07-16-2022, 11:45 PM | #23 |
Rep 7,539
0.030".
Yeah the gap is supposed to be that big, which is what shocks me when there are users running 0.018". Like that can't be running smoothly.
07-17-2022, 12:14 AM | #24 | |
Rep 34
Seems like a lotta m2 owners are having misfires with that gap. I just know that I’m going to try .26 and go from there. Also wondering if I may have gotten a bad batch of 97506’s. What’s sketch is that my friend with an f80 had that happen to him. He had one bad 97506 that was supposedly brand new. He happened to have an extra one laying around and it solved his issue. Seems like a quality control thing with NGK if anything. Wow.. |
07-17-2022, 12:27 AM | #25 | |
Rep 7,539
07-17-2022, 01:11 AM | #26 | |
Rep 34
As soon as I get home, I’ll regap to .26 and log. I’ll post the log here. If you don’t mind, can you can lend me a hand and see if you see anything off? I’m still learning to read the logs myself. Thank you again |
07-17-2022, 03:13 AM | #27 | |
Rep 7,539
07-17-2022, 09:31 PM | #28 | |
Rep 34
What I did do was disconnect the pre cat o2 sensor to see if it would change anything. There was a slight minuscule change but not much. Could it be the pre cat o2 sensor? How can I test it Last edited by Leaveatrail86; 07-17-2022 at 09:37 PM.. |
07-17-2022, 10:49 PM | #29 | |
Rep 7,539
1) Just because one user has success with a plug gap range doesn't mean you should follow it because every car and use case is different (maybe one car had weaker coils), and especially because you also have much more powerful coils meaning you have alot more potential to chose larger gap sizes. This is why you always go to the max gap (stock) and go down only when needed, so you can get the largest gap size possible - remember gapping down is not a desirable thing it means you don't have the coil energy to maintain the spark. So when you follow another user's gap size choice without any prior testing on your own setup - especially when you are following a gap size utilizing stock coils on a much more agressive setup (meaning the requirements for a smaller gap may be valid) you are literally throwing away all the gains you have by upgrading coils because you don't need to gap down. Sure 0.026" doesn't seem to pose any issues with misfiring or idle, but again why would you gap down when it's not needed - this is even more emphasized because you have upgraded coils and gapping down when you don't need to is like throwing money for coil upgrades in the garbage. (Sorry if I sound harsh, I'm just trying to explain this as best I can, not trying to be a douche). But at the end of the day it's your choice, I just think it's a bad idea to gap down when not needed. 2) Did you put anti-sieze on your spark plugs? 3) Wait wait wait, you did what? NEVER unplug the pre cat o2 sensor, that is what the car uses to detect afr's, removing this cripples the cars ability to accurately detect these values and can put it in limp mode or even worse blow the motor. If the cat is fouled afr's values would be very off, and you may get codes.
https://f87.bimmerpost.com/forums/sh...2#post30368242 Last edited by F87source; 07-19-2022 at 12:29 AM.. |
07-21-2022, 01:59 PM | #30 |
Rep 660
I have to second what F87source is saying here - I have B58 coils and NGKs, I increased the gap from 0.023" to 0.028" and the car feels great even on E45-E50 mix. I do have stock plugs coming in that should be at stock gap (0.030"-0.032") which I will try next.
F87source7365.50 |
07-21-2022, 02:22 PM | #31 |
Rep 7,539
Don't forget, no anti seize on spark plugs. The plugs are already coated from the factory and do not require antisieze.
Not only can anti seize end up on the plug tips causing misfires and fouling of the plugs, but it is also a torque multiplier and can cause stripping.
07-23-2022, 11:59 PM | #32 | |
Rep 34
What I’m experiencing is a choppy exhaust note at load, as I get into 1st gear I can hear it break up. Of course, that lessened substantially at the .26 gap. I did see a YouTube video of Zero to 60 showing you how to test your spark plugs with a multimeter. I’m going to test them out before putting them back in. I mean, they literally have under 100 miles on the 97506’s. Perhaps, one or two are defective. |
07-24-2022, 03:51 AM | #33 | |
Rep 660
07-24-2022, 06:30 AM | #34 | |
Rep 34
Stock gap is .28 from what I understand. Gonna test them to make sure the plugs are good, and then gap to .28. Hopefully good results. Sometimes I feel like trowing the oem plugs back in to see if that yields positive results. I still have them. |
07-24-2022, 10:00 AM | #35 |
Rep 34
So I went ahead and test the new spark plugs I bought from Precision Raceworks. Three are weak, 2 are bad and only 1 is good.
4.45, 4.28, 4.26, 4.61, 4.49, 4.47ohm’s. These plugs have less than 100 miles. Go figure. Quality control, fakes or junk? The old plugs were 97506 as well but purchased from Burger Tuning. 5.11, 5.03, 4.47, 4.84, 4.62, 4.18. Old plugs. I was better off with the old plugs. The 4.18 I’m guessing was the culprit from the very get go. That was the issue it looks like. I’m about to reuse the old plugs, swap 2 plugs from the other set and try it out. Yes I’m gapping to .28. If this works I’m definitely sending Precision Raceworks and email. Hopefully I can get a new set of plugs or a refund. And hopefully they can test them there before they ship them to me. Good thing I only live 57min away from them. |
07-25-2022, 03:51 AM | #36 | |
Rep 660
10-24-2022, 11:09 PM | #38 | |
Rep 255
Feeling nice to find this thread and thanks for the info. It may solve my current problem. Funny part is I'm under a custom tuning process of Cary Jordan Team right now. LOL. They insisted 0.022'' gap new spark plugs must be changed first, then ask them to start tuning process. |
10-24-2022, 11:19 PM | #39 | |
Rep 7,539
There is no such thing as a one size fits all gap, so I hate the idea of just following an arbitrary size, you must do what works best for your car.
10-24-2022, 11:39 PM | #40 | |
Rep 255
What gap do you think is relative best for me? 0.028''? |
10-25-2022, 12:08 AM | #41 |
Rep 7,539
Yeah you should be fine with that gap, I've seen alot of people run more power than stage 2 91 with the same gap. But this will depend on the health of your coils, so it is all relative.
10-25-2022, 09:09 AM | #42 |
Rep 1,243
Drives: 2017 Big Turbo BMW M2
I'm using 0.018 for an E60 blend and car feels smooth. I actually had misfires with 0.020 on the top end, causing us to gap down more. we also had to dial my map in better. the car feels fine now for me but we are fixing my reflex box
10-25-2022, 10:22 AM | #43 |
Rep 255
quick question, what is misfires symptom? CEL on? I don't have rough Idle or Stall issue. How can u tell if it's misfiring when doing WOT or during regular driving?
10-25-2022, 10:38 AM | #44 |
Rep 1,243
mainly with WOT throttle pull. we datalog with 4 gear pull, 2k to 6k RPMs. the car will cut all its power out basically and feel like it redlined it. sometimes it'll throw on a CEL but not always. rough idles can be from the same symptom of the misfire, like spark plugs, coil ignitions, or injectors.
ericlr1225138.00 |
