12-22-2023, 12:59 PM | #331 |
3890
Rep 54,590
Drives: F80 M3
Only five more kits left for the F8x M.
Help us move them! |
12-27-2023, 04:08 PM | #332 |
3890
Rep 54,590
Drives: F80 M3
PM us if you are concerned about the Ohlins R&T being to stiff. We can customize the kit with lower-rate Swift springs.
02-06-2024, 05:49 PM | #337 |
3890
Rep 54,590
Drives: F80 M3
BMS MR40S1 all sold out until end of Feb. 2024. New batch will be ready to ship around March 1st.
03-04-2024, 12:39 PM | #339 |
3890
Rep 54,590
Drives: F80 M3
F8X M Ohlins Road & Track back in stock in the USA. 5 kits ready to ship as of today!
03-05-2024, 06:36 PM | #340 | |
Rep 1,337
From the eu site it appears that the BMS-MR40 comes with a 16kg rear spring and is the dedicated part for the M2. Has this been discontinued? The BMS-MR40S1 comes with a 19kg rear spring and is a compatible part for the M2/M3/M4. Has the valving changed as well again? Seems like every 6 months they change the part numbers for this platform. If you can provide some insight what has changed overtime that would be awesome, also maybe add a matrix to the first post of the differences would help other potential buyers.
03-06-2024, 11:28 AM | #341 | |
3890
Rep 54,590
Drives: F80 M3
If a component/valving/spring is changed, the kit gets a new part number. What changed, exactly over time? We no longer have that information, but we might have posted something about it when the changes were made. You will have to do some research. Your local Ohlins Australia or Ohlins Sweden should have the answers you seek. |
04-26-2024, 01:01 PM | #346 |
3890
Rep 54,590
Drives: F80 M3
Feel free to reach out for quotes on Ohlins for other vehicles. We carry the entire line of Ohlins R&T, Track Day, and TTX.
05-15-2024, 01:38 PM | #348 |
3890
Rep 54,590
Drives: F80 M3
This is the latest step in the Öhlins Racing automotive philosophy for your F87 M2
– Road&Track by Öhlins. A more than 30 year long tradition of high-end racing commitments and state-of-the-art solutions within advanced suspension technology is now available for street Cars all over the world. The focus has been clear from the very beginning – superior road handling without sacrifi cing comfort in your day-to-day transports. The time of compromises is over! We have also added a clever light-weight design with a majority of the parts in aluminium and on top of that all shocks have suffered through vast corrosion tests according to ISO 9227. The end result is a 2-year limited warranty on all of our products - worldwide. FEATURES General Front Rear > DFV (Dual Flow Valve) > Rebuildable > Corrosion salt spray tested (ISO 9227) > 2 year limited warranty > McPherson strut > Single bleed adjuster > Spring preload adjuster (approx. 10 mm lower than standard) > Coil springs 90 N/mm standard > Dustcovers > Use with original top mounts > Conventional shock absorber > Single bleed adjuster > Separate spring preload adjuster (approx. 10 mm lower than standard) > Coil springs 190 standard > Dustcovers > Use with original top mounts BMS MR40/BMS MR40S1 |
