03-11-2019, 05:29 AM | #243 |
XSS11V
280
Rep 128
Drives: M2 LCI - Mineral Grey
Anyone here running a LCI DCT M2 with a JB4 and Wagner Evo2 Comp IC as the only mods? I would like to know what Map you are using with 98 RON fuel
03-11-2019, 06:02 AM | #244 | |
Rep 4,529
If you datalog both and see/feel some good gains with map 5 vs map 1, then use map 5 datalogs to create a custom map [map 6]. FWIW, I'd suggest upgrade stock DP to either a decat of 200CPI HFC DP to get most out of yr JB4 on yr m2.
Current '22 X3M LCI.. |
03-11-2019, 09:33 AM | #245 | ||
24491
Rep 191,471
XSS11V279.50 |
03-11-2019, 01:00 PM | #246 | |
Rep 488
I was only talking about this part with a friend yesterday as I was unsure how much benefit would really be realised without a bigger turbo. Was you experience with the hi flo turbo inlet based on a stock or already tuned car? I'm very interested in anything that minimised turbo lag. Cheers. |
03-11-2019, 01:07 PM | #247 |
Rep 488
Re IAT's - obviously the lower the better, but is there a temperature range that is usually aimed for?
Also, what would be the max temps seen before an engine started protecting itself? |
03-11-2019, 01:21 PM | #248 | ||
Rep 362
Thanks |
03-11-2019, 06:02 PM | #249 | ||
Rep 4,529
M2 stock inlet pipe is same part as fitted to early F2x m135i and F3x 335i with PWG turbo. Inlet ID is ideal for smaller PWG turbo compressor wheel. The later EWG turbo - as fitted to m2 - has larger comp wheel hence oem inlet pipe is restrictive by default. On my JB4 tuned EWG n55 in my m135i - the Pure hi Flo inlet pipe helped the car to punch harder longer higher up the rev range. Areas under power and torque curves grew by about 20 & 30% respectively. No brainer imho for n55 in my m2.
widetyres280.00 Sundinisagod115.50 |
03-11-2019, 06:06 PM | #250 | |||
Rep 488
Added to the shopping list! |
Bee Pee1787.50 |
03-11-2019, 09:54 PM | #252 |
24491
Rep 191,471
03-30-2019, 01:08 AM | #253 |
2470
Rep 9,004
No.
I wouldn't do any of the Wagner products (or any stage 1 intercooler for that matter) I'm more interested in the ER, VSFR and CF (ATM?) products. Wagner getting walked all over. https://f30.bimmerpost.com/forums/sh....php?t=1518971 |
03-30-2019, 01:26 AM | #254 | |
757
Rep 2,149
But I do agree any 5" intercooler isn't worth it. |
03-30-2019, 01:29 AM | #255 | |
2470
Rep 9,004
It's not that it's a "bad product" there is just clearly a superior option. I don't see people talk about ER here anymore though - I was under the understanding it was "the best" |
03-30-2019, 01:39 AM | #256 | |
757
Rep 2,149
03-30-2019, 01:54 AM | #257 | |
2470
Rep 9,004
03-30-2019, 01:58 AM | #258 |
Rep 1,835
Drives: 2020 X4M CS
7" VRSF combined with DEI Water sprayer and Cry02 C02 intercooler sprayer....I can bring my I/C to -40*F before or during a run. Keeps IATS under 90* on hottest days
2020 BSM X4///M-2016 BSM ///M2- 2011 668 ///M3 |
03-30-2019, 04:11 AM | #259 | |
Rep 7,539
1) Your IC sprayer + CO2 sprayer are consumable, once they run out the IATS will spike again, plus they don't last very long on constant spray for track usage. For drag racing it is a very nice setup, something I've played around with on my various subarus due to the top mount intercooler not getting any air flow when the car is stopped thus getting heat soaked. 2) The water spraying imo isn't very ideal because the engine bay eventually gets really humid and that attributes to corrosion. 3) I don't know if this is a huge issue with the BMW crowd since no one has really pushed very far with CO2 cooling, and the Intercooler is front mounted. But in the subaru community IIRC there was a case where the top mount intercooler was sprayed with excessive CO2 it filled the engine bay and got sucked into the intake and messed up afrs. This only happened when the car was at low speeds. 4) Adding extra water and a CO2 bottle also adds alot of weight, but the gains are very nice. IMO this setup is probably better for drag racing since you only need to have enough consumables for 1 pull vs. a track session where you can go for 15mins - 1 hour or more. Overall that sounds like a sweet setup man, do you have any pictures or a thread I can look at?
03-30-2019, 07:22 AM | #260 |
757
Rep 2,149
I'm not pretending either is better. From the very beginning I took the stance that it's subjective and depends what you want. 10lbs or 7F cooler. Neither make a difference, neither is superior, and neither are comparable. You're the one touting one is better than the other. Don't be a jerk.
03-30-2019, 07:56 AM | #261 | |
Rep 3,715
10lbs on the very nose of the car (for the track) and no lag (for the street) is worth more to me than a few deg F. ICs are all a balancing act, just depends on what you want out of them for your situation. |
03-30-2019, 08:27 AM | #262 | |
2470
Rep 9,004
I just really don’t see the use in recommending someone a ‘stage 1’ intercooler, especially in a brand that really just doesn’t perform as well during aggressive driving. Last edited by Taskmaster; 03-30-2019 at 10:21 AM.. |
03-30-2019, 08:31 AM | #263 | |
Rep 3,715
“A Note on Lag Measurements elsewhere have shown that the Wagner EVO 2 Comp should flow a bit better than the ATM. Paying attention to lag while accelerating from a stop, and also watching my fuel economy meter seem to confirm that. Accelerating form a stop my fuel economy meter drops to about mid to high 8mpgs with the Wagner. With the ATM it's in the low 8s. The lag is slightly more with the ATM” No thanks. |
03-30-2019, 08:34 AM | #264 | |
24491
Rep 191,471
One needs to compare pressure air drop, IAT recovery after each pull and weight (weight is more of a factor on the track). All these would come in favor of tube and fin core like the Wagner. Lots of really good options available, it just depends on the application and HP goals.
ZM22839.50 |
