12-18-2017, 11:59 AM | #45 |
Rep 4,255
Has anyone engineered a solution to hardwire this thing? Cheapest, stupidest thing BMW could possibly do on a factory ordered option IMO. Like all Bluetooth devices they are prone to issues.
///M Power
12-18-2017, 01:19 PM | #46 |
#savethemanuals
2463
Rep 1,989
How do you know the valves are closed? Do you close with 2 clicks on remote? Also, the remote is blinking about every 5 second while open, correct?
12-18-2017, 01:38 PM | #47 |
Rep 1,339
Few things that I want to note here.
I am sure you already have enabled your MPE in the boot below the carpet. There is a button to switch on and off. I found that the switch is very loose and sometimes actually turns off (Just once) when I load some stuff in the trunk although that should not contact directly... I just said to myself that i will tape it down to put it ON all time just if same thing happens again. Wire connection sounds very popular issue and espectially if this wire is not visible under the carpet in the boot, dealers and mechanics will not be able to troubleshoot the problem. I have read a forum that one guy had exactly the same problem but his M2 was pretty much doing just fine when he tried to visit to show the dealer the problem of his MPE. So he eneded up recording the video and took it to the dealer back and that they have replaced the exhaust and works perfectly fine after he did. http://f87.bimmerpost.com/forums/sho....php?t=1319784 It could be BT problem. Some ppl say that it gets interfered by others using the BT nearby which I never find any issues with... Untimate solution for you is to have it looks by dealer and let them diagnose. Make sure you have some videos taken before your visit just to prove and show what problem it has. Best chance (but worse also) to get is replaced. If you are still under warranty, Your dealer will provide rental vehicle and fix MPE for no charge. |
12-18-2017, 01:50 PM | #48 | |
Rep 823
Garage; 2020 Raptor, 2011 1M, 2017 M2 PE, 2006 Z4 MC, 2007 Z4 MC, 2001 Spec E46, 2007 GT3
12-18-2017, 01:53 PM | #49 | |
Rep 1,339
12-18-2017, 01:56 PM | #50 | ||
Rep 823
12-18-2017, 02:02 PM | #51 | |
Rep 1,339
Wire and connection problem of BT remote cannot be just troubleshoot as they are hard to find the root cause. Sorry I could not help much.. |
12-18-2017, 04:01 PM | #52 | ||
Mini Beast
190
Rep 361
I'm in the UK, the first m2s came with just the BT remote, you could turn it on and off all day long. My M2 is the LCI and come with a red button in the boot and the BT remote. You must start the car first and then press the red button. And you can use the BT remote on your journey. I was informed when buying the car BMW put the red button in because it stopped people leaving it on as it's illegal in the UK
M2 = big smile every time
12-19-2017, 12:12 PM | #53 | ||
Rep 67
It is quieter You can confirm it by looking into the exhaust pipes. You will notice the flaps. Use the flashlight.
seis-speed2462.50 |
02-27-2018, 02:39 AM | #54 | |
Rep 2,577
I had auto closing problem (not as much as others reported though) when I first bought it in early 2017, so I unplugged the control module to keep it open the whole time. TBH I do not think it's too loud daily to daily at all because I have quiet car to drive when quite is needed. Today I opened M2 trunk just out of curiosity and found the blue fuse was indeed loose. I tightened it then plugged the module back in. It works properly, never closes on me again. Nice!
Lemania 2320
04-24-2018, 02:11 PM | #55 | ||
Rep 305
Thanks to these 2 guys for the input... I just noticed my flaps would close randomly while cruising after taking the car out of hibernation (the remote would stop flashing)... Checked this thread and decided to take a look at the fuse box, since the car is new, so I didn't think the battery in the remote would be dead already. Look what I found: The blue fuse #15 was clearly popped up, so I pushed it back in place. It feels tight now. Will report back after a few days but hopefully everything is fixed. |
04-24-2018, 11:12 PM | #56 |
Rep 305
Oh well, after my mild testing tonight, seems like the problem is unchanged... The remote just suddenly stops flashing and I cannot tell if the flaps stay open or not... I just changed the remote’s battery and will ask my dealer a new remote if the problem persists with the new battery.
04-25-2018, 10:58 AM | #57 |
Rep 181
Same exact thing is happening to me. Found the fuse on mine was also popped up along with the fuse next to it too. Pushed everything right back down again. Problem persists. How do you get the damn battery out of this remote without destroying it? lol
04-25-2018, 12:15 PM | #58 |
Rep 305
Twist the bottom portion
04-25-2018, 03:39 PM | #60 |
Rep 305
04-26-2018, 09:35 AM | #61 |
Rep 181
Battery changed finally, no change in behaviour for me. Still constantly disconnecting. I will check the actual fuse itself that was popped out of place and see if it's actually good or not. I preemptively booked an appointment but I will report my findings here.
04-26-2018, 10:13 AM | #62 | |
Rep 305
04-26-2018, 10:50 AM | #63 |
Rep 305
Just inspected the whole trunk, everything looks good and tight. Unplugged the blue fuse, tried to open the valves, remote blinked no connection (as expected). Replugged the fuse, tried the remote, remote worked perfectly, valves opened, then closed and reopened valves a few times... Everything working perfectly.
Will have to go take a couple of rides to see it the remote stops blinking again, and when that happen, check if the valves are opened or not. If yes, will have the remote replaced. If the valves are closed, will have to get the bluetooth unit replaced I think. |
05-07-2018, 01:48 PM | #64 |
Rep 181
Just adding my findings thus far: Had an appointment today, and as luck would have it the remote was behaving flawlessly. They have opened up a case for me as well, and they will be ordering a new remote. Once it arrives they will pair it with the system. In the meantime I'm to continue testing with the existing remote and take note of any failures.
By some miracle however, the system has been behaving flawlessly all day today. Not a single disconnect. This made me start brainstorming what could have possibly changed. The only thing that is different today from other days is that my apple watch is dead. I will see if I charge the watch and turn it on, if the behaviour will come back. The only other thing I've done is unplug the unit for the past week (only plugged it back in today before the service appointment) so not sure if rebooting the unit did anything. Will keep updating with my findings. |
05-07-2018, 02:29 PM | #65 | |
Rep 114
At least you guys have your valves working.....I just installed my MPE this weekend and my valves have NEVER opened. All I get is the 2 quick blinks, even with the remote next to the exhaust. Would they warranty a new remote if I installed it myself...? BTW...I am not trying to hi jack thread....I started my own for some help.... http://f87.bimmerpost.com/forums/sho....php?t=1493670
05-14-2018, 03:27 PM | #66 |
Rep 181
Updating with my experiences thus far, will be replacing the remote tomorrow, have a second service appointment. Will keep seeing if the new remote will be the fix or not. They have an open case for me so if that fails, I will keep hounding them until it's resolved.
To try and troubleshoot, I've attempted turning off my apple watch and my phone entirely. Valves randomly turn off regardless. |
