04-10-2018, 07:29 AM | #1 |
Rep 76
Weight of HRE FF01 Vs OEM
Hi all,
So I'm thinking about the idea of changing to the HRE FF01 wheels but I'm a little worried about the impact of the extra weight. For all those that have changed to slightly heavier wheels what is the impact to ride/performance like? Many thanks |
04-10-2018, 04:03 PM | #2 | |
Rep 1,339
19': 22.4 lbs Front/ 22.6 lbs Rear 20': 23.8 lbs Front/ 24.6 lbs Rear 437M 19': 23 lbs front/ 23.37 lbs rear If you are considering 19' they are lighter than stock 437M. Weight should be considered along with tire weight. If you are considering fitting the same tires, then mind only wheel weight. Rotational force and inertia becomes very huge even there is 2 lbs different in front (both right and left) when you are comparing heavier and lighter tires. I dont want to go too deep into physics class and you can find those on youtube easily. Here is the one example of weight of front (7.5 lbs per a wheel+tire set) and the rear (7 lbs per a wheel+tire set) bringing huge difference in acceleration high MPH pull + breaking distance. We are not talking about 7.5 lbs difference (unless you are looking at changing 20' wheels with wider aggressive setup). But 1~2 lbs still will contribute to difference that your buttdyno will be able to tell such difference. Edit*: Picture only shows the straight line figures but cornering will be affected as much as straight dragstrip. |
04-11-2018, 01:50 AM | #3 | |
Rep 76
Interesting maybe I had the wrong information, i had the OEM weights as : Front 19x9 21.1lbs Back 19x10 22.7lbs Corrected/ Checked - Front 21.9lbs, Rear 22.5lbs Plus i then had the HRS coming in at: Front 19x9 23.8lbs Corrected/ Checked - 23.4lbs Back 19x10 24.40lbs Corrected/ Checked - 24.5lbs Hence i thought slightly more weight to them Will double check the figures Thanks Last edited by spookyzeus; 04-11-2018 at 02:30 PM.. |
12-29-2023, 07:59 AM | #4 | |
Rep 68
01-12-2024, 08:03 AM | #5 |
Rep 422
Where do they call these wheels "lightweight"? In comparison to their forged wheels these are very heavy.
01-15-2024, 02:23 PM | #6 |
Rep 5,931
HRE does not market their FF wheels as being lightweight. Their FF wheels weigh what a typical flow forged wheel weighs (+/-1 lbs or so based on design differences). Their FF wheels are made by Enkei (still believe this is true?) so it has good strength and quality for flow forged. I have a set of FF15 which were used for three years without issue. However, get a set of their R101LW forged monoblock wheels (17 lbs for 19” diameter) if you’re concerned about wheel weight. I noticed a huge difference between unsprung weight and steering response with my 19” R101LW vs 18” 513M. FF15 had a much smaller change between them and the 513M, not enough to impact ride quality or steering differences (which will go unnoticed between the FF01 and 437M.
01-19-2024, 08:16 AM | #7 |
Master Baiter
4173
Rep 631
Drives: 18 M2
I inquired to HRE about the FF01 for my car before I ordered Apex and they replied and said they didn't make FF01 to fit the M2. I didn't argue with them, because I have seen FF01 wheels on an M2. They lost a sale with that though.
FYI, if you get an infraction in the off-topic section, you can never visit that section again. |
