| 02-02-2025, 12:52 PM | #243 |
![]() 1793
Rep 1,336
About 2 fingers of clearance with BimmerWorld TA5R 18x9.0 ET31
Dare I squeeze three at yo' cherry M3
| 02-03-2025, 12:31 PM | #244 |
![]() 1049
Rep 1,351
You have very tiny fingers if you can fit 2 of them inbetween the caliper and wheel.
This is the only account I have on Bimmerpost, I will never post my e-mail publicly. If you want to contact me send a PM or you can find me on Instagram: @andre_westersund or @westersund_motorsport
BMW M2 LCI -18 | BMW 520DA Touring M-Sport -12 | BMW Z4 M Coupe -06 | BMW 330i -05 | BMW M3 -02 | BMW Z3 Coupe -99 | BMW 740i/6 -96 | BMW M5 3.8 -92 | BMW M535i -87 |
4
| 02-03-2025, 12:42 PM | #245 |
![]() ![]() ![]() 866
Rep 627
Drives: '21 M2C, '20 G05 X5, '17 X3
Westersund1048.50 D_SheerDrivingPleasure1793.00 |
| 02-04-2025, 07:23 AM | #246 |
![]() 1548
Rep 2,772
Track/S it looks like you recommended 25mm spacers with the 10.5x18 square 513m wheel setup in the past but perhaps recommend 15mm now? Also curious what length wheel studs are best for this fitment front and back?
Searching for the best source/price on 10.5” 513m wheels at the moment and will be in touch on the 2NH adaptors soon. Likely going girodisc on the rotors.
2020 M2 Competition | 3.0L | DCT
| 02-04-2025, 08:42 AM | #247 | |
![]() 3279
Rep 2,404
With coilovers 30mm With gts knuckles 10/15mm Studs for 25-30mm spacer, part number 36108417045. Studs for 10-13mm spacer, part number 36108417046.
M2 Competition 6MT: MCS 3way, Full Kinematics, Custom LSD diff, Lift Kit, CF Propshaft, 513M 18x10.5 ET46 Square, CF Recaro's Pole Position, ST2 Hybrid Turbos, Keyed Crank Hub, CCB, Ti Pistons, 1465kg with half of fuel tank,
600hp/800nm. |
///Mobbin1548.00 |
| 02-04-2025, 04:42 PM | #248 | |
Rep 5,365
and some bushings, and a diff lift ![]()
| 02-05-2025, 08:29 AM | #249 | |
![]() 1793
Rep 1,336
I stopped working on my car after spending a full day trying to locate the resevior to change the blinker fluid.
Track/S3278.50 |
| 02-05-2025, 09:07 AM | #250 | |
![]() 3279
Rep 2,404
![]() Removing old pistons is very easy!
600hp/800nm. |
| 02-05-2025, 07:56 PM | #251 |
Rep 2
| 02-06-2025, 01:27 AM | #252 |
![]() 3279
Rep 2,404
I'm making 10 sets now, they will be ready soon!
600hp/800nm. |
| 02-06-2025, 06:35 AM | #254 | |
![]() 3279
Rep 2,404
600hp/800nm. |
| 02-07-2025, 12:07 PM | #256 |
![]() 1548
Rep 2,772
ApexWheels is your theory that your 18x10.5 et40 forged sprint line wheels might fit square in this setup? Using a ~20mm front spacer (and no rear spacer)?
Would love such a setup if so. FWIW I have not found the 18x10.5 et46 M2 Racing wheels in the U.S. at a price that makes sense yet. Track/S That 3D scan could be clutch for us, more good vibes towards getting it done!
| 02-07-2025, 04:57 PM | #257 | |
4483
Rep 7,316
Posts ![]() |
- Jasper
///Mobbin1548.00 |
| 02-12-2025, 02:21 PM | #258 | |
Tuner
47
Rep 71
Will this setup work with the EC7 18x9.5 +22 wheels? 2nh bracket + 380mm rotors I plan on doing a 265 square with -2.5 degrees of camber on stock suspension with plates. Thanks! |
Expert@ApexWheels4482.50 |
| 02-14-2025, 11:16 AM | #259 | |
4483
Rep 7,316
Posts ![]() |
- Jasper
| 02-14-2025, 11:23 AM | #260 | |
![]() 285
Rep 170
| 02-18-2025, 01:59 PM | #262 | |
4483
Rep 7,316
Posts ![]() |
- Jasper
| 02-23-2025, 05:55 AM | #263 |
Rep 25
Just get the hats from girodisc gonna install everything when i get the caliper and the car back from the shop
iG : StixR_
| Bookmarks |
