M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > No heat/ low coolant
      02-03-2022, 03:46 PM   #1
NY135ivishnu
Drives: 2009 bmw 135i
Today while driving I got the alert that the coolant was low.
As soon as this happened I turned on my mperformance steering wheel and noticed the following.
- oil temps were normal 220 normal mode 190f under m2 sport mode.
- water temp 220f under normal mode and 170f on m2 mode. While giving the engine load the water temps would go up. The highest I noticed was 235.
I also noticed the car wasn't providing heat into the cabin no matter the temperature I set it to. Center wheel near vent was set to heat/ red. Temps on HVAC were set to 84f. AC off.
I was only a couple mins from home. When i arrived I filled both tanks with bmw fluid that I had and distilled water with correct mix ration. 60/40. I couldn't locate a leak anywhere. I don't have any errors according to the bmw diagnostic window.
I've searched all over the Inter webs and can't find anything concrete. The car is a 19 M2C with 44k miles. Any have this issue ?
      02-03-2022, 11:33 PM   #2
OGM2
Drives: F87 M2 AW DCT MPS,N180 4Runner
Perhaps this may be the problem
https://f87.bimmerpost.com/forums/sh....php?t=1579409
      02-04-2022, 02:42 PM   #3
NY135ivishnu
Originally Posted by OGM2 View Post
I found the issue. It's the driver side aux radiator seems to have a hole or something.
