12-01-2016, 08:43 PM | #199 |
2012
Rep 6,916
Eventuri Carbon Fiber Engine Cover for the BMW M2 F87
I picked this up from the team at IND not sure if it's on the site yet but I believe they have them in stock. Everyone can use more carbon fiber..... Items that you will need - BMW Logo - part # 11 14 7 788 967 (this is not the same part number on our BMW M2 Engine cover) You will also need to pull the rubber grommets (total 3) out of the oem engine cover and put them into the carbon fiber cover as well as the insulation. Pics below. Since I'm a bit ocd I went ahead and used the Rupes Ibrid Short Neck with the Rupes Yellow Pad and Jeffscar Micro Finishing Polish (coming soon) to remove some of the hazing left behind from possibly the wetsanding and compounding after the clear coat was sprayed. I went ahead and polished it out to remove the haze and bring out the shine. Following it with 2 layers of Nanolex SI3D HD ; ) Haze on the CF Engine Cover Polishing the haze out I opted to remove the Eventuri decal..... Probably should have removed them first before polishing BMW Roundel Emblem Used Nanolex EX to prep the CF Engine Cover for Nanolex SI3D HD A nice thick coat of Nanolex SI3D HD goes on After Swapping out the grommets and insulation from the OEM Engine Cover OEM Engine Cover Back of Engine Cover with Rubber Grommets and Insulation Pulling out the insulation from OEM Cover Back of the CF Cover Installed rubber grommets Without insulation Before with OEM Engine Cover Eventuri Carbon Fiber Engine Cover Last edited by Detailers Domain; 12-01-2016 at 09:08 PM.. |
Robban267.00 |
12-03-2016, 09:12 PM | #200 |
2012
Rep 6,916
today I removing the rubber nib, removing knobs, removing hair off your tires
used one of the razor blades that we use for clear film installation to clip them off, some use nail clipper or box cutters all good. a nice clean look. something so small and such a big impact ; ) |
12-08-2016, 08:03 AM | #202 |
2012
Rep 6,916
12-09-2016, 09:04 AM | #204 |
Rep 289
Drives: '18 M2 MG 6MT, '03 E39
All that carbon fiber in the engine bay looks awesome!
Current Car | 2018 ///M2 MG 6MT
Previous Car | 2003 E39 530i Sport |
12-10-2016, 09:34 AM | #205 |
2012
Rep 6,916
12-10-2016, 06:59 PM | #206 |
2012
Rep 6,916
and so the guys at Rogue Engineering just informed me that my brakes are in ; )
Product Description: (F) 6-Piston Monobloc Calipers | 380x34mm (15') 2-Piece Discs | Type 3 | Color: Yellow Part number: 1N3.9045A5 (R) 4-Piston Monobloc Calipers | 380x28mm (15') 2-Piece Discs | Type 3 | Color: Yellow Part number: 2P3.9044A5 Can't wait to get these on the car |
12-10-2016, 07:21 PM | #207 |
Living the aloha
241
Rep 449
I've never seen a car shaved down below before.
Detailers Domain2011.50 |
12-12-2016, 04:35 PM | #209 | |
Rep 218
12-13-2016, 09:00 PM | #210 |
2012
Rep 6,916
Updated
Ready to get them on Removal of stock Installed Front and Rear Afters Last edited by Detailers Domain; 12-15-2016 at 02:43 PM.. |
12-14-2016, 11:05 PM | #211 |
Resident Engineer
136
Rep 748
That BBK is: ohhhhhh myyyyy.
///M4 (SO/BLK/BLK) Exec, LED, Blk 19s, HK, 6MT <- SOLD
///M2 (LBB), Exec, 6MT <- SOLD 2014 Land Cruiser, Slee Sliders, OME Lift, ARB Onboard Air European Delivery Journal & F8X Door Rattle Fix Machine Shop Directory - www.mfgcenter.com |
12-15-2016, 02:46 PM | #213 |
2012
Rep 6,916
More shots of the Brembos on the car
automotiveaperture92.50 |
12-15-2016, 02:48 PM | #214 |
Rep 248
Looks so good, the color combo is awesome build!
12-15-2016, 09:39 PM | #216 | |
Rep 1,345
12-15-2016, 09:49 PM | #217 |
Rep 96
Beautiful. Nicely done. Everything is on point and you spared no detail. Love it
Question please - where do you have the m perf coilovers set at in terms of height? It appears to be at the lowest setting front and rear, true? Did u have to worry about adjustments to get the perfect corner balance or did u just set them at their lowest position and left it there? I am in process of installing and curious where to set the height. I love how your car looks so would love your advice. Thanks for sharing this build with pics and details! |
12-15-2016, 10:08 PM | #219 | |
2012
Rep 6,916
Rears = $3,795.00 --------------------- $8390 Total no where near the ceramics, which I was tossing around with the idea. |
12-15-2016, 10:11 PM | #220 | |
2012
Rep 6,916
lowest setting plus, to get the look we wanted we did not install the rear adjusters, yes I know crazy but it was put in and it was just as high as the stock set up. the front was the pretty close to the lowest setting, everything else was set to what bmw stated in the manual. pm or email if you have more questions. |
Tags |
bbs fir, bmw m2, detailersdomain, nanolex, xpel |
