5mm shims it’s for the caliper get centered to the disc … since you use F10 M5 caliper.
iG : StixR_
| 05-21-2025, 01:50 PM | #319 | |
![]() 14
Rep 49
So basically with Girodisc 380x36 you're saying that a protrack one 18in 10j et25 will not have sufficiant clearence unless my F10 calipers are shaved? You had 2NH calipers, but still shaved, hence my confusion? |
| 05-21-2025, 01:53 PM | #320 |
Rep 25
Yes it was brand new but i shave it only protrack and Apex was too long waiting i talk to the boss of Protrack even the forged and Y5 model will not fit without shaving the caliper
iG : StixR_
| 05-21-2025, 03:09 PM | #321 | |
![]() 14
Rep 49
My plan is to next week while fitting additional brake cooling is to take off my existing 400mm discs, remove the existing modified brackets that blau3er supplied fit the new brackets that Track/S supplied and test fit the protrack rim for clearence blau3er value your advive and opinion so please feel free to chime in ![]() |
| 05-21-2025, 04:32 PM | #322 |
![]() ![]() ![]() ![]() 1618
Rep 925
OK, some clarification needed here...
F10 M5 calipers are dimensionally IDENTICAL to the silver/grey 2NH or the gold CCB. The ONLY difference being a 5mm height difference at the point of meeting the swivel bearing. Therefore, moving forward you need to understand that the 5mm shim supplied is purely to make the M5 calliper body 100% identical to 2NH / CCB variant. You cannot 'not use' the shim, as otherwise you will have incorrect pad sweep on the friction ring - and you may even cause the caliper to contact the brake disc. It's a no go. The simple answer is that if a 2NH / CCB caliper needed to be shaved to go under the Protracks, using Track/S brackets, then your M5 caliper will also need to be shaved down too using the same brackets / 5mm shims..... |
StixR_24.00 DetailDevil13.50 |
| 05-21-2025, 04:51 PM | #323 | |
![]() 14
Rep 49
| 05-22-2025, 12:41 AM | #324 |
Rep 5
Hey guys I just recently made this account and its not letting me direct message anyone. Can someone put me in the right direction to purchasing the caliper brackets?
| 05-22-2025, 12:47 AM | #325 | |
![]() 285
Rep 170
F87 ///M2 Competition | BBS | Akrapovic | Active Autowerkes | TCK | SPL
| 05-22-2025, 02:05 AM | #327 | |
Rep 25
DetailDevil where are you from and where you drive the car ? It’s a easy job to shave the caliper …
iG : StixR_
| 05-22-2025, 02:07 AM | #328 |
Rep 25
What brake setup you have on your car ?
iG : StixR_
| Bookmarks |
