11-19-2023, 09:29 PM | #1 |
Drive Different
53
Rep 225
F87 Brake Replacement Simple Question
Hey Guys,
Planning on changing brakes on my 2017 F87. Simple question. In the image, there's a recommendation to change the "retaining spring". Is that the part #9 (red arrow) in the diagram? Thank you!
'17 F87 M2 DCT / '16 F15 X5 X35i / '09 E82 135i 6MT*
'10 E70 X5 35d* / '05 E60 M5 SMG* / '01 E53 X5 4.4i* / '76 2002* | '70 2002* *Gone |
11-19-2023, 09:37 PM | #2 |
Rep 211
Drives: 2021 F87 M2 Competition
Yes, that is correct; #9 is the retaining spring, or clip as it is referred to in the diagram
2021 F87 M2 Competition, Sunset Orange, 6-speed
2010 E60 535i xDrive, Space Gray, Auto (sold, but still in the family) |
11-19-2023, 09:41 PM | #3 |
Drive Different
53
Rep 225
Thank's for your help!
Fred Conoway365.00 |
11-20-2023, 12:03 AM | #4 | |
Rep 3,549
The retaining spring is item #4 in the front and rear diagrams below. There's no need to replace it.
gsrbri559.50 |
11-20-2023, 10:30 AM | #5 |
Drive Different
53
Rep 225
Thank you for picking this up. Not sure how I got to this diagram, but sorted it out with my VIN. You saved me from ordering a bunch of incorrect parts. Cheers!
11-20-2023, 12:15 PM | #6 |
Drive Different
53
Rep 225
For street use only, are there better pads and rotors than OEM that people gravitate towards?
11-20-2023, 03:19 PM | #8 | |
Rep 507
Drives: 2018 M2 6MT
https://f87.bimmerpost.com/forums/sh....php?t=1886659 |
xhado1.50 |
11-21-2023, 07:58 PM | #9 |
Rep 350
There are alternative pad options although I can't recommend street ones, I'm still on my original stock pads after many sets of track pads. For rotors, I don't think there are as many alternatives, I've seen listing for Zimmerman which are probably decent but the stock rotors are rather good.
Replacing the retaining springs or the pins (shown as #3 in both diagrams above) probably don't need replacing. The pins do need replacing eventually but it's after a lot of pad swaps but if you're simply street driving and swapping pads for the 1st or 2nd time then they will be absolutely fine. After probably upwards of 40-50 uses that's when the pins can start to get a little loose and can start to back out. Just cleaning the springs and pins and re-installing should be fine. |
11-22-2023, 01:43 PM | #10 | |
Drive Different
53
Rep 225
'10 E70 X5 35d* / '05 E60 M5 SMG* / '01 E53 X5 4.4i* / '76 2002* | '70 2002* *Gone Last edited by nszzya; 11-22-2023 at 01:49 PM.. |
gsrbri559.50 |
11-22-2023, 01:45 PM | #11 | |
Drive Different
53
Rep 225
The Akebono pads look great and were a fair bit less when I checked, but I'd my order had already shipped. Next time maybe!
jefe2000785.00 |
11-27-2023, 10:56 AM | #13 | |
The Seeker
14198
Rep 3,426
So many holes, so little time. by Andrew Thompson, on Flickr |
12-30-2023, 11:00 PM | #14 | |
Rep 3
jefe2000785.00 |
