M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > Wheel and tire sizes, stock suspension
      04-02-2024, 10:39 PM   #1
Jpinner
Jpinner's Avatar
Drives: 2011 BMW X5 50i
Hey guys,
I’m new to the Bimmerpost community and recently bought a 2019 m2c. It came with the stock wheels and titan7 ts5 wheels. The tires on it are michelin pilot sport 245/30/19 front and 265/30/19 rear.
My question is, I recently put on a bootmod3 stage 2, 91 OTS map. I’ve been reading the stock tire size won’t be able to accommodate the newly added HP gains and tires will just spin.
What tire size will suffice to handle 500+ hp? Also id like to keep stock suspension and no suspension upgrades at the moment.
I’ve been reading 255/35/19 front and 285/30/19 rear is the way too go and I won’t have any rubbing issues. Please comment on the anyone’s experience with reccomended sizes that won’t require mods to suspension and will be able to
Handle the extra power for traction.
Please and thanks!
Wheel specs:
Titan 7 TS5
-19x9.5 et 27
-19x10.5 et 44
      04-05-2024, 08:25 AM   #2
///MPhatic
The Seeker
///MPhatic's Avatar
14193
Drives: OG M2 • Exige
OK, wow, just hold the phone.
1. Grip has more to do with the tire compound and pressure in the tire than it does with size; bigger is not always better. You will get NO MORE straight line traction with a 275/285 than you do with a 265. Wide tires are made for sideways grip, not forward grip.
2. On 9.5 & 10.5 you can run 245/35 & 265/35, or 255/35 & 275/35 (although this will give you no more grip and you're really just making the tire taller, which is making the ride more comfortable at the expense of response), or 265/30 & 285/295/30 (265 is the issue here, and will most likely rub if you drop the car).
Some guys run the stock 245/35 up front because it runs WIDE, and a 295/30 in the rear for more grip, which you can do, but you're going to jack up the handling of the car.
So handling is what you need to address first. Do you want to preserve the stock playfulness of the car, or are you after 0-60, ¼-mile, and roll-racing fun?
YOU MUST CHOOSE, otherwise you won't get the best of either.
From the picture it appears you have the stock PSS in 245/35 & 265/35. The front runs WIDE, and the rear a bit skinnier, which is why you have such a stretch.
Do you drive in rain?
Do you plan to track?
Do you drive in the cold? How cold?
Do you plan to drop the car?
What's your budget?
What's more important; handling or 0-60?
Do you mind to rub a bit if it doesn't really damage the car or the tires?
Do you regularly carry passengers in the rear?
So many questions that need answers before anyone can really help you with tires. It's not as simple as it seems.
DanG10848.00
Shaq9312.00
      04-05-2024, 09:33 AM   #3
VGSON
VGSON's Avatar
Drives: F87 OGM2
I’d advise 265/30 front and 285/30 back in mich ps4s. If you’re still getting spin midway thru 2nd/3rd gear; consider playing with lowering pressure a few pounds or lowering power by gear a few %….
      04-05-2024, 10:35 AM   #4
///MPhatic
The Seeker
///MPhatic's Avatar
14193
And this is a perfect example of why we don't listen to just anyone about tires.
No disrespect intended dude, but I'm going to use you as an example.
1. The 265/30 PS4S will almost assuredly rub in the front on 9.5 +27.
2. The 285/30 PS4S runs particularly skinny, and as such is as near as makes no difference in width to the stock 265, and has a SHORTER sidewall, which will grip less.
3. At his height the 265/285 combo will make his gap look like a monster truck.
DanG10848.00
      04-05-2024, 12:14 PM   #5
VGSON
VGSON's Avatar
Drives: F87 OGM2
I think you are being quite dramatic. The fronts will barely rub and a heatgun will resolve the issues if it doesn’t self clear.
Stock tire dimensions;
9.8wide 25.8tall front
10.7wide 26.3 tall rear
265/285 combo
10.7wide 25.3tall front
11.4 wide 25.8tall rear
about 1/4” of added fender gap = monster truck? Especially on a black car…dramatic
OP, do a search on this forum for pics of others running similar setups. I was worried due to people making comments about my future tire setup..but after searching im good..Everyone says its bad, then someone does it and shows irs good/fine.
https://www.bimmerpost.com/forums/sh...php?p=25675441
      04-05-2024, 12:45 PM   #6
///MPhatic
The Seeker
///MPhatic's Avatar
14193
And what if he decides to lower the car with a set of coil-overs, where does that leave your 265/30 on +27? Locked to PS4S?
265/285 combo
It is, especially with his already large gap. And the 285/30 PS4S is usually quite hard to get. In fact, it doesn't even show in stock at Tirerack at the moment.
You'll find very few cars running 265/30 & 285/30 indeed. Less than 10 I think, and there are good reasons for that, but hey, to each their own.
      04-05-2024, 01:54 PM   #7
VGSON
VGSON's Avatar
Drives: F87 OGM2
correct; to each their own and form your own opinion…
      04-05-2024, 02:25 PM   #8
///MPhatic
The Seeker
///MPhatic's Avatar
14193
That's interesting, it didn't show available earlier.
I wish Michelin would keep their sizes more consistent, between the 265/275/285/295, Star Spec, DTM, Merc, and TP they are all over the place.
