05-01-2022, 07:35 AM | #1 |
Rep 86
TCK coilovers/camber plate
So I just recently had tc Kline coilover kit installed on my 2018 m2. This also included two new adjustable sway bar links, and the tck camber plates. This is my first time upgrading suspension on a car.
The ride surprisingly to me was smoother, along with being far more responsive and planted through the turns. I’m looking forward to getting the car corner balanced and some summer rubber pit on to really see the grip level the car can produce now. With that being said, I do have some questions regarding the kit, mainly about noises that are new to the car and setup. I’m not here to complain, if the noises are normal that’s fine by me. I have read the camber plates can introduce noise to the cabin of the car. The noise I hear is most pronounced at slow speed going over harsh bumps. It’s a click, clunk clank type noise but when I checked to see if something was loose there was nothing I noticed. When the suspension arrived the sway bar links were delayed a week. Since I needed my car I drove it without the sway bar connected on one side. Once the adjustable links were installed the noise was louder and more frequent. So I’m either thinking it’s sway bar related or the camber plates, which everyone says the noise from coilover kits comes from. I just picked up the car yesterday so I’m definitely going to check with the shop on Monday and see what they say. My other is it could it be setup related and maybe there is too much camber or ride height to low causing the noise. I’ll add some pictures shortly. Thanks. Last edited by Dozer324; 05-01-2022 at 08:40 AM.. |
05-01-2022, 07:48 AM | #2 |
The Seeker
13998
Rep 3,361
From my research that's more of a specific type of suspension thing, as well as being caused by camber plates. I ended up going with the MPS and have no additional noise, except some clicking upon hard cornering (even though the pinch bolts were replaced and torqued properly).
05-01-2022, 08:48 AM | #3 | |
Rep 86
Cabin noise from the road would be expected, but that is not what I’m referring to. Maybe I can get some video of the noise. |
05-01-2022, 09:26 AM | #4 | |
Rep 857
05-01-2022, 09:34 AM | #5 |
Rep 86
05-02-2022, 11:15 AM | #7 |
Rep 647
Wondering this as well. I have a TCK kit going in this week so I’ll report my experience here. I have the “quieter” single adjustable fronts for what it’s worth.
05-03-2022, 02:03 PM | #9 |
3885
Rep 54,481
Drives: F80 M3
DA fronts are known to be noisy. A common kit is to use SA front and DA rears. You will also get increase in NVH with camber plates. If you the click and slight clunk is only limited to low vehicle speeds, you are good to go.
05-04-2022, 07:58 AM | #10 |
Rep 86
Yes, I got the SA front and DA rear. The car drives great so I’m not too worried.
05-05-2022, 07:50 AM | #11 |
Rep 408
I 've been running the SA front DA rear kit with the camber plates (no sways) for over a year and I don't recall experiencing those noises you've described at low speeds over harsh bumps. However a recording would be great if you've got one and I can tell you for sure if I've experienced similar sounds or not. However, it could be just increase of noise due to the camber plates. The worst noise is at high speeds over uneven metal expansion joints on highways. Sounds like a harsh metal on metal impact noise.
05-05-2022, 08:28 AM | #12 | |
Rep 86
The harsh metal to metal type sound you hear I’m guessing is the same sound I’m hearing, but I will try to get a video. |
05-05-2022, 11:07 AM | #13 | |
3885
Rep 54,481
Drives: F80 M3
05-05-2022, 01:54 PM | #14 |
Rep 312
I'm going to start by saying that I think its a coilover thing. Not that there are defects with the coilover but a noise as a result of just having coilovers. I have KW V3's with GC camber plates and I am experiencing the exact noise going over bumps at low speed or dips at high speed. I have taken off the camber plates and that noise goes down significantly but not completely away. Everything is solid and tight and car handles like a dream. I'm going to tinker with the dampening to see if anything helps.
05-07-2022, 08:22 AM | #17 |
Rep 86
05-07-2022, 08:57 AM | #18 |
Rep 100
I had noises like these develop on my TCK setup some miles in. I tightened the camber/toe eccentrics, the lower shock mounting bolt, and used the correct swayer end link washers TC Kline provided all in one go, and the noises went away, forever. Not sure which of the things was the culprit but you may want to check essentially all the bolts that were touched during install. I definitely thought my noise was up front but I did more bolt checks in the rear. But since I did it all at the same time I'm not sure what fixed it.
05-07-2022, 09:06 AM | #19 |
Rep 203
Based on your video, sounds like you have some play/ movement in the camber plates/ strut connection areas as it sounds similar to when the strut top nuts on my Ohlins in a previous car was not torqued down properly. Perhaps strut top nuts needs to be re-torqued. It's either that or some play in the end links as HP Autosport pointed out.
05-07-2022, 11:07 AM | #20 |
Rep 35
Drives: LSB E46 M3, AW F87 M2, Model 3
It sounds like there is some play between the front struts and camber plates. Tighten the top bolts of the Koni struts. Real tight(proper torque). Also, apply few drops of red locktite.
I added helper springs in my set up for tighter fit.
I have a white f87 m2 and a blue e46 m3
05-07-2022, 02:16 PM | #21 | |
Rep 647
We’re you getting noise like this prior? |
05-07-2022, 02:18 PM | #22 |
Rep 647
When you say no sways did you remove sway bars or are you saying no aftermarket endlinks?
