04-25-2022, 07:12 PM | #1 |
Rep 63
2018 M2 brakes squeal only when beginning to push on the pedal
Hi guyz
idk whats going on but my 2018 M2's brakes squeal when I initially start to push pedal about the first 20% then the noise stops if i push harder the car has like 10,000 miles spo i dont think the pads need replacing, idrive says the brakes are due in 90,000 miles lol pics of rotor and brake attached
2018 M2 LCI Long Beach Blue
Options: DCT, Carbon Fiber Winglets, M Performance Carbon Fiber Diffuser, M Performance Exhaust, Apple Car Play and those door lights that project the M logo on the ground when you open them lol |
04-25-2022, 07:51 PM | #2 |
The Seeker
14158
Rep 3,415
This is a common complaint. The previous owner of my car complained at 9,000 miles and they replaced her pads and rotors with new ones. I had no issues when I got the car. However, I also swapped to Akebono's immediately to preserve my rotors, have less dust, and have less noise. If you don't track your car I highly recommend them. If you do track your car, sorry, I can't help you.
04-25-2022, 08:02 PM | #3 | |
Rep 63
04-25-2022, 08:20 PM | #4 |
The Seeker
14158
Rep 3,415
PresidentEvil42.50 |
04-25-2022, 08:41 PM | #5 |
Rep 63
thanks, just bought some
///MPhatic14158.00 |
04-25-2022, 10:41 PM | #6 |
Rep 165
04-26-2022, 08:04 AM | #7 |
The Seeker
14158
Rep 3,415
Maximus_M2242.00 |
04-26-2022, 03:02 PM | #8 |
1029
Rep 842
No need to buy new pads. Just re-bed the ones on the car. Do a series of stops that will get the pads hot enough to stick to the disc face. That should quiet them down considerably.
04-26-2022, 05:21 PM | #9 |
The Seeker
14158
Rep 3,415
And help kill your rotors in the process. I realize you're trying to help, but increasing rotor wear isn't the way for a street car, news pads are.
04-27-2022, 07:07 AM | #10 |
1029
Rep 842
Iron discs can handle a tremendous amount of abuse. Bedding them in does not kill them. Quite the opposite in fact. When you heat them up in the manner as described in the video, you lay down a pad transfer layer on the discs that improves performance, reduces noise, and helps ensure longer overall disc life.
gsrbri559.50 speedsnice1209.00 |
04-27-2022, 08:17 AM | #11 | |
The Seeker
14158
Rep 3,415
That excessive brake dust you see from the stock pads is ROTOR, not just pad, as BMW sees rotors as sacrificial. Stock rotors are $1400, and have 1.6mm of wear before replacement. For a street car ceramic pads are a must, as they are superior in every way. |
04-27-2022, 08:25 AM | #12 | |
1029
Rep 842
That is different from cleaning discs by running race pads on the discs on them cold, which scrapes a ton of material off the disc face. 'Ceramic' pads are more of a buzzword than anything else. Most of the pads labeled as ceramic are indeed mild and tend to not chew the discs up very much. That said, there are all sorts of mild brake pads made from a wide range of materials. For a street car, what you absolutely do not want is a race pad designed to operate at high track temps. When cold they act in a highly abrasive manner and will eat discs for lunch. |
04-27-2022, 09:32 AM | #13 |
The Seeker
14158
Rep 3,415
04-28-2022, 06:42 PM | #15 | ||
Rep 143
04-29-2022, 02:26 PM | #16 |
Rep 570
If the car has stock pads, I recommend the following:
1) if it's not a daily driver, be careful of washing the car and then putting it away without getting heat into the brakes so they can dry 2) pull the brakes apart. Specifically, remove the pads from the calipers. The retention pins need some lubrication for the pads to slide properly. They brakes will squeak and eventually groan when stopping if you let this lubricant dry up and/or wash off. I posted previously on this, to include photos. My brakes make zero noise under all conditions (unless I swap-in racing pads…and then they are loud) Bedding slightly isn't a bad idea, either. Although I don't believe you're hearing a brake pad to rotor surface harmonic. You are hearing a vibration translated into a harmonic because of non-lubricated caliper pins. Good luck |
06-04-2022, 12:10 PM | #17 |
Rep 166
hi - I have a street only 2017 M2 w ~44K and would imagine I am going to need brakes soon. the brake dust is and always has been insane. don't know who made the oem stuff I am running. what exactly would you recommend for me. I live in LA if that matters. my driving is a mix of city/highway. Akebono pads seems to be obtainable, should I get those and what rotors? do I replace the front/rears at the same time? thank you!
06-04-2022, 06:52 PM | #18 | |
The Seeker
14158
Rep 3,415
2. I like the stock rotors, get them from Evan@Tischer at Getbmwparts.com 3. Replacement depends on wear. You need a set of calipers to gauge what you have left on the fronts and rears. They start out at 30mm front and 24mm rear, and only give you 1.6mm of wear, so you'll have to check them for minimum thickness. This isn't a hard thing to do at all, just get yourself a set of calipers, take the wheel off, and be detailed in checking it. You might not need rotors at all. |
Evan@Tischer3515.00 |
06-05-2022, 01:35 PM | #19 | |
Rep 166
06-05-2022, 03:12 PM | #20 | |
The Seeker
14158
Rep 3,415
06-06-2022, 12:31 PM | #21 | |
Rep 166
so pads and rotors, I am set on what to get - your opinion on the below. I was going to skip the bolts, seems like a waste of ~$60 but I am open to your opinion on it. Mucho thanks! BMW Brake Disc Set Screw BMW Brake Caliper Carrier Mounting Bolt ATE DOT 4 SL.6 Brake Fluid (1 Liter) |
06-06-2022, 02:40 PM | #22 | |
The Seeker
14158
Rep 3,415
I bought new bolts, but I've never heard of anyone having an issue, so that's your call. |
