02-12-2019, 11:45 AM | #23 |
Rep 258
Dont you have to crank the motor to perform a compression test? Without oil, Im thinking you did way more damage doing that than actually running the car for 2-3 minutes. That motor is toast. Im gonna guess scored cylinder walls and bearings. Yikes.
02-12-2019, 01:37 PM | #24 |
Luxury at the redline :)
9109
Rep 7,563
Ahh.. Makes sense now.. New cars don't get totaled for 'minor front end' damage; the motor was gone before you even made the purchase.
Unless you own a body shop or it's a project car; you'll never come out ahead with purchasing a vehicle with a salvage title.. Trust me, I know from personal experience.. I could write a book.. |
02-12-2019, 03:23 PM | #25 |
on restriction from buying more cars
244
Rep 193
All cylinders low does seem suspicious. Could it be fuel washed? I not super familiar with the N55 engine, but I had a friend run a car for over 100 miles with no oil and the car still ran. Seems to me no oil would cause excessive wear on bearings, cams, gears, etc, but I’m struggling to see how it would create low compression on all cyclinders. I wouldn’t go scrapping the whole engine without getting a professionally opinion. Maybe a tech could swing by off the dealer clock and check it out for you after work. Gotta make friends with some mechanics
Edit, unless you scored all the bores so horribly that they are not holding compression. You can peak down the spark plug hole with a camera. They make borescopes for this that are fairly cheap. Last edited by matty_f; 02-12-2019 at 04:09 PM.. |
ZeroEmissionZ17.50 |
02-12-2019, 05:39 PM | #28 | |
Rep 1,018
It cost $400.00 at the dealer just to open it up, just to tell me I needed either a complete rebuild for $8700, or a new engine for $9000. I didn't have the financial resources back then that I do now, so the car sat for a year until I found a used motor out of a 96 M3 for $3500. My E36 M3 was a six year old model at the time, so parts were easier to find for it. The N55 for the M235i has been around for awhile, so that may be the cheapest route, if you don't mind having a slightly less powerful car. I had a M235i and the power didn't feel that much more less than my M2, the M2 is just tuned and geared more aggressively. I also agree with others in that taking it to a dealer may not be a bad idea. It will cost some to open it up, but who knows, hopefully it's something they can fix. |
02-13-2019, 10:18 AM | #29 |
Occasionally frequent poster
3012
Rep 2,746
I would suggest that finding a good independent BMW shop, especially one that deals with modified and/or race cars, would be a better choice than the dealership. Typically (at least in the USA) they default to "replace engine" if they get into any difficult internal issues. If the engine is toast, it's almost certainly cheaper to go find a used one somewhere. The N55 is common enough that a replacement could be sourced.
I suggest sticking with the engine (even though the M2 is not a standard N55) that the car came with, to avoid ECU programming issues, but that's just an uneducated suggestion. Buying a total loss car is always risky. Back when I had my Chevy SS (Holden VF Commodore) there was a guy on the forum who bought a flood car, and he was able (with mad skilz) to replace the damaged computers, reprogram stuff, fix the other stuff (no engine or transmission internal damage) and ended up saving probably $25K (US) over the price of a dry car. Of course, he can never sell it for much more than he paid, since it is a branded car, but it can be done. Again, you've got to be able to do a lot of it yourself; otherwise you're just writing checks all day long. I applaud the OP's chutzpah, but it sounds like it's time for a professional diagnosis, not a remote Internet guessing game. Keep us posted though, we all wish you well!
Current inventory:
02-14-2019, 09:18 AM | #30 | |
Rep 50
Will keep you guys posted thank you so much for trying to help all ❤️😘. |
02-14-2019, 09:28 AM | #31 |
Rep 50
Oh I think I remember reading somewhere a few days ago , can and does the “Double VANOS” new system have any effect on the actual motor psi? I know the VANOS pushes the cam rod or shaft from what I remember which also effects the timing of the engine.
