09-12-2019, 01:17 AM | #24 |
Rep 244
Got a response from PTF:
Serge proTUNING Freaks commented: Hi Thank you for reaching out to us. The update was done only for stage 2 maps. Stage 1 had no issues. Best, Serge |
09-12-2019, 07:14 AM | #25 | |
Rep 4,218
This is awesome news about the inlet, thank you! |
09-12-2019, 10:32 PM | #26 |
Rep 1,115
OTS Stage 2 91
Before inlet http://www.bootmod3.net/log?id=5b1f1da5d10b4355bc6a667d After inlet http://www.bootmod3.net/log?id=5baadd37d10b435c56a38456 |
09-15-2019, 11:46 AM | #28 |
MOLON LABE
80
Rep 109
I’ve been using it for about a week now and it does produce power as advertised all the way to redline. I have no dyno data just time using version 5.7 prior to this on the street. I’m using Stage 2 93 oct AGG OTS 5.8 for reference.
09-15-2019, 11:50 AM | #29 |
Rep 27
I updated yesterday and haven't had time to test that much. I using the stage 2 93 oct map. I tried the car after update and it's hard to say if there is a noticeable difference or not. regarding to the sport display it's like 450hk but I assume that the sport display is noting to relay on
09-15-2019, 12:20 PM | #30 | |
MOLON LABE
80
Rep 109
09-16-2019, 05:18 AM | #31 |
726
Rep 364
The reason for the updates is due to the limitation of the turbine efficiency. On 5.7 stage 2 93 and E30 OTS maps I saw power drop on dyno where the stage 2 91 octane actually made more power!
So I made some changes allowing more turbine on those maps and the result is a solid and stronger topend! |
squixs110.50 digimattic36.50 |
09-16-2019, 06:37 PM | #33 |
Rep 21
Quick Noob question. I just purchased BM3. About to flash my first map. I'm running 94 octane and a catted Fabspeed down pipe. Any suggestions on what the best map I can run. There seems to be multiples of the same maps.
thanks for any help. |
09-16-2019, 09:44 PM | #35 |
Rep 21
09-16-2019, 10:11 PM | #36 |
Rep 1,115
94 regardless of brand in Western Canada is pretty crappy, if you aren't prepared to run 1/3 can of Boostane Professional in every tank I'd stick with the ACN maps. Watch for the pop sound if you haven't changed your charge pipe yet from OEM.
09-16-2019, 10:19 PM | #37 | |
Rep 21
Cheers |
09-21-2019, 08:16 PM | #39 | |
Rep 4,218
09-22-2019, 02:02 AM | #40 | ||
Rep 4,529
Current '22 X3M LCI.. |
10-08-2019, 10:31 AM | #41 |
726
Rep 364
Results from an M2 F87 with downpipe and intercooler on 98RON (93OCT) on stage 2 93 octane OTS map Version 5.8!
10-08-2019, 02:39 PM | #42 |
Rep 303
10-08-2019, 09:35 PM | #44 |
Rep 303
