M2 Technical Topics > Track / Autocross / Dragstrip > Custom 2NH Bracket (for fitting 18”)
      01-05-2025, 03:45 AM   #199
E93M3MW
Drives: E93 M3
Originally Posted by Track/S View Post
I'll have to do some testing, I have a friend who has those tires, I'll ask him for one to try
Thank you, much appreciated.
      01-06-2025, 09:01 PM   #200
D_SheerDrivingPleasure
D_SheerDrivingPleasure's Avatar
1793
Drives: Very Fast F80 & G80
Is there any coding needed when upgrading from the little blue boys to the big red 2NH calipers?
Dare I squeeze three at yo' cherry M3
      01-07-2025, 04:46 AM   #201
Track/S
Track/S's Avatar
3279
Drives: M2C, M4 GTS
When I mounted the 2NH on my ex M2 OG I saw no need to code
M2 Competition 6MT: MCS 3way, Full Kinematics, Custom LSD diff, Lift Kit, CF Propshaft, 513M 18x10.5 ET46 Square, CF Recaro's Pole Position, ST2 Hybrid Turbos, Keyed Crank Hub, CCB, Ti Pistons, 1465kg with half of fuel tank,
600hp/800nm.
      01-07-2025, 01:23 PM   #202
1793
Are you or others experiencing any pad knockback? How thin are you running your pads?
Wondering if I should proactively install AKB springs.
      01-07-2025, 01:38 PM   #203
Track/S
Track/S's Avatar
3279
Drives: M2C, M4 GTS
I haven't tracked with those calipers, but if you can get the springs I would put them in.
600hp/800nm.
      01-08-2025, 01:02 PM   #204
Mahduece
Mahduece's Avatar
560
Drives: M2C
Can anyone tell me what calipers I have?
I’ve read that the blue ones are smaller and not the 2nh, but i have the blue and it appears to be 6 pot front and 4 pot rear. Appreciate the help!
*sorry for the dirty and blurry pic…winter wheels and it’s freezing.
      01-08-2025, 11:58 PM   #205
Track/S
Track/S's Avatar
3279
Drives: M2C, M4 GTS
Wow how curious, The blue ones are from m5/m6
600hp/800nm.
      01-09-2025, 09:04 AM   #206
Mahduece
Mahduece's Avatar
560
Drives: M2C
Hmm very interesting.
      01-09-2025, 01:47 PM   #207
Track/S
Track/S's Avatar
3279
Drives: M2C, M4 GTS
Can you upload a pic of the side where the 2 calipers can be seen?
600hp/800nm.
      01-09-2025, 04:40 PM   #208
Mahduece
Mahduece's Avatar
560
Drives: M2C
Stuck my arm behind the wheels and snapped these horrible pics, front and rear….
Track/S3278.50
      01-10-2025, 10:55 AM   #209
Westersund
Westersund's Avatar
1049
Drives: BMW
The M5/M6 calipers are the same casting as the 2NH but 5 mm have been milled off of the mounting surface, you can use the 2NH adapters along with a 5 mm spacers if you want to run the 400 mm 2NH discs. There was a thread on here made buy a guy in the UK that figured that out.
https://f87.bimmerpost.com/forums/sh....php?t=2107205
This is the only account I have on Bimmerpost, I will never post my e-mail publicly. If you want to contact me send a PM or you can find me on Instagram: @andre_westersund or @westersund_motorsport
BMW M2 LCI -18 | BMW 520DA Touring M-Sport -12 | BMW Z4 M Coupe -06 | BMW 330i -05 | BMW M3 -02 | BMW Z3 Coupe -99 | BMW 740i/6 -96 | BMW M5 3.8 -92 | BMW M535i -87
      01-10-2025, 12:59 PM   #210
Track/S
Track/S's Avatar
3279
Drives: M2C, M4 GTS
I knew this before this thread existed, the thing is that the calipers shown above are from m2c and for m2c they did not exist in blue color.
600hp/800nm.
      01-10-2025, 02:37 PM   #211
Westersund
Westersund's Avatar
1049
Drives: BMW
That's not what you said though, you said the blue ones are from M5/M6. Didn't mention anything about these particular calipers being from a M2C.
These particular calipers are probably re-painted.
      01-10-2025, 04:13 PM   #212
Track/S
Track/S's Avatar
3279
Drives: M2C, M4 GTS
I meant that the blue ones were mounted on the M5/M6, they don't look like they were repainted, it's difficult to leave that finish so good.
600hp/800nm.
      01-10-2025, 04:26 PM   #213
Mahduece
Mahduece's Avatar
560
Drives: M2C
To my knowledge the calipers are not re-painted.
      01-12-2025, 10:23 AM   #214
Maynard
Drives: 228iX & M2C
Not to hijack the 'what calipers are these?' but...
If the M5/6 has same caliprs with 5mm less pad, would those work to allow smaller rotor/wheels (or at least smaller rotor and more wheel clearance on 19s)?
      01-12-2025, 10:26 AM   #215
Track/S
Track/S's Avatar
3279
Drives: M2C, M4 GTS
Yes, they are suitable for 390x36mm discs, which nobody else makes
600hp/800nm.
Maynard5564.00
      01-12-2025, 11:38 AM   #216
Maynard
Drives: 228iX & M2C
Is that the M5/6 rotor size?
      01-12-2025, 01:59 PM   #217
Track/S
Track/S's Avatar
3279
Drives: M2C, M4 GTS
Not, 400mm
600hp/800nm.
      01-13-2025, 01:38 PM   #218
///Mobbin
///Mobbin's Avatar
1548
Drives: m3
Just catching up on this thread and wow, awesome what all has gone into this! Thanks to those who have contributed to the knowledge. Very interested in fitting 18's and running giro-disc replacement rotors as well. Win-win.
ApexWheels any chance the newer APEX ML-10RT's would fit? My preferred option would be 18x10.5 square but 18x10/18x11 staggered could also work for me.
2020 M2 Competition | 3.0L | DCT
      01-13-2025, 01:47 PM   #219
Track/S
Track/S's Avatar
3279
Drives: M2C, M4 GTS
A friend of mine bought Girodisc for G8X by mistake and now I have to make him hats for F8X
600hp/800nm.
      01-13-2025, 01:54 PM   #220
///Mobbin
///Mobbin's Avatar
1548
Drives: m3
295/30 with 30mm of spacer
Curious if there is a certain amount of camber required to fit the 295/30?
I'll soon be running the Tractive Touring suspension with OE-type springs and Millway Motorsport Street camber plates. Was planning -2 to -2.3 up front as this is a dual purpose car.
