06-16-2018, 04:53 PM | #1 |
Rep 328
BootMod3 Stage 2 Race Gas Log
2018 M2 DCT
Wagner Performance EVO2 Intercooler VRSF Catless DP 3" Cut out on factory non-MPE exhaust NGK 97506 gapped to .020 Just did a quick 4th gear pull, HPFP keeping up and NOT dropping! Hot as Hades here in ATL, pulls hard with no noticeable break up above 5K RPM that I was experiencing on other tunes (plugs probably solved this). Should be making close to 400WHP if not more, I'll dyno at Technica Motorsports to verify, feels nasty, not as nasty as my 966WHP M5, but damn strong! Gauges in car show 460FWHP and 430FWTQ. Those that understand logs please chime in. 1.5 cans Torco + 93 at fill up. http://www.bootmod3.net/log?id=5b2581e1d10b4304d3cee32d Last edited by M-Supra; 06-16-2018 at 10:32 PM.. |
06-16-2018, 07:53 PM | #2 |
Rep 4,203
Overall it looks strong from my perspective but the pull is too short. How much Torco you running? What was the ambient temp
Do a longer pull...start your pull at 2k all the way to 6.5k. That will put more load on everything and give a better picture plus IAT's will increase. Always do pulls like that. And if you can do a 3rd, them 4th and then a 5th..... |
FSociety3812.50 |
06-16-2018, 10:29 PM | #3 | |
Rep 328
1.5 cans Torco + 93 at fill up. Thanks for your guidance! Cleve |
06-17-2018, 08:36 AM | #4 | |
Rep 4,203
06-17-2018, 09:28 AM | #5 | |
Rep 328
1-32oz can should be sufficient for our small tanks but due to heat in ATL, I added another 16oz for margin |
06-17-2018, 01:39 PM | #6 | |
Rep 328
Just did this pull getting on 400N, its 98 degrees according to car thermometer and high humidity, ATL is approximately 1000' ASL http://www.bootmod3.net/log?id=5b26a977d10b4304d3cee4f5 |
FSociety3812.50 |
06-17-2018, 03:54 PM | #7 |
IG @bmwF9xG80
3813
Rep 7,593
According to Demon owner he uses Boostane 8oz + 5gals of 93 for 100oct.
Obviously you need a little more for Torco. Did anyone reach out to Torco to see what is required for Turbo applications?
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 Last edited by FSociety; 06-17-2018 at 04:02 PM.. |
06-17-2018, 04:09 PM | #8 |
Rep 4,203
Interesting...the race gas map targets maybe .5-1 psi more boost than the stg 2 93 but it allows more timing advance. Your up in the 11-12 range but it was pulling back timing late in the 4th gear pull but no knock was registered.
I like your IAT's you had a +18 deg increase on your full pull. I did a similar pull on the stg 2 93 and had a +28deg with just the 5in stepped HD core IC and stock DP. I wonder if it is the catless DP that is helping you with slightly cooler turbo temps, don't think the Wagner Performance EVO2 is doing it all its self. Anyway fuel pump is stable |
06-17-2018, 05:01 PM | #9 | |
587
Rep 898
For sure this map requires a strong healthy FBO car with _VERY_ good octane. It also has some throttle safety disabled ( to prevent throttle closure on slight overboost )
06-17-2018, 06:19 PM | #10 | |
Rep 328
06-17-2018, 06:22 PM | #11 | |
IG @bmwF9xG80
3813
Rep 7,593
Whats your mixing ratio? The last log you posted looks great in my opinion, booster is meeting the timing. Something I did learn was these folks only use octane booster for track days as it may leave orange residue in your plugs and exhaust tip in long use period of time. But adding a bottle of techron should clean it up.
06-17-2018, 06:50 PM | #12 | |
Rep 328
Since so hot here, I mixed 1.5 cans (48oz) Torco with balance being 93 pump. I don't think I need this potent of a mixture but was being extra cautious. 1-32oz can mixed with 10 gallons 93 equates to 103 based on Torco ratio chart. Not on BM3 group but would love to be, where do I find? Thanks, Cleve |
06-17-2018, 07:20 PM | #13 | |
IG @bmwF9xG80
3813
Rep 7,593
Do you have a Dragy ? Performance Meter https://www.facebook.com/groups/bootmod3/
06-17-2018, 09:03 PM | #14 | |
Rep 328
http://torcoracefuel.net/2-docs/acce...r-ratio-93.pdf On stock tune with Wagner IC, Wagner 200 cell DP, and 3" cutout she made 368/411 on Technica Motorsports' dyno. She made 381/445 with above mods and Turner Power Module on same Dyno. BM3 Race Gas Tune feels much healthier/stronger than above. Ill check FB, thanks FSociety! |
FSociety3812.50 |
06-17-2018, 09:05 PM | #15 | |
IG @bmwF9xG80
3813
Rep 7,593
06-17-2018, 11:15 PM | #17 |
Rep 328
Launch control from shoulder on entrance ramp going slightly uphill, cooler now, approximately 84-85 degree evening.
http://www.bootmod3.net/log?id=5b272ce7d10b4304d3cee608 |
06-18-2018, 03:34 PM | #20 |
Rep 2,577
400whp is a understatement. Your car would smoke anything on stock turbo without meth that's ever posted on F87 forum.
I had a feeling you're a bit faster than my Dinan turbo on 93AKI. Congrats!
Lemania 2320
FSociety3812.50 |
06-18-2018, 04:08 PM | #21 | |
Rep 328
Is there any way to decipher acceleration times from logs? It also appears that stock turbo is maxed out around 16-17psi on this tune at the top of 4th gear due to 100% wastegate duty cycle (cant push anymore exhaust through turbine), is this assumption correct? I'll be doing PS2 some point in the near future. Cleve |
FSociety3812.50 |
06-18-2018, 04:30 PM | #22 | |
Rep 4,203
FSociety3812.50 |
