01-30-2022, 12:54 PM | #1 |
Rep 13
Drives: 2018 M2 LCI
87 Fuel by mistake
I was not paying attention and accidentally filled up my F87 with 87 fuel. Should I siphon it out, or will I be fine with just one tank?
2018 M2 LCI, Long Beach Blue
01-30-2022, 01:10 PM | #2 | |
Rep 264
Edit: Even better if you have access to high octane race gas…couple gallons will get you back to premium levels. |
01-30-2022, 02:08 PM | #3 |
Rep 224
I just did the exact same thing. This car does not like 87 that’s for sure. I just left it in and topped it off when it got down to 3/4. I’ve done this twice now and still had a 1/4 when I had the brain fart so I will top it off once more at 3/4 before running it down. It’s already not noticeable but prior to the first top off it was noticeably coarse and less power/responsiveness.
01-30-2022, 02:24 PM | #4 |
Rep 7,542
The cars smart enough to adapt by pulling timing, but you must baby it like crazy to ensure no major knock events damage the engine. Also make sure you don't have low rpm, high gear, high load events because LSPI with low octane fuels would be devestating.
A can of octane booster would help if you had some available locally, just make sure the octane booster is good and not a bad brand.
01-30-2022, 02:24 PM | #5 |
this is the way
18468
Rep 8,589
If you have a full tank just pour in some octane booster and go easy on it. Top it off as soon as your burn off a couple of gallons with high octane gas and you'll be fine.
01-30-2022, 03:44 PM | #6 |
22357
Rep 8,738
I'd siphon that gas into somebody else's car And then I would follow up with some BMW fuel system cleaner prior to properly filling up again
01-30-2022, 03:52 PM | #7 |
Rep 7,542
You can't siphon these cars anymore, bmw put something in the fuel filler neck that prevents tubes from going down into the tank.
01-30-2022, 04:04 PM | #8 | |
22357
Rep 8,738
Can you drain the tanks content from below ⁉️
01-30-2022, 04:27 PM | #9 | |
Rep 7,542
1. Take off the lpfp hat and you have access directly into the tank from inside of the car. 2. Disconnect the lpfp line and turn the car on into accessory mode and let the lpfp pressurize itself and that will cause fuel to drain. I am not sure if the pump cuts off eventually so you might have to cycle the ignition alot. 3. if you have an inline fuel filter like the one bend calibration sells there is a bung on it that allows you to depressurize the fuel line and that will allow you to empty the tank like method 2 but you don't have to disconnect anything.
///M TOWN22356.50 |
01-30-2022, 05:16 PM | #10 |
your average JAMF
3196
Rep 4,116
Just take it easy on this tank, and/or add some octane booster if you're really paranoid. Complete waste of time/money to drain the 87. IMHO.
'21 M2 Comp
'19 Golf R |
01-30-2022, 06:12 PM | #12 | |
22357
Rep 8,738
But I'd definitely stick a small bottle of BMW fuel system cleaner in before I refill the tank just to make myself feel better
01-30-2022, 07:20 PM | #13 |
Rep 842
Run it to near empty, pop a bottle of octane booster, fill up with premium, and you'll be fine. Do this for the next 2 or so fills if you're still concerned.
These tanks are small so you'll be back to the gas station before the end of the week. |
Mark2016MG48.00 |
01-30-2022, 08:05 PM | #14 |
a coffee drinker
96
Rep 162
Not to worry. Don't flog the beast (the car) and, as mentioned previously, the gas tank is so darn small that topping off with "Supreme" and you will be fine in no time all. So will the engine.
For sh*ts and giggles: 87 octane on bimmerpost.com Click and Clack Last edited by Zeese; 01-30-2022 at 11:08 PM.. |
01-30-2022, 10:26 PM | #15 | |
Luxury at the redline :)
9108
Rep 7,563
It sucks BMW took that away from future generations.. 😂 |
01-30-2022, 10:36 PM | #16 | |
Rep 7,542
The other methods to access the fuel tank (remove lpfp) while the tank is full is pretty dangerous so yeah no real means to empty the tank except driving it. So I use some good fuel stabilizer to help mitigate the effects of winter storage on the fuel.
Poochie9107.50 |
01-31-2022, 03:33 AM | #17 | ||
9108
Rep 7,563
Unrelated question, can you still "push/kick start" a modern manual BMW? Where when the battery or starter is dead, you can still power up the engine, by letting the car roll, shift into second gear and pop the clutch - thus, starting the vehicle without using the ignition.. https://en.wikipedia.org/wiki/Push_start |
01-31-2022, 04:22 AM | #18 | |
Rep 7,542
So what I think would happen on a BMW is that you'll have it in accessory mode because you can't start It and a failed start would resort back to accessory mode not that start position the Honda was in (this is the part it should hinge on), you'll roll it in a gear then when you let out the clutch the car will slow down and stop. It will not start because you were in accessory mode to begin with and you have to click the button again to start, but you can do that with the clutch pedal pulled out a bit. So I don't think it will work on a BMW, but I've yet to try and probably will never try, as if the battery is dead I have equipment to jump start it and get it in my garage while I prepare to install a new battery.
Poochie9107.50 |
01-31-2022, 09:10 AM | #19 | ||
Rep 1,054
E92 335i 6MT | Balloon White | Black Dakota Leather - Sold
PROcede Rev3 V5 | AE Quad Exhaust | BMW Performance Short Shift Kit | Gunmetal 19" M3 GTS Wheels | BF Goodrich g-Force T/A KDW 2 | AST 4100 Coilovers | Swift Springs F:280 R:560 | ER Charge Pipe | Tial Blue BOV | VRSF 3" Downpipes | VRSF 7" Intercooler http://www.e90post.com/forums/showthread.php?t=782212 |
Poochie9107.50 QuarterMileJoe9.00 |
01-31-2022, 01:56 PM | #20 | |
Rep 7,542
01-31-2022, 04:12 PM | #21 | |
Rep 211
Drives: 2021 F87 M2 Competition
2021 F87 M2 Competition, Sunset Orange, 6-speed
2010 E60 535i xDrive, Space Gray, Auto (sold, but still in the family) |
01-31-2022, 04:20 PM | #22 |
Rep 7,542
I guess it is possible lol! That is good to know.
