04-12-2021, 02:42 PM | #243 |
Rep 109
Daleb/zm2..
Well you guys were right on! Chris from Dorch increased the targets on my hpfp and all crazy whistling, chirping, etc (under load) .. noises are completely 100 percent gone... Thanks.. she's running super smooth and strong |
04-12-2021, 03:20 PM | #244 |
Rep 266
Was the update just specifically for your car? Or did they update it on bm3 maps as well? Coz ive been getting that chirp too.
04-12-2021, 04:08 PM | #245 |
Rep 109
I think mine specifically.. Chris from Dorch is working on a update now. Should be out real soon.
Apparently those noises are from the fuel rail/system |
04-12-2021, 04:45 PM | #246 | |
Rep 3,867
So weird/highly coincidental that mine went away when the dealer replaced my tension pulley & belt, thinking that was it. Glad it’s fixed! |
04-12-2021, 06:50 PM | #247 | |
Rep 3,867
koastal382.50 |
04-14-2021, 12:11 AM | #249 |
Rep 266
question for you guys:
does the stage 2+ maps really target 12.7 to 12.9 afr at redline? what timing advance is this map targeting does anyone know? i just tried the stage 2+ and the cars a beast! but i fear my e30 mix is not enough for this map. my timing starts breaking up after 6000 rpms. i will add more ethanol and relog. and the throttle closure at tip in is driving me nuts lol but i understand this is a tune issue at this time? https://www.bootmod3.net/log?id=6076...729b7c58178ae7 https://www.bootmod3.net/log?id=6076...0b43554c3a6d07 |
04-14-2021, 12:17 AM | #250 | |
Rep 3,867
04-14-2021, 12:23 AM | #251 |
Rep 266
04-14-2021, 02:50 AM | #252 | |
Rep 415
Ideally the stock turbo guys would need their own map with boost targets tapering off a few psi to redline from 6000 imo, but again i doubt that would translate to quicker car. Just a cleaner log. |
04-14-2021, 03:37 AM | #253 |
Rep 668
04-14-2021, 11:10 AM | #254 | |
Rep 266
04-14-2021, 11:54 PM | #255 |
Rep 266
yup more ethanol did the trick. cleaned up the logs real nice. i threw in about 3 ounces of boostane for good measure lol
https://www.bootmod3.net/log?id=6077...729b05a6a058d3 thanks for your input daleb and zm2 i had a friend clock my 100-200 and it was 8.8 ( shifting around 6k rpms), presumably could be better or worse coz of my friends response time lol. i have to get a dragy to get an official one and i will share it here Last edited by Dj_Quik; 05-23-2021 at 03:53 AM.. |
04-15-2021, 04:20 AM | #256 | |
Rep 2,578
I am on STG2 turbo running at 18psi of peak boost on 98RON/93AKI pump gas (430whp on dynojet) and get low to flat 8s in winter and middle 8s in summer. I think the monstrous mid range torque with these ethanol map helps a bit punching above its weight class.
Lemania 2320
04-15-2021, 05:40 AM | #257 | |
Rep 415
The n55 definitely loves cool ambients and the closer to zero degrees celsius it gets the quicker our cars go. Based on my 7.9 100-200 id expect a few more tenths off in near 0 condition in a best case scenario. |
04-15-2021, 09:30 AM | #258 | |
Rep 266
definitely punches way above its weight class. there was a 100-200 list by a youtube channel called autotopnl and the time i got is on par with a lambo urus, 718 GT4 and tuned rs3 among others lol so im very happy with the setup right now! |
04-15-2021, 09:31 AM | #259 |
Rep 266
[QUOTE=Daleb;27474967]I think the midrange helps massively with the on road performance and times.
The n55 definitely loves cool ambients and the closer to zero degrees celsius it gets the quicker our cars go. Based on my 7.9 100-200 id expect a few more tenths off in near 0 condition in a best case scenario.[/QUOTE i cant imagine how sub 8 seconds would feel like!! |
04-15-2021, 11:15 AM | #260 | |
Rep 3,867
04-15-2021, 12:57 PM | #261 | |
Rep 415
It feels good, doesn't overpower the chassis either. The maps capable, lets see what your car does when you get a dragy.
Got some 18" protrack wheels coming so I'm interested to see if the smaller rolling radius will reduce times at all. Not the reason for getting them but it would be nice if it does. |
ZM23018.50 |
04-16-2021, 01:52 PM | #262 | |
Rep 3,867
In the meantime, every time I finish a drive I think, “Man, what an f’ing great car!” |
