02-12-2019, 10:33 PM | #243 |
Rep 1,899
Been reading up on BM3 and preparing to tune my car soon after parts are installed. Is there a way to configure valves closed in comfort mode? I noticed only a valve setting for sport mode in the user manual
02-13-2019, 09:18 AM | #244 |
Rep 1,660
Be aware that the flash will override some of the changes you may have made with other software like BIMMERCODE.
In my case I had to reset the ASD, Folding Mirrors, auto seat adjustment and seat heating values. These were all reset back to OEM when I flashed with BM. Took me a couple of days to realize what had happened. BM worked fine. However, this is something to be aware of. |
Poochie9107.50 |
02-13-2019, 09:53 AM | #245 | |
IG @bmwF9xG80
3817
Rep 7,595
I've been flashing for over 2yrs now this is false !
60-130 6.5s X4M
60-130 5.04s G80 M3 Stock Turbo 60-130 4.82s | 9.4@148mph 1/4 Hybrids IG: @bmwF9XG80 |
02-15-2019, 10:39 PM | #247 |
Rep 932
Coding for that stuff is in other ECUs in the car if you ever used ESYS to code the car yourself. Zero and I mean zero chance bm3 did that as it doesn’t even talk to anything but your engine computer. If anything your battery going low causing that.
FSociety3816.50 |
02-16-2019, 12:55 AM | #248 |
Rep 2,577
There is little hope to ask PTF at this point but M2 OG DCT software needs improvement.
Our problem with Stock DCT is in the comfort mode: When you input mild throttle and the car comfortably climb up to 4th (or 5th/6th) gear, it enters some sort of 'cruise state' as I call it, where DCT is extremely lazy to downshift. You progressively apply pedal, it will just hold at high gear even if it's already 80-90% pedal, until 3-4 secs later it downshifts. In the traffic of downtown big city (think New York), it is dangerous when you're trying to pass and change lane with a tight time window. It's nothing to do with DME tuning, it's purely the DCT logic. All it needs exactly for comfort mode is to increase the eagerness of downshift. Some may argue 'that's why I always use sport mode'. That may work for some guys. But sport is way too aggressive for most of the times on street when cars are not few. Now that ZF8spd already has its TCU albeit it's engineered to address torque limit issue. It proves that TCU is programmable via aftermarket tools, rather than we only rely on BMW pre programmed option (GTS gearbox which doesn't really work well with OG M2). Think about it please PTF.
Lemania 2320
963mw331.00 |
02-17-2019, 03:09 PM | #249 | |
Rep 328
02-18-2019, 07:47 AM | #250 |
Rep 2,577
It has something to do with throttle adaptation. When you commute in the serious downtown traffic (literally average pace = 8mph daily commute in my case). Comfort mode can adapt overtime and become very lazy. To 'recover', either open her up do spirited pulls, or reset adaptation every now and then.
Lemania 2320
M-Supra394.50 |
02-18-2019, 04:27 PM | #251 |
Rep 160
Drives: 2017 M2 6MT/2017 Hyundai Azera
I didn't get the read the whole thread but I was wondering if Launch Control or 2 step is available with the manual M2? Even without it for now, I am enjoying my BM3 E30 tune on my M2.
02-21-2019, 07:40 PM | #252 |
Rep 7,542
Dang this would be a really sweet feature to have.
04-08-2019, 06:12 PM | #253 |
Rep 6,638
Anyone know if the latest iStep upgrade for n55 m2 vehicles also locks the DME so it can longer be flashed by bootmod3? S55 vehicles with the latest update can no longer be flash tuned through obd port.
04-12-2019, 02:24 PM | #254 | |
Rep 244
Hi,
Last Tuesday a shop installed an ~4k miles used HJS 300 Cell Catted Downpipe on my car. While reading codes with the BM3 app, I just saw: Quote:
04-17-2019, 01:31 PM | #255 |
4517
Rep 1,862
Drives: powered by bootmod3
System Update:
bootmod3 update v0.10.065 is out with some great enhancements: 1) DCT Transmission Offline Flash - Flashing the DCT on the S55 is now done like with the DME tunes where data is first downloaded in full and then the DCT flash starts. This removes any dependency on your internet connection quality when flashing the transmission. TCU flashes now significantly faster than before! NOTE: If using mobile apps you'll continue to use the online based TCU flash until you get the latest update. If you use a laptop/web you'll have the new version immediately. 2) DME coding after flash - last fix we did on this resolved it for most cars but some were still needing to recoding using online recode, in most cases just after unlock if at all. This should now be fixed as well. If you have the new DME (MG1) with the B58 engine this does not apply. 3) Agent/dash connectivity - further enhancements with dash auto-reconnect if cable is disconnected/reconnected. Now even minimizing the app and doing something else on your phone (e.g. call comes in, do an iMessage to someone, etc) and coming back into the bm3 app will have the dash still active including logging. A bug that at times caused logs not to get pushed to the server in case agent was powered down or cable was disconnected has also been fixed. bootmod3 web version is updated and the new OBD Agent is out. Apps are in submission and will have the update live as soon as the app stores release them to public.
YouTube Channel [NEW] | Facebook User Group (20,000+ members) | Tech Support Website | Wiki | FAQ | iOS App | Android App | bootmod3 Web
Sales Support Email: sales@protuningfreaks.com | Tech Support Email: support@protuningfreaks.com |
4
04-17-2019, 09:41 PM | #256 | |
Rep 3,715
04-18-2019, 08:36 AM | #257 | ||
Rep 1,899
04-18-2019, 11:03 PM | #258 |
IG @bmwF9xG80
3817
Rep 7,595
I use Google and it works fine
60-130 6.5s X4M
04-19-2019, 03:44 PM | #259 | |
70
Rep 93
04-19-2019, 04:42 PM | #260 |
Rep 699
Another bm3 question.
We have 93 octane here. In the off chance it's slightly less would I be better running the 91 tune? 2'nd question: Assuming my 93 octane is actually 93 octane, does anyone know the hp difference (roughly) between the 91 tune and 93 tune? |
specka71.00 |
04-19-2019, 07:09 PM | #261 | |
Rep 1,899
I believe 2nd question i believe the difference is like 10-20 hp assuming ideal perfect conditions. |
04-23-2019, 10:10 AM | #262 |
Rep 3,715
I had a different password saved between the app browser and Safari. Updated Safari and the password seems to be sticking for the app.
Update: Never mind, the app is still requiring me to log in. Just a pain if you’re driving and want to launch the app. Last edited by ZM2; 04-23-2019 at 10:20 AM.. |
MRosth126.00 |
05-22-2019, 10:10 AM | #263 |
Rep 289
Are there any maps made for track duty? To dial things down a little bit?
I'm getting a little paranoid ringing the car out at the track with my stage 2 map when I'm running shit CA 91 octane. |
05-22-2019, 03:19 PM | #264 |
Rep 1,899
Are you running the ACN91 map? Don't run the OTS 91 maps if you're in Cali. Check mine and Nezil's threads about Cali gas.
