07-18-2017, 10:24 AM | #1 |
Rep 112
M2 PE Exhaust Rattle
Loud rattle on start up. Stops once driving. Looking under the car, the exhaust is hitting the cross frame support. Is this normal or is there a way to adjust the performance exhaust to sit higher in the tunnel?
Thanks
2017 BMW M2 PE MT
2006 Z06 2004 Miata |
07-18-2017, 11:01 AM | #4 | |
Rep 492
Unwanted rattling and particularly resonance will be increased the closer the pipe is to the support brace. |
07-18-2017, 11:17 AM | #6 |
Rep 112
Does anyone have a link to installation instructions? Mine came installed from BMW. I would like to just fix it myself.
2017 BMW M2 PE MT
07-18-2017, 01:33 PM | #7 | |
Rep 295
This will also pull the tips in a bit more out back. |
07-20-2017, 01:04 PM | #9 |
Rep 379
To sum things up, it seems the port MPE installs in Baltimore are the source of the issue - OEM exhaust being cut too short. I had the same issue, so did a couple other people I know. After my fourth trip to the dealership to get this resolved, and a couple new clamps later. I ended up just going to RRT Racing and having the weld it. Issue resolved!
DoggieHowser210.50 |
07-20-2017, 01:04 PM | #10 |
Rep 379
07-20-2017, 07:43 PM | #11 |
Rep 112
Thanks Joey I tried fixing in my driveway. No go. I will put it up on a rack tomorrow. Does your whole exhaust move up and down? Floating????
2017 BMW M2 PE MT
07-21-2017, 08:40 AM | #12 |
Rep 379
Yes, even with the weld the exhaust has a light feeling, if you grab it near the bracket that is. The rear around the muffler and tips feels solid.
07-21-2017, 02:03 PM | #13 |
Rep 112
MPE Exhaust
Agreed. I will get it on a lift sat or sunday and see what I can adjust.....
2017 BMW M2 PE MT
07-21-2017, 03:47 PM | #14 |
Rep 61
Do all of you guys experience the drone around 3K rpms? I got the clamp welded in as well but the drone is always there... trying to find a way to get rid of it (or at least get the drone to be quieter)
07-21-2017, 05:58 PM | #15 | |
Rep 492
It will never go nor fade, you just get used to it and it's only across such a small rev range that honestly, after a few thousand miles you will think it's disappeared! Sounds soooooo good though - especially with a down pipe! |
07-23-2017, 11:42 AM | #16 |
Rep 112
Ok got up on a lift and pushed the pipes together. Exhaust sits where it should now and feels more secure. Thanks for the advice!
2017 BMW M2 PE MT
07-24-2017, 06:04 PM | #17 |
Rep 112
Well I hopped in the car today and on start up it rattled forever....... I looked underneath and the exhaust is sitting on the cross brace support again? I guess I will have to get back on the lift and check it out. Getting over it. Really do not want to have to drop my car off at the dealership but I will before I start welding stuff.....
2017 BMW M2 PE MT
07-24-2017, 10:19 PM | #18 |
Rep 155
I took my car to the dealer at 1500 miles with rattle at cold start and randomly through warm up. They identified it as "hitting the heat-shield/underbody insulation". Apparently they bent it further out of the way. All I know is the rattle is no more 800 miles later, I hope that helps... YMMV
Living Life Turn After Turn!
[/url] F87 M2 Performance Edition - 2017-current F15 X5 35d - 2014-2017 E36 M3 - 2009-2016 |
07-25-2017, 10:28 AM | #20 |
Rep 10
I did a cross country trip last month and developed the rattle. Took it to a dealer in LA and they fixed in in under a hour. Developed rattles again 1500 miles later on the return. Took it in to the dealer hear at home and they said there is a service notice and installed a newer clamp. Time will tell if this fix lasts.
