06-29-2018, 09:27 AM | #133 |
1006
Rep 1,653
Hello all,
I want thank Xutvjet for his passion. If anyone has had a federal issue with their sport cat on their vehicle I would love to hear about their experience. We use the HJS sport cats for our sport cat downpipes. Designed with a 200-cell HJS catalytic converter core for maximum performance and reliability; same cat core used on our Ferrari 458 Italia applications! You can add +21whp +36tq (ft/lbs). I do want to reiterate that we do not have any problem passing emissions testing in 49 out of the 50 states and the sniffer test in the 50th state (sorry California). |
07-02-2018, 05:20 PM | #134 | ||
Rep 451
I've been told these are one time use. |
07-04-2018, 01:27 PM | #136 |
Rep 4,255
No. The metal gasket is clearly one time use. It conforms to the outlet of your new dp.
///M Power
07-04-2018, 05:07 PM | #137 |
Rep 3,958
I reused the brass gasket. Its just a bitch to work with it. You can use it over and over and over.
07-05-2018, 12:48 AM | #138 |
Rep 2,197
jesus, just went to BMW parts, they charged me 60$ aud for the gasket!...
goign to try and reuse if possible so i can return it haha..
So far: 200cell downpipe, custom exhaust, lifhtweight splitter, m4 comp seats
07-07-2018, 10:52 PM | #139 |
Rep 1,466
Just to finish up my story... I returned from vacation on Thursday to find my Fabspeed Sport Cat waiting for me at home. I'd sent it back to them the day before I left to minimise the time my car would be out of action.
Struggling with Jet Lag, I woke up earlier than intended this morning and re-fitted the now fixed Sport Cat back to my car. Installation was a bit easier now that the bracket lines up because you can use the bracket fitted loosely to take the weight of the down pipe while you line up the turbo flange and V clamp. I've now removed and re-fitted the down pipe three times, so I've got pretty good at it. All times were done on jack stands like this: I was fortunate because I self installed, and because I was going on vacation. Overall though I think Fabspeed handled the issue well. Yes it was frustrating but these things happen and in my case they proactively reached out and fixed the issue.
2018 ///M2 LCI, LBB, 6MT...
07-07-2018, 11:01 PM | #140 |
Rep 1,466
With all of the talk of replacing gaskets and clamps, I think it's important to point out that the stiffening plate bolts, which need to be removed if you're changing the down pipe, have a torque rating of 56 Nm + 90 degrees.
This sort of bolt is known as a 'Torque to Yield' bolt, and is designed to stretch slightly, which gives a more even and accurate tension to the bolt than simply torquing can apply. It does however mean that the bolts cannot safely be re-used. I'm not sure quite why BMW decided to use these type of bolts, but they clearly do stretch. I re-used a set of bolts 3 times, and each time found it increasingly difficult to achieve the 90 degree angle after the first torque wrench setting; clearly the bolts had no more stretch left in them. I also found that screwing the bolts into the threaded parts of the chassis became increasingly difficult, almost like they were cross threaded. This was presumably because the stretch had occurred to part of the threaded section of the bolt. The last two times I used all new bolts, and everything went back together very easily and torqued up followed by 90 degrees very well. There is a reason BMW says these bolts must be replaced every time...
Current Performance Mods: CSF FMIC, ER CP, Fabspeed Cat, Aquamist WMI, GFB DV+, NGK 97506, BM3 (Stage 2 93 OTS), CDV delete, UCP, M2C/M3/M4 Strut Brace, M3/M4 Reinforcement Rings Last edited by Nezil; 07-09-2018 at 12:21 AM.. |
nothingman522.00 |
07-08-2018, 09:45 PM | #141 |
Rep 1,466
I was asked on another thread for the torque settings for the nuts and bolts required for the DP install, so here they are, taken from ISTA+:
07-08-2018, 11:54 PM | #142 | |
Rep 929
https://d1sfhav1wboke3.cloudfront.ne...c329e97cb8.pdf |
07-09-2018, 12:20 AM | #143 | |
Rep 1,466
07-09-2018, 12:27 AM | #144 | ||
Rep 929
07-09-2018, 05:00 AM | #145 |
Rep 2,197
07-09-2018, 05:14 AM | #146 | |
Rep 2,197
Ive got one of these, but doubtful itll be any use here http://www.supercheapauto.com.au/Product/ToolPro-Torque-Wrench-3-8-Drive/214304 |
07-09-2018, 07:54 AM | #147 | |
Rep 4,255
///M Power
07-09-2018, 08:26 AM | #148 | ||||
Rep 929
I will be doing the install next week and I was hoping I could use the same type of torque wrench with some long extensions but maybe it won't work? Quote:
07-09-2018, 08:27 AM | #149 | ||
Rep 929
07-09-2018, 08:40 AM | #150 |
Rep 4,255
I am pretty anal about preventing exhaust leaks. For me a vband clamp should be as tight as possible by hand with a wrench sort of thing. The tighter it is, the closer it draws the two bell ends together.
///M Power
07-09-2018, 08:59 AM | #151 |
Rep 1,466
I have two torque wrenchs, both are click type and both were purchased in England because I could only find primarily Ft-lb wrenches in the US. BMWs are European, and the original specs are always therefore Nm not Ft-lb so I prefer a wrench that is primarily Nm rather than Ft-lb; not that it actually makes a difference!
So I have a 1/2" drive one that has a 30 ~ 210 Nm range, which I use for thinks like lug nuts, and a smaller 3/8" unit that has a 10 ~ 80 Nm range that I use for almost everything. The 3/8" wrench did fit in the space for the top clamp, but it was tight. My wrench is cheap so the ratchet is pretty crap. It would only move one click at a time in the space available. The top clamp is almost springy, so achieving 13 Nm takes quite a few turns. I did end up doing it tighter by accident because the click on my torque wrench at 13 Nm was so quiet that I didn't hear or feel it. Having said that I do think 13 Nm would be fine for this clamp because of the type of material etc. It's not designed to take the weight of the downpipe, only hold the faces together so it doesn't need to be tight. The torque settings I posted are from ISTA+, I didn't make them up, they are BMWs specs! I also did the bottom downpipe to exhaust to 30 Nm, and that's really very tight for a V band clamp. The aluminum shaped washers were shedding fillings as I did it up because it was so tight. I torqued to speed, but it felt a little too tight to me.
07-09-2018, 01:35 PM | #152 |
Rep 4,255
Did you crush the metal gasket? I found it too tight as well then realized I need to get the gasket crushed/formed to the new DP. Depending on how you set it up, it could be easy or hard to tighten it. I switched it out for a brand new one and found it much easier to tighten. I probably went somewhere around 40lb-ft. 30Nm is only 20lb-ft and I think that would have left a noticeable gap still.
///M Power
07-09-2018, 03:49 PM | #153 | |
Rep 929
07-09-2018, 05:57 PM | #154 |
Rep 4,255
Start it cold and put your face near it basically. It will be obvious. Ultimately visual inspection near the part not covered by the vband also helps.
///M Power
