M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > Rear tail light failure
      09-06-2023, 02:12 AM   #199
doughboy
doughboy's Avatar
1602
Drives: 2007 E85 Z4M Roadster
REM is rear electronic module.
It's a control module sitting on the vehicle control bus and controls power and monitoring on all sorts of stuff at the rear of the car including all tail lights.
      09-06-2023, 02:26 PM   #200
c0riolis
Drives: 2018 M2 DCT
Originally Posted by chmura View Post
Do you happen to have a part number?
61359499001 / https://www.realoem.com/bmw/enUS/sho...diagId=61_2802
      09-06-2023, 03:16 PM   #201
doughboy
doughboy's Avatar
1602
Originally Posted by c0riolis View Post
And it needs coding etc to suit your vehicle..
      09-12-2023, 09:35 PM   #202
Itr123
Itr123's Avatar
Drives: Bmw m235i
I've ordered a new light from the dealers to replace the fault one.
Fingers crossed I don't this fault on a new one
      09-27-2023, 12:30 PM   #203
Rk-d
Rk-d's Avatar
625
Drives: GT3 Touring, 993 C4S, M2C
Whats a REM module? Do you happen to have a part number?
I see others have answered this question. I'm not sure on particulars, the dealership changed this out as part of their warranty algorithm. I sold the car on Monday, the problem never came back so as far as I'm concerned this was a permanent fix.
I'm not claiming this is necessarily the solution for everyone, but it was for me.
      12-20-2023, 05:33 PM   #204
BeMyWheels
Drives: F22
Sorry to bump a old thread
But thought I’d share my point on it
As someone who’s spent enough time with multiple F22s
Pre and post LCI
Pre lci replaced the board and as it was from bmw it did come with the extra ground. I am yet to wire that in …
Post LCI drilled 4 holes along the bottom of the tailight
Drained out no joke 200ml at least
Let it dry and refitted
Holes left open as where I have drilled them I can’t see water filling anything from there
      12-21-2023, 12:39 AM   #205
doughboy
doughboy's Avatar
1602
There wasn't any water at all in my LCI failed lights. I broke them open when i replaced with new darkline versions.
But that's not to say some do leak
chris7197788.00
///M TOWN35366.50
      02-09-2024, 09:54 AM   #206
chmura
chmura's Avatar
1585
Drives: 2019 M2 Competition
Can you code this with bimmerlink yourserlf?
2011 BMW M3 Sedan Alpine White
Picked up via ED 9/27/2011 & Redelivered 11/23/2011 **SOLD**
      02-09-2024, 10:42 AM   #207
Enabled
Drives: 328xd Wagon, M2 Competition
No, bimmerlink doesn't really do full factory coding, but rather it reads and changes existing coding. It would require E-Sys (no token or loaders, just plain E-Sys) or dealer ISTA etc. to do initial coding.
-2019 M2 Competition MT, Alpine White. Self-tuned 560hp
-2016 Mini Cooper S, MT. Many plans.
Others:
-E36 328is. 2000 Z3 Roady. 2003 VW Jetta TDI Manual. Estoril Z3M Coupe.
      02-09-2024, 12:09 PM   #208
chmura
chmura's Avatar
1585
Thanks I have ISTA but havent used it in a while.
      02-09-2024, 03:34 PM   #209
Enabled
If you have a Windows laptop + ENET cable, I can code your REM remotely in minutes. I wouldn't suggest ISTA as the go-to for coding, especially if it decides it wants to flash update everything. It can get risky then.
Others:
///M TOWN35366.50
      02-15-2024, 08:47 PM   #210
Eddy’s Garage
Drives: M2 LCI
I had the tail light error on my OG LCI and coded it out. Hopefully it works for you if it is a coding issue and not a mechanical one. Here is a video I did on the coding. If you like it give it a thumbs up and subscribe because I have heaps of M2 content coming.
      02-15-2024, 09:44 PM   #211
chris719
Drives: '08 M Roadster
It will buy you time, and possibly a lot of it, but it will eventually fail.
      02-16-2024, 12:26 AM   #212
doughboy
doughboy's Avatar
1602
Nice video. My comp that setting was already active. Unassigned in bimmercode doesn't mean OFF it means it's a value that bimmercode can't read.
The other coding advice on here is to disable the check feature, which of course is bad.
Did you actually look at your turrn signal when the failure was happening?
      02-16-2024, 11:16 AM   #213
AlpsRider
AlpsRider's Avatar
2888
I have checked my turn signal when the hyper flash was happening. The taillight was still flashing. I coded it out, no more hyperflashing. It was the same coding I did to my M235i when I upgraded to LED bulbs.
It wasn't that long ago when cars didn't have any bulb check.
      02-19-2024, 12:11 AM   #214
Eddy’s Garage
Drives: M2 LCI
Several people have contacted me saying that BMW will replace the light even though it is out of warranty. I have booked it in next week to see what they say after they take a minimum 1 hour $300AUD diagnostic fee. The stealership lives up to its name. Does anybody have the SIB from BMW with the repair and extended warranty details?
      02-19-2024, 12:50 AM   #215
doughboy
doughboy's Avatar
1602
Surely you can just buy a tail light for 300aud?
      02-28-2024, 09:46 PM   #216
Eddy’s Garage
Drives: M2 LCI
Dealer just quoted me $625AUD a side. ouch
Im still looking for the SIB on the issue but nobody seem s to know about it.
      02-28-2024, 11:23 PM   #217
bruiser135msport
Drives: Bmw M2 CS & Bmw E21 320i
BMW Warranty or Not
Hi
First of all what year is your vehicle and how far out of warranty is it ?
You realise that the new Australian Consumer Law does cover items out of Warranty (depending on value and age ) .
Cheers
Bruce
      02-29-2024, 01:34 PM   #218
doughboy
doughboy's Avatar
1602
Why buy from a rob dog dealer? Have you looked online? I got mine from ebay, brand new in sealed bmw boxes £200 each. Bmw UK want around £350 for one.
AUD to GBP is roughly double now so your dealer price is about right.
On uk ebay now there's a brand new one, still wrapped for £120
chris7197788.00
      04-11-2024, 11:09 PM   #219
Eddy’s Garage
Drives: M2 LCI
Originally Posted by bruiser135msport View Post
Hi
Cheers
Bruce
I work in product warranties and my car is a 2017 LCI so no longer covered.
      04-12-2024, 11:57 PM   #220
asiflicious
asiflicious's Avatar
Drives: 2017 540i
2018 BMW M2  [10.00]
Mine does it sometimes too but always goes away after a restart 🤷🏻‍♂️
