11-19-2022, 07:02 PM | #1 |
Rep 77
Downsides of bootmod or similar
My 2020 M2c is out of warranty soon, and I am wondering on the downsides of 40 plus hp, with your iPhone .
You know what I mean. Anyone done it to stock car ( maybe k&n filters} and can give a bit of feedback? |
11-23-2022, 04:57 AM | #4 |
Rep 3,227
11-24-2022, 02:53 AM | #5 |
Rep 77
“I have used it since almost day one with absolutely no issue.”
So day zero was the only day it was standard before you tuned it? I was asking how you could actually feel the 40 or so hp etc people say the tune does if you hadn’t had it in tuned for some time to appreciate the tune. Please explain if I am not interpreting your words correctly, |
11-24-2022, 07:28 PM | #6 | |
Rep 166
Drives: M2 LCI BSM
FWIW there are hundreds of people in here running BM3, myself included. The benefits are well documented. In my own personal experience, it made a marked difference to the feeling of pace and I love being able to remove all burbles or move them to high rpm/speed and super short duration. I did however get a strange type of throttle delay that is ony noticeable when driving around town in traffic, and wasnt enough to make me remove the tune.
M2 LCI - DCT - BSM | BM3 Stg 2 | Eventuri Intake | Fabspeed Sportscat | Wagner Evo 2 FMIC | Ohlins R&T | Rays | Recaro Sportster CS
terrywang95.50 mmmmQuattro259.00 |
01-05-2023, 06:45 AM | #7 |
I like the noises
11
Rep 9
BM3 is well tried and tested, I don't see alot of downside unless you are worried about the extra stress on the car that comes with increasing power.
I have been running BM3 stage 1 on my M2 for a few months now. It was certainly a noticeable change and I am enjoying playing around with the burble configuration, cold start, gts roar etc. Why not give it a go, can always revert to stock. |
01-10-2023, 05:40 PM | #8 |
Rep 557
Unless you track it's questionable whether you'll really use the extra HP but BM3 provides a lot more than just power, you can customise quite a few settings to your liking as well.
I have a custom tune (I started with less power than your M2C so the extra power is probably more useable), have custom throttle mapping to effectively delete the overly sensitive Sport+ map, burbles turned off, exhaust flap open full time and having a 6MT the Shift load drop fix significantly improved wot upshifting. |
01-10-2023, 08:45 PM | #9 | |
Rep 1,337
IMO they are two different things. I’m chasing the latter and hear crickets from custom tuners.
01-11-2023, 12:52 PM | #10 | |
Rep 7,340
Enabled might be a person who knows the answer to your question. |
01-12-2023, 04:52 AM | #11 | |
Rep 557
The user adjustable throttle sensitivity wasn't an available option when I had my tune done, I'm not sure of how it differs. |
MR RIZK757.50 |
01-12-2023, 08:44 AM | #12 |
Rep 1,337
chris719 I have a MT with a stiff ride setup. On poor roads at slow'ish speeds there are instances with the bumpiness of the road surface it will cause my foot to tap the accelerator pedal and subsequently the car will start bucking. Bit like when you start learning to drive a MT.
By decreasing the sensitivity it has helped in removing about 80% of the issue at slow speeds. The issue with the sensitivity setting is that it delays the time to throttle target for the whole curve. In simplistic terms think of a throttle curve which is static, reducing the sensitivity increases the time it takes to reach the target at a given point. The more the sensitivity is reduced the longer it will take to hit target. Too high of a value and the car becomes sluggish. Obviously it is far more complex than this and beyond my capabilities in understanding the calibrations available in the mapping tables. As the sensitivity setting affects the whole curve. I just want some mechanism to help with the slow vehicle speed high speed pedal inputs. Not sure if the above makes sense. The throttle sensitivity setting was tested by someone on this forum a while back and its affects.
chris7197393.50 |
01-13-2023, 07:52 PM | #13 | |
Rep 7,340
Can't you just put your foot down faster though? I understand what you're asking for but I think linear is almost always the way to go with controls. It is an interesting idea though. It's funny how everyone has different preferences because I think people with E90 328s were trying to get rid of this kind of behavior where the throttle tip-in was insensitive to smooth out the driving. The more I think about this, the more I like it if it's done gently. |
MR RIZK757.50 |
01-13-2023, 08:44 PM | #14 |
Rep 1,337
Correct. The suggestion above about the curve at a high level is what I’m chasing.
Since the phenomenon can happen in different gears and at different vehicle speeds the only user definable setting is the sensitivity. Trying to fake it in conjunction with torque reduction is not an option cause the issue isn’t only in 1st gear, can be second and sometimes 3rd. Again torque reduction is the same issue as I suspect it is just a offset of target torque.
01-13-2023, 11:13 PM | #15 | |
Rep 557
Except for very wet roads I exclusively use Sport+/MDM for spirited driving (mostly NSW/Vic alpine regions) & getting rid of Sport+ has been the best thing, so much more confidence getting on the power out of corners. |
terrywang95.50 |
