04-01-2022, 10:06 AM | #199 |
Rep 927
08-24-2022, 11:24 AM | #200 |
Rep 177
glad I remembered this thread, took a break from tracking to focus on business but am about to start back up. Sadly I got F*&ked over by someone advertising a 3d printed kit from Europe on the Facebook M2 pages and they haven't owned up to never shipping it etc etc.
Looks like thanks to the nice OP and others I'll get my friend to 3d print some parts and make my own kit instead of doing this one https://burkhart-engineering.com/en/...or-m2-f87-bmw/
2018 M2- Alpine White 6spd
some two wheeled fun and a tow rig |
08-25-2022, 10:31 AM | #201 | |
Rep 4,733
09-06-2022, 03:12 PM | #202 | |
Rep 1
12-09-2022, 07:14 AM | #203 |
Rep 927
12-09-2022, 09:21 AM | #204 | |
Rep 2,516
03-03-2023, 07:26 AM | #205 |
Rep 2,516
I am the OP and I thought I’d give you an update on my setup. I’ve upgraded my rears to AP 9449s to compliment the front AP 9660s. I was intrigued by this rear brake duct package that I purchased through Burkhart Engineering. Thought it would be a bit more efficient than the Porsche ducts. The finish of the carbon fiber is incredible. Shame no one will see them! I’ve since opened up the backing plates a bit more for better air flow. https://burkhart-engineering.com/en/...d-engineering/
03-03-2023, 03:31 PM | #206 | |
Rep 7,543
DrKevM52281.00 |
03-03-2023, 06:18 PM | #207 | |
Rep 2,516
03-03-2023, 06:22 PM | #208 | |
Rep 7,543
So far I have seen one good brake ducting kit, and it is made by Westersund https://f87.bimmerpost.com/forums/sh....php?t=1895176 This kit actual aims the air right into the hat.
DrKevM52281.00 Westersund511.00 |
03-04-2023, 10:14 AM | #209 | |
Rep 882
I just built a new computer to be able to 3D-scan the uprights to design a new backing plate and make them out of carbon instead. Will try to implement most of the ideas some of you have contributed with. Will buy a 3D-scanner this month as the new 3D-printer will arrive this month as well. Will be a busy spring...
BMW M2 LCI -18 | BMW 520DA Touring M-Sport -12
| BMW Z4 M Coupe -06 | BMW M3 -02 | BMW Z3 Coupe -99 | BMW 740i/6 -96 | BMW M5 3.8 -92 | BMW M535i -87 |
03-04-2023, 10:25 AM | #210 | |
Rep 4,733
Is there any improvement from removing the backing plate for track days. Seems like that would allow more heat to radiate out from disc. I'm looking for a system that I swap on for track days when swapping pads, and then remove when swapping back to street pads. |
03-04-2023, 09:15 PM | #211 | |
Rep 882
As far as cooling the brakes, removing the backing plates will help cool the brakes as the heat won't be contained in the discs as much. But that heat has to go somewhere and will radiate inward and to some extent it might shorten the lifespan of the boots covering the joints. In a race car that's not an issue due to the use of uniballs. Personally I haven't had any issues with the boots as the closest boot (steering knuckle) is covered by the backing plate.
03-05-2023, 07:58 AM | #212 | |
Rep 557
I'm just about the replace the rear rotors but not sure if it's worth removing the rear dust shields?? Anyone removed the rear shields and can offer for/against? The rear rotors are completely free of crazing/cracks, just worn to min thickness and 1 set of rear Pagid 29's lasted 2 sets of fronts (I go DSC OFF). I go MDM on mountain drives (oem pads) and since doing the front shield/GT3 scoop mod have not had any fade issues. |
03-05-2023, 09:51 AM | #213 | |
Rep 4,733
Westersund511.00 |
03-07-2023, 02:54 AM | #214 |
Rep 882
I will be making an effert this spring to get everything finished.
F87source7368.50 |
03-07-2023, 02:57 AM | #215 | |
Rep 882
06-08-2023, 12:06 PM | #216 |
Rep 269
I got something I’m working on and wanted to share a teaser
Take a guess as to where the air is being fed in from… Should be wrapped up today or tomorrow at the latest. Just need to size the hose accordingly and tidy it up in the wheel well. |
