10-20-2021, 04:31 PM | #1 |
Rep 1,243
Drives: 2017 Big Turbo BMW M2
Wheel Recenter Issue
I was informed by my shop that "after putting the wheels on and getting alignment at slower speeds it feels a little funky in the steering. Nothing crazy but just as a precaution I reset all the steering angles and everything. It should get better once you put some miles on it, just lmk what you think when you get back in the car".
I been away at college, but my dad picked up the car this morning and he stated that when driving, the steering wheel took longer to recenter and needed to be manually turned back to straight now. I am running stickier tires (Michelin Pilot Super Sports) but dropped down to 245/265 (oem spec). The wheels are also, M2 specs: Vorsteiner V-FF 108 carbon graphite 19" (front) 19x9.5, 22 offset, (rear) 19x10.5, 34 offset. As well, I just had a alignment done after the wheels were put on. I'm not sure why this is happening but if anyone knows why this is please let me know so I can have the shop fix the issue ! Thanks, Shane |
10-20-2021, 04:46 PM | #2 |
Rep 842
Have had this happen on the stock Competition setup. Occasionally, returning to center is met with slight resistance and requires some "manual" input rather than just returning to center on its own. I'm at about 5k miles now and haven't experienced this much, if at all. It has, more or less, smoothed itself out over time but I'll still occasionally experience it but to much lesser of a degree (*almost* unnoticeable).
I chalked it up to newer tires needing to be worn in a little and I expect the same thing to happen once I put on some new rubber. Can't confirm until it actually happens though. |
shaneguags1197.50 |
10-20-2021, 04:51 PM | #3 | |
Rep 1,243
10-23-2021, 09:05 PM | #4 |
Rep 1,243
update : steering is still stiff and I'm starting to think it's a spring issue. my shop thinks a spring binding is it coming from the left or right. not sure if this sounds right
