01-11-2018, 07:51 PM | #1 |
Rep 2,560
Drives: Rapidly from A to B
I thought I'd start a thread similar to that in the 1Addicts group that captures everyone's fitments. I found it real useful when I owned a 1 to help me understand what works and what doesn't. So add your fitments including wheel size and offset, tires size and type, any suspension or alignment details, and any rubbing issues or requirements to roll or pull your fenders. Please post your specs here in the format below. Also, UltraMagneticAL pulled together a filterable spreadsheet that we you can look at to see what has been done. Between us and other volunteers we'll try and keep it up to date based upon your posts. Here is the link to the sheet.
https://docs.google.com/spreadsheets...PeI/edit#gid=0 Wheels: Advan RS2 19x9.5 et 35 square. 7.5mm spacer in front. Front: 19x9.5 ET 27.5 with 255/35 - 19 RE-71R Rear: 19x9.5 ET 35 with 265/35 - 19 RE-71R Suspension: Stock initially but now at -2.5 camber with TC Kline camber plates. Comments: No Rub at either stock settings or obviously with the -2.5 camber dialed in. Last edited by Pyrat 2; 01-13-2018 at 10:37 AM.. |
01-12-2018, 05:26 PM | #3 |
Meh
926
Rep 781
Drives: M3CS & Cayman S
what wheels? let's go ahead and add that info too. I'm making a Shared Google Doc that everyone can see. I can give a few people access to update it as well.
01-12-2018, 05:29 PM | #5 |
Rep 444
Drives: 2017 M2 6MT, 2022 X7 M50i
Subscribed.
I'm looking for track wheels on stock suspension with camber plates. Contemplating between square and staggered setup. Would love to hear what works and what doesn't. |
01-12-2018, 06:16 PM | #6 |
Meh
926
Rep 781
https://docs.google.com/spreadsheets...it?usp=sharing
here's the google sheet. Should be able to filter the data to find what you need. this list will expand once people enter more data in this thread. |
01-12-2018, 10:39 PM | #7 |
Rep 2,560
Wheel info added in original post.
01-12-2018, 10:54 PM | #8 | |
Rep 2,560
01-12-2018, 11:13 PM | #9 |
Rep 2,560
I've owned a number of BMWs over the past 15 years. Most have seen track duty. In general more square than stock or completely square has been my preference. However, the M2 might be different. I picked up my car at the BMW performance center in SC in 2016. It was the second M2 customer car to move through there. They were as excited as me to see this car. They had the advantage of having their hands on non clients M2s before full production M2s came through. When I asked two instructors about setup they both said the same thing - 'keep the stagger'. I questioned it because it was contrary to my e36, e46, e90, and e82 experiences. I bought square wheels and reduced the tire stagger from 20 to 10 and in hindsight am questioning my move. Next set of tires I am considering going back to a 20 cm difference between front and rear. The front end just turns in so well that frankly my setup has oversteer. Now I'm running -2.5 camber to save scrubbing my front tires. So that factors into my oversteer. Anyhow, assuming you are asking because you'll will track your M2 then I would say get a square wheel setup and play with the tire sizes as you burn through your tires.
01-13-2018, 08:11 AM | #10 | ||
Meh
926
Rep 781
AutoTalent2310.00 |
01-13-2018, 10:05 AM | #11 | |||
Rep 152
01-13-2018, 10:45 AM | #12 | ||||
Meh
926
Rep 781
01-13-2018, 11:00 AM | #13 | |
Rep 485
I need to raise my front a little anyway, as it痴 getting harder to clear a dip/ridge across the asphalt in the alley behind my house. |
01-13-2018, 11:16 AM | #14 | ||
Meh
926
Rep 781
01-14-2018, 07:33 AM | #17 | |
Rep 960
I知 still on stock spec with MP per coilovers so nothing to add from me. I知 debating F14 superconcave or something with a Lip (haven稚 decided if I build a set yet), but won稚 do anything till after the winter |
01-14-2018, 11:20 AM | #18 | |||
Rep 796
I have a feeling the RS4's might be a good durable track tire with more stick than what I'm used to, yet more quiet than the RE-71. Everyone loves the RE-71 though, so its though! |
01-14-2018, 12:00 PM | #19 |
Rep 796
Wheels: Forgeline monoblock GTD1 5 Lug. This wheel is derived from the GTD1 center lock race wheel developed for the Daytona/GTD class. Then modified to 6 lug/open lug for Viper customers/racers. They had a lot of interest for a 5 lug derivative and knocked down the spoke count to 10 for the GTD1 5 Lug. My favorite set of wheels I've owned by far! All business.
Im listing the specs including my spacers, Forgeline comp wheels have a center cap option but I liked the idea of using my turner Hub extending spacers to hide the hub, while having a safety net if I was too aggressive with measurements. They are flush with the wheel so I'm happy with the results. The spacers are 10mm front and none on the rear. A 285/35r19 on a 10" wheel at et33 is as far as I could push it without rubbing. Absolute max with that tire. I am stepping down to a 275/35 rear and will run my old 7.5mm or 5mm spacers out back. Front: 19x9.5 ET 21 with 265/35r19 RE-11 Rear: 19x10 ET 33 with 285/35r19 RE-11, ET28 with 275/35r19 and 5mm spacers. Suspension: H&R Coilovers, H&R sways F&R with Adjustable endlinks. SPL rears to come. TC Kline camber plates -2.5-3 front. Rear stock pin adjustment is around 2.25-2.4. |
01-14-2018, 03:22 PM | #20 | |
Rep 2,560
https://docs.google.com/spreadsheets...PeI/edit#gid=0 |
01-14-2018, 03:26 PM | #21 | ||
Rep 796
01-14-2018, 07:14 PM | #22 |
Rep 1,084