If the VANOS system was hydraulically locked somewhere wouldn’t that have a impact on the oil circulation and pressure in turn affect the psi reading of the internal if for example the rod is not fully engaged or partially , or completely disengaged ? I wouldn’t think such a car being $100k designed by big men “engineers” would allow a $20k motor to be cooked in literally 30 seconds , it is a 2018 model , like what the heck these days a car will alert the hell out of you if your windscreen fluid is low , and go into limp mode if it doesn’t like a signal from the transmission, one would of thought Bmw has some sort of safety system to protect such a important component of the car they designed “the bloody motor!” And so inconveniently they have placed the oil cooler literally about 5 inches above the road level, so hit some wildlife or road speed bump, or a gutter and kiss your engine bye bye. Really stupid locataion for such a critical part of the vehicle , and the motor should at least sense the sudden drop in oil presssure and switch off or limp mode, this is what I’m assuming has happened with my car “hopefully” it’s in a safe mode and hence it’s not starting. But the pistons still read 50-75psi across them 😔😡 |
02-14-2019, 09:40 AM | #32 | |
The deuce gets loose
290
Rep 499
The cooler is out front, where it works best. You cannot design something that is as efficient, AND can take a hit. Who hits things and expects everything to be ok? Why was your car totaled to begin with? Let's start there before we tell you that there is no limp mode due to low oil pressure. And if there were, it would alert you on iDrive. Engines need oil to stay lubricated, and reduce friction on internal parts. You started it without oil. The bearing tolerances themselves are extremely tight. Maybe not E92 M3 tight, but tight. I suspect you cooked whatever was left of those rod bearings. |
02-14-2019, 09:49 AM | #33 |
3012
Rep 2,746
Please note that the OP is in Australia, and they pay quite inflated prices down (under) there. And higher taxes. And their dollar doesn't translate 1:1 to ours.
Current inventory:
McPurrs290.00 ZeroEmissionZ17.50 |
02-14-2019, 02:09 PM | #34 | |
Rep 50
In my SL65 AMG the coolers are not down below held by 2mm thin steel brackets that you are able to bend with your hands. , They were mounted much higher off the floor , near the centre grille and didn't have long neck hoses that could be penetrated at the slightest bump or hit. They had two grills in front of them, and thick metal that you would use as a roof intrusion bar going across the front . I will try get a photo and show you what I mean. So computer tells you, you need wiper water, or fuel, but doesn't warn you that your engines about to cook? sounds legit to me! |
02-14-2019, 02:16 PM | #35 | |
290
Rep 499
02-14-2019, 02:25 PM | #36 |
Rep 50
ok im a liar and im just bored with my life lying to people who know better then me needing there help? really? The car did not mention nothing of oil , it said washer fluid low, bonnet open, headlight adaptive malfunction as the headlights were disconnected. It did not mention anything of oil is why I didnt stop to turn it off, and asking the question as to why BMWs do not have this safety system, then again what would I know im sure its you who has the busted M2 oil lines, and seen the message
02-14-2019, 02:28 PM | #37 |
Rep 50
02-14-2019, 02:44 PM | #38 | |
290
Rep 499
Questionable as in , how did you know the car had zero oil in it? Why would you run an engine without oil, if you knew it was empty? Are you sure you are not over your head thinking you can repair a salvage, with limited knowledge such as "lack of oil is bad for an engine?" Where are ANY pics to validate your story? What steps did you take while performing your compression test? What did the subsequent leak down test tell you? Have you scanned it for codes at all? |
eatingpizzainthef87rules253.00 |
02-15-2019, 08:57 AM | #39 | |
Rep 50
I stopped the motor and knew the oil was low when I got out of the car to see why it turned off , the oil cooler lines were all brown covered in oil, so was a huge patch of oil on the floor, but as far as inside of the car telling me the oil is low "No" this never happened, engine just turned off and then I got out to see and seen the oil everywhere. I hope it didnt cook it and it just went into a fail safe mode, funny enough on the dash no errors other then hood opened , washer fluid level, and headlights . I cant rule out any engine lights as the car isn't turning on meaning all the Ligjts are still on "reds" which lights up all the lights on the cluster, not necessarily meaning they are fault, but merely going through the stat up procedure, I will get photos up soon and keep this post updated. sorry if any misunderstandings here guys |
02-15-2019, 10:20 AM | #40 | |
Rep 845
Instagram: @Project_F87
02-18-2019, 09:12 AM | #42 |
Coffee Every Day
397
Rep 359
Drives: 2021 M2C
Good luck man. I wish you the best. Hoping to hear this engine turn over again as it will be good future reference for others.
-2021 M2C, HS, 6MT
-AST 5100, AP Racing 9660, BMW-788M, RF-GT4, BW-TA5R, APR GT 250 Wing & Front Splitter -TMS Diffuser, TMS F80 Skid Plate, HEX Armor PPF, CAN-Checked Data Logger, RaceBox -Recaro Pole Position , 2kBody Half Cage, Pinnacle Motorsports Half Cage (On order), CAE Shifter -Remus Race + BR EL Mid |
02-18-2019, 11:19 AM | #44 | |
290
Rep 499
Or do what that clown said and fix your leak, change your plugs, and you are good to go I guess. LMAOOOOOO Back to serious stuff... do you know why the car was salvaged? That may help trace the issue(s). |
