| 05-08-2025, 05:09 AM | #289 |
![]() 3279
Rep 2,404
Yes
You don't need anything else, i would have to make you custom brackets
M2 Competition 6MT: MCS 3way, Full Kinematics, Custom LSD diff, Lift Kit, CF Propshaft, 513M 18x10.5 ET46 Square, CF Recaro's Pole Position, ST2 Hybrid Turbos, Keyed Crank Hub, CCB, Ti Pistons, 1465kg with half of fuel tank,
600hp/800nm. |
| 05-08-2025, 05:11 AM | #290 |
Rep 24
| 05-08-2025, 07:03 AM | #291 |
![]() 3279
Rep 2,404
Different for e90
600hp/800nm. |
| 05-08-2025, 08:19 AM | #292 |
![]() 149
Rep 227
chiefsubjugator109.50 egparson202280.00 |
| 05-09-2025, 08:38 AM | #295 | |
![]() 3279
Rep 2,404
Yes i can do
600hp/800nm. |
| 05-14-2025, 12:46 PM | #297 | |
Track rat, well-meaning but not all-knowing
280
Rep 337
Drives: ‘21 M2C, ‘18 Audi TTRS
I’ve acquired the custom brackets (Thanks @Track/S) and Girodisc hats and discs (arriving today). I’ll probably put them into service after this weekend’s track event in pursuit of some handling advantage and to get positioned to move to 18” wheels/tires. I could likely wait a bit for the factory discs to wear out completely, but doing it sooner makes them available as spares and realizes the gains sooner.
21 M2C 6MT | Bimmerworld | Competition Motorsport | OMP | Lifeline | Stilo | HANS | RE-71RZ | PFC | Girodisc | @Track/S | Ground Control | SPL | MCS | Drexler | Rogue | VTT | Injen | Active Autowerke
| 05-19-2025, 02:00 PM | #298 |
Rep 25
If people can share tyre and wheel setup that fit we can maybe put a post to list all the wheel setup past without shaving the caliper.
iG : StixR_
| 05-20-2025, 12:05 PM | #299 |
![]() 14
Rep 49
Hey guys,
I have a set of brackets coming from Track/S in a few days time. These are supplied with 5mm shims as I have the Blue F10 6 piston calipers on my F82 M4 Can anyone advise if they have fitted 18in Protrack One Wheels 10J ET25 using 380x36 Paragon or Girodiscs together with the Blue F10 6 Pot Caliper? I'm looking at going sq set up using AD09s 275x40x19, and willitfit.com stated that 10mm spacers needed on fronts Or I'd consider Apex EC-7 wheels, 18in 10j ET25 Thanks guys Louie ![]() |
| 05-20-2025, 12:12 PM | #300 | |
![]() 14
Rep 49
| 05-20-2025, 02:59 PM | #301 | |
![]() 1793
Rep 1,336
You could also use Bimmerworld 10.5x18 ET36 I have MCS dampers.
Dare I squeeze three at yo' cherry M3
| 05-21-2025, 01:13 AM | #302 | |
![]() 14
Rep 49
I have KW V3 coilovers, but ideally want 18in 10j ET25, as looking to run 275/40/18 AD09 tyres |
| 05-21-2025, 01:25 AM | #303 |
![]() 14
Rep 49
Oleg, this is the set up I want. With your brackets, 5mm shims, F10 Blue calipers, Paragon or Girodisc 380x36mm discs and wheel size
18in 10j 5x120 ET25 would that all fit? I have Protrack sending me a test rim, but not got discs yet so will test fit with just the calipers and your brackets |
| 05-21-2025, 01:30 AM | #304 | |
![]() 14
Rep 49
| 05-21-2025, 01:33 AM | #305 |
![]() 14
Rep 49
| 05-21-2025, 01:42 AM | #306 | |
Rep 25
Already drive it 41 laps on the Nordschleif no issue. Protrack One Front 18x10.5J ET27 ( 12mm spacer wheel ) Protrack One Rear 18x11J ET44 ( 12mm spacer wheel ) I just shave it because the barrel are more narrow like 1.5mm or 2mm on the top and bottom caliper both side.
iG : StixR_
| 05-21-2025, 02:46 AM | #307 | |
![]() 14
Rep 49
Track/S So with your brackets you're sending and the 5mm shims would my planned sq set up of Protrack Ones 18in 10j ET25 using 380x36mm girodisc work? ![]() |
StixR_24.00 |
| 05-21-2025, 03:42 AM | #308 | |
![]() 14
Rep 49
| Bookmarks |
