08-08-2019, 02:41 PM | #1 |
3893
Rep 54,605
Drives: F80 M3
Brembo Premium Ceramic Pads
Specifically designed for the North American market, this Brembo formulated friction material with premium shim offers comfortable, quiet, smooth braking and cleaner wheels.
Designed and engineered to enhance braking power, Brembo Ceramic Brake Pads minimize braking distances while offering a quiet and safe braking experience on a variety of road conditions. Original Equipment Direct Moulding Pressing Process provides a proper and accurate fit. The positive molding process uses extreme pressure to compress friction materials and provide balanced bonding to the backing plate. Each pad is then thermal scorched following Brembo's O.E. specifications to lessen running-in and fading. Brembo's multi-layer ESE (Elastomer - Steel - Elastomer) red shim, clearly identifying the pads as Brembo pads, dampens noise and minimizes vibrations. Additional noise dampening is handled by the backing plate which also acts as a heat shield to reduce heat transfer to the caliper. Developed for a wide range of applications, including premium imports and domestic models, Brembo Ceramic Brake Pads offer the performance, dust reductions, comfort, reliability and longevity drivers demand. Vehicle Fitment: F2X F3x F8X with BMW Sport Blue Calipers. ***NOT for M2C*** Order here: https://hpautosport.com/product/brem...port-calipers/ Last edited by HP Autosport; 07-13-2023 at 08:12 PM.. |
11-07-2019, 04:29 PM | #5 |
3893
Rep 54,605
Drives: F80 M3
aguy7.50 Killed by Death13210.50 |
11-17-2019, 10:15 PM | #7 |
Rep 176
11-18-2019, 12:50 PM | #8 |
3893
Rep 54,605
Drives: F80 M3
08-18-2020, 10:45 AM | #16 |
3893
Rep 54,605
Drives: F80 M3
No, not yet. The aftermarket is very slow to catch up, especially right now.
Here is a good alternative. Slightly higher dust but also better performance for street driving: https://www.hpashop.com/Porterfield-...ld-R4S-M2C.htm |
