05-05-2016, 03:22 PM | #1 |
3890
Rep 54,590
Drives: F80 M3
Ohlins Road & Track BMW F8X M2 M3 M4 BMS MR40S1 Black Friday Day Sale!
This is the latest step in the Öhlins Racing automotive philosophy for your F87 M2
– Road&Track by Öhlins. A more than 30 year long tradition of high-end racing commitments and state-of-the-art solutions within advanced suspension technology is now available for street Cars all over the world. The focus has been clear from the very beginning – superior road handling without sacrifi cing comfort in your day-to-day transports. The time of compromises is over! We have also added a clever light-weight design with a majority of the parts in aluminium and on top of that all shocks have suffered through vast corrosion tests according to ISO 9227. The end result is a 2-year limited warranty on all of our products - worldwide. FEATURES General Front Rear > DFV (Dual Flow Valve) > Rebuildable > Corrosion salt spray tested (ISO 9227) > 2 year limited warranty > McPherson strut > Single bleed adjuster > Spring preload adjuster (approx. 10 mm lower than standard) > Coil springs 90 N/mm standard > Dustcovers > Use with original top mounts > Conventional shock absorber > Single bleed adjuster > Separate spring preload adjuster (approx. 10 mm lower than standard) > Coil springs 190 standard > Dustcovers > Use with original top mounts BMS MR40/BMS MR40S1 You can only substitute one pair of Swift springs or a full set of Ohlins springs at retail price. Second pair of Swift springs at 20% off of retail. 80/160 & 70/140 Ohlins springs are very popular. Exceptional pricing from now until May 31st, 2024! PM for details! Looking for Ohlins for your other vehicles? PM us for a quote! Order here: https://hpautosport.com/product/ohli...m4-bms-mr40s1/ Last edited by HP Autosport; Yesterday at 02:44 PM.. |
09-27-2016, 04:25 PM | #11 |
3890
Rep 54,590
Drives: F80 M3
11-06-2016, 01:16 PM | #21 |
3890
Rep 54,590
Drives: F80 M3
We can supply lower rate rear Swift springs at no additional charge!