      04-06-2024, 05:44 PM   #9
tropicatango
tropicatango's Avatar
444
Drives: Bmw f87 M2c hockenheim silver
Go with 255/35/19 front and 275/35/19 rear
Choose a sticky 200 thread wear compound
- yokohama a052
- yokohama advan ad09
-nankang crs
- bridgestone re71rs
Check on tire rack yo make you an idea with these sizes
The titan7 are designed to run up to
265-30-19 front
295-30-19 rear
Without rubbing
They are the same specs as the apex ec7
Good luck shopping
I personally run these wheels,
I tried on these:
Goodyear eagle super car 3 : 245/35/19 front and 265/35/19 rear, very good sticky tires but the oem size is a bit stretched on the wheels, its safe and offer good performance because by the tires specs, the wheels are ok but i prefer 255/275
Tried Michelin cup2 255/275, was perfect fitment, great tires
Now i run 255/275 Michelin pilot super sport, perfect too, more street oriented vs the 2 other
Got a good deal from a brand new take off supra which are bmw star specs tires
For me, next are bridgestone re71rs 255/275
      04-21-2024, 07:31 PM   #10
Jpinner
Jpinner's Avatar
I am leaning towards replacing the MPSS tires with the Firehawk Indy 500s. I’ve heard some good reviews on the Indy 500s and the price being half the price as the MPSS and similar performance wise.
I am after better straight line grip, roll racing and will be doing 1/4 mile drag in the future.
should I go 255/35, 275/35 or will 255/35 285/35 be better?
      04-22-2024, 09:03 AM   #11
VGSON
VGSON's Avatar
Drives: F87 OGM2
if wanting straight line….get a set of drag radial rears…285/35 nitto nt555’s
      05-07-2024, 07:53 PM   #12
Telluride
Drives: 2020 M2C
- yokohama a052
-nankang crs
265-30-19 front
295-30-19 rear
Without rubbing
Good luck shopping
I tried on these:
I too have 9.5"/10.5" wheels. What does looking "stretched" mean? Not square shouldered, more rounded because tire is pulled inward towards middle of rim? I do not mind how my stock 245/265 MPSS look on my rims. I have seen 255/275 MP4S on another M2... meh, think the MPSS sidewall is a better look.
And definitely curious on your SC3 experience. Considering that and the SC3R in 245/265 size, if it would provide noticeable improvement to MPSS traction. I enjoy MPSS thrill and playfulness (slide). However, my tune has made it bat shit crazy loose.
Here's my recent post asking about SC3/3R and A052's...
https://f87.bimmerpost.com/forums/sh...&postcount=351
      05-07-2024, 09:37 PM   #13
tropicatango
444
Goodyear eagle supercar 3 are very good sticky tires, on the street and track i absolutely loved them. The 3R are super sticky but 2 tracks day or 3-4000 kilometers and it’s over, not the cheapest option
But the 245 front and 265 rear are stretched on 9.5-10.5 wheels, that means that they do not cover the lip on the wheels abd the lip is exposed, by the tires specs, there is no problem to run 245-265 on 9.5-10.5. I did and the performance was amazing
But i since upsize to 255-275 to have a Little less stretch and have my sidewall cover my wheels lips
If you have a tune with 9.5-10.5 wheels setup designed for m2… i suggest minimum 255-275 with 200 thread wear tires ( i would try bridgestone re71rs because they are cheaper than other, but plenty of sticky rubber in this size
Or 265-30-19 front and 295-30-19 ( i would try nankang crs)
Make search by tire size and see what’s available, you’ll find something good since you have a good wheels setup that open up the size options with perfect fitment
Telluride135.50
      05-08-2024, 10:34 PM   #14
Telluride
Drives: 2020 M2C
Goodyear eagle supercar 3 are very good sticky tires, on the street and track i absolutely loved them. The 3R are super sticky but 2 tracks day or 3-4000 kilometers and it’s over, not the cheapest option...
Great detail! And the 3R's only providing 3,000-4,000 km's. Haha! Crazy town.
Makes my choice easy at the 245/265 size - SC3. Comparing SC3 to SC3R, did SC3 pickup materially less rocks? A concern I'll have to deal with, going to stickier tires.
I did see YouTube review of the A052's and reviewer said they picked up much less rocks than their M Cup2's.
Appreciate all your help. Now time for me to study the 'wheel spacer' thread, and see if I can figure out what stickier, wider tread width tires (255/275) will fit. Thank you!
      05-08-2024, 11:03 PM   #15
tropicatango
444
Sticky tires and spacers are perfect to sand blast the sides of your car, i personally avoid them.
To save the car, i had it ppf and i installed automotive passion carbon arch guard and when i see how they look inside of the wheels well, they really worked and saved my paint.
I ran super car 3 and cup 2 and didn’t personally observe a difference for rock picking, they both are sticky and picked stuff.
      05-09-2024, 12:23 AM   #16
Telluride
Drives: 2020 M2C
Definitely NOT looking to add spacers. Have BBS FI-R's so my offset is good. My comment was in regards to this thread, in which I asked about tire fitment and a 'wheel spacer' thread, as I consider sizing up.
https://f87.bimmerpost.com/forums/sh...468422&page=17
Arch guards is a good tip... I'll check them out. Funny, earlier tonight I asked another poster about the arch guards on their black M2 as they blend nicely.
      05-09-2024, 04:16 PM   #17
tropicatango
444
Automotive passion arch guard are invisible once on the car
Telluride135.50
CSBM52756.00
