09-05-2023, 09:50 PM | #1 |
Rep 83
Drives: 2018 BMW M2, 2021 GR Supra
Brake Pad Replacement
I see a lot of options on FCPEuro for brake pads but I'm wondering what's the best option for price? I'm in need of front brake pads, I'll change only the fronts of I don't have to do both front and rears at the same time. Rears are pretty good on durability left.
09-10-2023, 07:46 PM | #3 |
Rep 507
Drives: 2018 M2 6MT
I’ve also read a lot of good things about Akebono pads (for the non-comp M2) and Carbotech pads for the big 2NH brakes on the M2C/CS. Though, I don’t think either of them are rated for track use. So the answer to your question highly depends on how you use your M2.
chris7197393.50 |
09-11-2023, 12:30 AM | #4 | |
Remove Before Flight
6919
Rep 1,616
That being said, WHAT you replace them with matters. I'm a fan of staying with the same compound for front and rear, but there is a case to be made where a dedicated front track pad (e.g. Ferodo 1.1/3.1) could be paired with a rear (e.g. Ferodo DS2500)-- but they're still running the same compounds, just different formulations of such. And even then, I'd only do this for the track. As for track-- the DS2500 is recommended for *light* track duty. I've used them and burned them up doing HPDE's, but I had a tune and was running a fair bit more power than stock. After detune, the DS2500's were acceptable for HPDE, but I'd still consider them more of an "aggressive street" pad. R.
Current: M2C, Miata RF-GT, RDX & Element // R1200GS & VRSCF
Previous: M3, Focus ZX3-S2, Superchaged Solara, Samurai, Integra, Pinto & RX-4 // VRSCR, R6S, FZ1 & FZ600 |
