M2 Technical Topics >
Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics >
Bimmercode topics
| 02-16-2023, 01:16 AM | #2597 | |
![]() ![]() 1603
Rep 8,972
Easy to set on bimmercode to either default OFF or remember last setting. If you keep Bimmercode in normal mode (not expertmode) then it's all laid out clearly and you won't do any harm. Just be aware when coding modules they are reset afterwards so you lose settings in that module, i.e all your radio presets, the clock, shortcut buttons, M buttons presets etc. So just be prepared for that depending on which module the setting you changed is in. Go on bimmercode website and get an adaptor they recomrnend id say is best way to be sure. I bought this one 5 years ago but it seems to have doubled in price since then. https://www.amazon.co.uk/gp/aw/d/B00...b_b_asin_title If you Google "bmw f20 coding cheat sheet" you'll find lots of other 2 series F platform settings you can change (some applicable some not) M2C is F87 but its built around basic 2 series F20 electronics platform Last edited by doughboy; 02-16-2023 at 02:48 AM.. |
Stevieno11.50 |
| 04-07-2023, 06:44 AM | #2598 | |
![]() 49
Rep 83
Thanks |
| 04-08-2023, 02:48 AM | #2599 |
![]() ![]() 1603
Rep 8,972
I had to use esys to recode the module after Bimmercode messed it up using the disable ASD option.
I don't know any other way but im sure others do. |
| 04-13-2023, 04:56 PM | #2600 |
Rep 200
Drives: 2017 BMW M2
You may still want to hear it for yourself, but FWIW I toggled it on and off repeatedly while driving and could BARELY tell the difference. Its so subtle I truly dont understand why BMW bothered adding complexity to the car (extra harness, etc) just for the "feature". It does almost nothing...
| 08-06-2023, 06:03 PM | #2602 |
Rep 4,196
I turned on full screen Carplay and its so much better with the new functionality that is now there. But, am imagining that there is some color shifting going on with the screen depending on the album art displayed while playing music? All other apps are normal.
| 09-27-2023, 06:12 PM | #2603 |
Rep 21
Drives: 2019 M2 Competition; 2019 X3 M
So I want something to read all the “ECU’s” for the purposes of determining the history of the car, trouble shooting, etc…. Is bimmercode the best way to go?
Thx! |
| 10-07-2023, 11:38 AM | #2604 |
![]() 338
Rep 175
Drives: BMW M2 Competition
I just picked up a 2021 CPO and they said that it would be flashed with the latest software as part of their certification process. Just confirming that the latest version of Bimmercode will still work. I'm most interested in the full screen CarPlay, folding mirrors and configuring some of the lighting settings. Thank you for any help.
| 05-24-2024, 03:19 PM | #2605 |
![]() ![]() 135
Rep 303
does anyone know in expert mode how to access puddle lights? trying to make sure they come on immediately while unlocking the car (not just when the car door is open)
| 08-25-2025, 10:08 AM | #2606 |
HALA MADRID!
1051
Rep 2,909
Hi all,
could use some help with adjusting my angel eyes brightness... here is the situation: I coded my car's angel eyes brightness late 2020 (I have a 2019 M2C), and all was perfect. A month ago, my car got hit in a hit-n-run at the airport, and went into the shop for repairs, where they replaced the front bumper and the driver's side headlight unit. I got my car back today, and the brightness on the new headlight unit's angel eyes was not the same as the passenger side (which was the original)... it was whiter and less bright, whereas the passenger side original one still had the new brightness settings I had originally coded it. I connected the bimmer app via the BT module I've always used, and tried to recode it, and nothing. I tried reducing the coding, and still nothing. I increased the brightness, and nothing. I checked both sides in regular mode, and both sides show 100% brightness. I don't recall going into expert mode, but again, nothing seems to work. I could use some help here.
![]() F87 M2 Competition, Sunset Orange, Exc, DCT. **SOLD** F80 M3 Mineral Grey/Sakir Orange, Exc, DCT... ED 6/2015 **SOLD**E90 M3, Interlagos Blue / M individual two-tone, ZCP, ZP2, ZCV, DCT, ED. |
| 08-25-2025, 01:13 PM | #2607 |
![]() ![]() ![]() 885
Rep 643
Drives: '21 M2C, '20 G05 X5, '17 X3
What conditions must be met to turn off iDrive when driver door is opened? Is it really as simple as opening the door with the engine off? Does seat belt matter? Comfort access seat position implications?
I have coded numerous times and it still doesn’t want to remain active. It shows active when I open and connect BimmerCode, but it has only actually worked a couple of times. Similarly, the comfort access seat positioning seems to be hit or miss as well. Sometimes it fails to move to driving position, but I can press the “1” preset button on the side of the seat and it advances to my set position. No big deal either way…just curious mostly. |
| 08-25-2025, 09:57 PM | #2608 | |
![]() ![]() ![]() ![]() 601
Rep 667
For comfort access: I have MT (which requires depressing clutch to crank engine) … so not sure if there’s a difference vs DCT But I have the same hit or miss issue, but think I have it narrowed down to where the seat doesn’t move from comfort access to setting 1 position when you get into the car, unless the driver’s door is shut prior to hitting the on/off button to either turn car on or crank engine. Note I don’t drive my car nearly often enough, so I havent’ been able to fully remember nor pinpoint if there’s specific parameters, but the door being closed seems to maybe be one of them? But there’s definitely hit or miss scenarios where sometimes the seat will move back to the comfort access position when I first open the driver’s door and get in (from the outside), and other times it’s already in the comfort access position when I open the door from the outside. I’m wondering if that’s maybe related to something like if i opened the door prior to shutting down the car the previous time? |
SirPsychoMD885.00 |
| 08-26-2025, 08:04 AM | #2609 | |
HALA MADRID!
1051
Rep 2,909
I tried restoring both units back to the original backup, and then recoded the angel eyes, and nothing ![]() ![]() it's like they are stuck in this mode and the coding from Bimmercode does nothing, eventhough I hear the ECU restarting, the fault codes being cleared, etc, but still nothing.
| 08-26-2025, 10:55 PM | #2610 | |
![]() 4577
Rep 3,729
Drives: 2026 iX xDrive60, 2024 718 GTS
You mentioned it went into "the shop," was it a BMW dealer or a random mechanic? They could have gotten parts from perhaps just a third-party or another model that have different LEDs/brightnesses than the factory part. You might want to check the actual modules. They're just held in with screws in the end bays near the front by the bumper, 2 per side, 3 screws per module. |
| 08-27-2025, 07:43 AM | #2611 | |
HALA MADRID!
1051
Rep 2,909
I'll check the modules to make sure they are not loose or something.
| 08-27-2025, 08:54 AM | #2612 | |
![]() 4577
Rep 3,729
AFAIK the headlight unit is a separate part than the DRLs. I would just go back to whoever you took it to and tell them it's not right. |
| 08-29-2025, 11:59 PM | #2613 | |
![]() 325
Rep 255
Drives: 1 BMW (at a time)
It seems unlikely but if the setting is 'bottoming out' because the new light can't be dimmed (much) further, it may prevent either light from being adjusted. Just a theory. |
| Bookmarks |
