04-18-2024, 12:10 PM | #1 |
Rep 75
Correct Way to Install N55 Chargepipe O Ring
Had a shop replace the OEM CP, and they forgot to move the O Rings over to the new pipe. CELs thrown. Shop is too far to take it back, so I bought the rings from the dealer and installed them last night. New codes thrown all of which indicate a boost leak somewhere. Pretty sure I incorrectly installed the O Ring on the IC side of the CP. Could anyone confirm the correct way to put that ring in the CP?
04-18-2024, 12:53 PM | #2 | |
22186
Rep 8,724
They clearly weren’t careful noticing how they removed it in the first place You might check if it’s leaking right in the middle where both the upper and lower sections connect
04-18-2024, 04:30 PM | #3 |
Rep 4,216
Mods: Yes.
hihowareyougood125.50 |
