M2 Technical Topics > Suspension | Brakes | Chassis > uneven brake pads wear on the front wheels
      11-10-2023, 08:14 PM   #1
XYoung
XYoung's Avatar
Drives: BMW M2C
At my last track day, last session the front brake was making grinding noise, so I figured something was wrong, the outside pad has >6mm thickness, and no brake sensor warning... so I still drove the car back home with the noise. Later I took off the drive side front wheel, see the picture attached, there was slanted inner pad wear, basically the top part is down to the metal plate, and metal to metal ruined my rotor too. The passenger side front is exactly like this, except it still has the last tiny layer of material on the top side of the pad. The rear brakes are totally fine, even wear inside and outside, no thickness difference. Has anyone seen this before?
My car is a 2021 comp, stock brake pads and rotors, ~6000mi, been on the track for 6-7 days, recently replaced the PSS tire with RE71RS, and added camber plate before the last track day, motul 600 brake fluid. before the failure, no brake vibration and any performance issue, actually I had PB from the last day (before the pad worn out on me). I am still learning the car, so I never turned ESC off completely, mostly MDM mode on the track, with the passenger, full nanny on.
Now I replaced the front rotors and front / rear pads - EBC bluestuff. It's an expensive lesson learned, never be lazy and skip the inner pad check.
The questions are:
1) since it's on both sides, I have less doubt on the caliper failure, or sliding pin/piston problem, but do I still need to take the car to an indy shop to consult? I bet dealers won't help much even within the warranty due to track use?
2) Is this due to some bad brake habit that I am not aware of? My understanding is MDM mode would trigger more on the rear brakes to avoid sliding, I don't know if it would impact the front or not.
3) the rotor still has almost the full thickness, is it worth resurfacing the rotor if possible? then I can save them as back up rotors.
4) if this is happening again, is it better to rotate the pads after each track day?
my friends have never seen this before, so I posted it here for help, really appreciated!
2021 M2C HS
Executive, DCT
      11-13-2023, 07:39 PM   #2
AUSf22
2693
Drives: 2020 M2C HS & Ferrari Roma
I must say that is very unusual wear indeed and I've never seen that before ... best to consult an indy.
2020 M2 Competition | Hockenheim Silver | 437M Wheels / 763M Wheels | RHD | 2NH Brakes
OEM M2 CS Steering Wheel | MP Carbon Steering Wheel Trim | MP Pedals | MP Dash | MP Interior Kit
OEM M2 CS Bonnet | M Performance Coilovers | MP Rear Spoiler | MP Rear Diffuser| Perl Carbon Front Lip | Remus Race Exhaust
chris7197393.50
      11-15-2023, 11:29 AM   #3
Apexeater
Apexeater's Avatar
43
Drives: 21 BMW M2 Competition 6 speed
Isn't that kind of wear related to a sticking pin?
      11-22-2023, 07:14 AM   #4
GtSport
Drives: F87N & F30
On this platform, there is a big difference in brake disc temperature outside/inside, especially in the rear:
I believe the same thing happens in the front without brake cooling.
chris7197393.50
      11-29-2023, 07:25 PM   #5
XYoung
XYoung's Avatar
Drives: BMW M2C
Thanks for the great info! I believe that's the issue.
2021 M2C HS
Executive, DCT
