06-01-2023, 09:21 AM | #265 | |
Rep 435
Drives: F87 M2 DCT, F15 X5
‘18 F87 M2 DCT
'17 F15 X5 xDrive35i M-Sport Sold in 2023 '12 F30 335i 8AT Sport Line Sold in 2020 '08 E92 335xi 6MT Sold in 2016 '08 E90 335i 6MT - FBO |
06-01-2023, 09:54 AM | #266 |
Rep 435
‘18 F87 M2 DCT
CSBM52756.00 |
06-01-2023, 01:24 PM | #267 | ||
Rep 7,542
06-01-2023, 01:39 PM | #268 | |
Rep 435
Interestingly the tech document for the F80/82 specifies a fluid change every third oil change, whereas the F87 tech document specifies every 5th oil change. Yet, official BMWUSA maintenance guides are every 5th oil change.
‘18 F87 M2 DCT
CSBM52756.00 |
06-01-2023, 10:21 PM | #269 |
New BMW owner
328
Rep 846
I'm still trying to get my head around the spider gears and its rotation to allow diff speeds on each wheel. Engineering!
are there a set of clutch packs for each L&R wheel? or just one as shown on that video.
06-02-2023, 04:49 PM | #270 |
Rep 435
No just one clutch pack. A clutch pack on either side is more like the Audi Sport Diff or focus RS diff or MK8 Golf R. Those offer more will slip control at the expense of cost and weight.
‘18 F87 M2 DCT
06-13-2023, 03:39 PM | #271 |
Rep 882
So both the gearbox and rear axle survived 3870 km to Germany and back, including about 400 km around the Nürburgring. Just wanted to let you guys know in case you want to step out of that cozy BMW dealership bubble and try something that works great for a lot less money.
BMW M2 LCI -18 | BMW 520DA Touring M-Sport -12
| BMW Z4 M Coupe -06 | BMW M3 -02 | BMW Z3 Coupe -99 | BMW 740i/6 -96 | BMW M5 3.8 -92 | BMW M535i -87 |
F87source7368.50 |
06-13-2023, 03:44 PM | #272 | |
Rep 7,542
For me atleast, MSP/A from bmw is still cheaper than Castrol syntrax.
Westersund511.00 |
06-24-2023, 01:05 PM | #274 |
Rep 435
Yeah it’s a little more than 1L which is kinda annoying. Just changed it and it took about 1.1-1.2L. I think in the benchmarking study we did at work at was around 1140ml, I can double check the reports. Not sure if that was dry fill or wetted fill though.
Edit: I checked the report it is 1120mL to bottom of fill plug at 0 degrees pinion angle. With the pinion tipped up slightly in the installed position (4 degrees maybe?), it might be slightly less than this.
‘18 F87 M2 DCT
'17 F15 X5 xDrive35i M-Sport Sold in 2023 '12 F30 335i 8AT Sport Line Sold in 2020 '08 E92 335xi 6MT Sold in 2016 '08 E90 335i 6MT - FBO Last edited by E90convert; 06-24-2023 at 01:13 PM.. |
CSBM52756.00 |
06-24-2023, 01:06 PM | #275 | |
Rep 7,542
I also measured it when I drained it, and it was exactly 1L (filled up the original MSP/a bottle) 6mt is 1.3L.
https://f87.bimmerpost.com/forums/sh...2#post30368242 Last edited by F87source; 06-24-2023 at 01:42 PM.. |
CSBM52756.00 No_curebimmer645.00 |
06-24-2023, 02:04 PM | #277 | |
Rep 7,542
I can screen shot the ISTA docs for you, so you know I'm not making stuff up. Just don't let me forget, I'll be home in a few hours.
06-24-2023, 02:08 PM | #278 |
Rep 1,404
if one day you run out of ISTA you will not know how to tighten a screw 😂
06-24-2023, 02:17 PM | #279 |
Rep 7,542
So you're implying you don't follow bmw's prescribed fill volumes and torque specs? That's confidence inspiring for any potential customers coming to your shop.
06-24-2023, 03:04 PM | #280 | |
Rep 8,972
I just use it for fault diagnostics and wiring diagrams |
06-24-2023, 03:29 PM | #281 |
Rep 215
I just wrapped up the rear diff fluid flush right now and can confirm the capacity was exactly 1L as others above have said. Torque value for drain/fill plugs are 45 Nm per ISTA.
06-24-2023, 04:09 PM | #282 |
Rep 7,542
It's part of the vehicle management section. I'll share some screen shots and that's should be enough ro you to get a hang of it.
06-24-2023, 04:31 PM | #283 | |
Rep 7,542
You will notice under the vehicle management tab and then repair/maintenance tab and then product structure, you will get a bunch of categories related to the car. If you click on rear axle-> rear-wheel drive, guide -> rear axle final drive you will get information on the diff. Next I will click on REP oil change in the rear axle final drive. Image 2: This is the rear diff oil change guide, it will tell you how to change the diff as per BMW AG, so the info contained here is as per BMW and the correct way to change the oil on the diff - no one else's opinion has any weight compared to this. So you will notice the tightening torque is 33 11 5AZ (the 5AZ part is critical so memorize it), if you click on that this page will pop up: Image 3: If you look at the table and 5AZ, you will notice screw plug with o-ring (this is the diff drain and fill bolt). The next thing you will notice that it is mandated that you replace both screw plugs - likely because the o-rings will be deformed and unable to seal properly after 1 use. Next you will notice that the torque spec is 45 NM. If we refer back to Image 2 you will notice there is a technical data hyperlink for filing capacity. If you click on that you will get this: Image 4: This table will tell you how much oil the diff takes, and for both a brand new diff and for a diff oil change you require exactly 1 liter, no more no less. If you have your car on a level surface (I measured my garage with a level before doing this), you will notice that after exactly 1L of diff oil has been pumped in there will be a very slow thin dribble of oil from the fill plug, and thus the diff indeed is full at 1L. I also measured 1L of used oil drained out as well, so there is that. Hope this helped!
06-24-2023, 04:49 PM | #284 | |
Rep 7,542
From this thread: https://f87.bimmerpost.com/forums/sh....php?t=1938793 As per ISTA, BMW stipulates that you are not to drive without the stiffening plate in place. I suspect this is due to the possibility of the sub frame damage due to torsional strains, in conjunction with debris damaging the oil pan. But since the M4 GTS with the stiffening plate cover in place still requires the stiffening plate, I suspect it must be due to structural rigidity requirements. So what does Track/S do with his ifinite "wisdom", he deletes the stiffening plate and replaces it with a thin carbon cover that not only is rigid enough to provide additional structural rigidity for the car, but is also only attached by the flimsy trim screws that are secured to the plastic underbody panel - and note, these screws are NOT meant to handle any significant loads.... This is why I will NEVER ever trust a shop to do work on my car, because you never know if they will do things by the book (torque specs, filling capacities, or critical BMW guide lines), or think they know everything and just end up doing sketchy things like this. Lets just hope you read ISTA carefully for your customers. Like I said in the original thread, the idea of creating a carbon stiffening plate cover is ingenious, it would be a really great item to sell as an aero device to help clean flow over the stuffening plate. But deleting the stiffeing plate and replacing it with this is a bad idea.
https://f87.bimmerpost.com/forums/sh...2#post30368242 Last edited by F87source; 06-24-2023 at 04:54 PM.. |
E90convert182.00 |
