M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > M2 STG1 Turbo Dyno Result - vs M2 Stock & M4 ZCP stock
      01-05-2018, 11:56 AM   #1
SeanWRT
SeanWRT's Avatar
3307
Drives: E90 M3 & F87 M2
Think it's approriate to start a new thread sharing some dyno results of mine and my friends'.
My car is a Euro Spec M2 MY2017 on FBO plus STG1 turbo on 98RON (93AKI), custom tuned by ProTuning Freak.
No meth, No PI, No ethanol. See more on my build link below.
http://f87.bimmerpost.com/forums/sho....php?t=1416389
All runs are on same day and same dyno. Numbers are corrected to STD Smoothing 5, to the liking of US guys here. As it's a cool day (ambient temp 50F, humidity 50%), heat soak isn't our problem. BTW, the uncorrected numbers would even be a bit higher, due to negative correction factor (cool ambient temp).
I'm running a progressive boost map. Not until 4000rpm do I apply more load than a typical N55 EWG OTS tune that nowadays could be found just everywhere and that goes flat out with boost surge at down low. My map starts to really shine from 4k5 up, pushing as hard as fuelling and octane allow and holding aggressiveness to redline, which is well reflected with a flat torque curve and a power peak at 6200~6300rpm - not your average N55 EWG tunes that stop making more from 5500.
Truth is, with a proper baseline, breaking 400whp is right next to impossible for a stock turbo N55 on pump gas. There is only so much you can do tuning around fueling and octane limit.
My baselines are as following:
1) M2 bone stock - 340whp
2) M4 ZCP bone stock - 396whp
3) The N55 1/4 mile record breaking (11.11@125mph) 335xi PWG PS2+Meth - 460whp, it holds 25psi and 10+ignition as log shows. Everyone else on here of similar setup pushing 25psi would definitely show you 500+whp. Too much hype on forum.
Let the pictures speak then
Lemania 2320
Appreciate 14
NO_USER_542.00
BAN_M2C4298.00
AngryBaby344.50
zenmaster1593.50
Dav31048.00
FSociety3957.00
ceedawg476.50
filet.M2c816.50
963mw350.50
bm3nyc56.00
      01-05-2018, 03:46 PM   #2
Yellowflash21
Slovenia
386
I would like to know 62-124 mph time if it's possible...
      01-05-2018, 04:44 PM   #3
ZM2
Drives: 2017 LBB M2
Nice work. What downpipe are you using? How would you compare your results to tehboosts’s FBO, no turbo upgrade on 91 octane results?
NO_USER_542.00
skier_du159.50
      01-05-2018, 05:47 PM   #4
NO_USER_
Drives: .
Awesome Sean! I like that flat torque curve!!
SeanWRT3306.50
      01-05-2018, 11:02 PM   #5
cookiesowns
cookiesowns's Avatar
603
2026 BMW M2  [0.00]
That area under the curve is really impressive. Nice work PTF!
BM3, MHD, ECUTek Calibrator | N55/S58 specialist | 2026 M2 6MT | 2026 BMW iX M70i
SeanWRT3306.50
      01-06-2018, 02:29 AM   #6
FSociety
IG @bmwF9xG80
FSociety's Avatar
3957
2022 BMW X3 M40i  [0.00]
2020 BMW X7 M50i  [0.00]
2023 BMW G80 M3  [10.00]
2020 BMW X4MC  [10.00]
16' BMW X4 M40i  [10.00]
06 Cadillac STS  [10.00]
Got a log of the runs?
My HCP PTF Map 16psi made 375AWHP 433AWTQ in 90F / Eurocharged Toronto Dyno when I took a family trip up to Niagara Falls back in September.
I suspect this NEW PTF OTS Map with all the new tables that was released after November has a better powerband since I also tested against some of my friends (Real World Testing on this side) but we'll see so far I managed with Dragy 0-60 4.19s and 1/4 mile 12.4@110 (beating my jb4 e30 records that only managed 12.8@105)
Current: 23'G80 + 22'X3M40i
Previous X7 M50, X4M, F90 M5, F80 M3
IG: @bmwF9xG80
SeanWRT3306.50
NO_USER_542.00
      01-06-2018, 09:13 AM   #7
velociti
Drives: 2009 E90 M3
I like that you went for top-end power over low-end torque. I don’t understand why so many people love the idea of monster low-end torque when the car physically can’t put it to the ground in the first couple gears. Nice looking powerband, man!
SeanWRT3306.50
      01-07-2018, 07:30 PM   #8
SeanWRT
SeanWRT's Avatar
3307
Originally Posted by velociti View Post
I like that you went for top-end power over low-end torque. I don't understand why so many people love the idea of monster low-end torque when the car physically can't put it to the ground in the first couple gears. Nice looking powerband, man!
I have very good reasons ditching low end torque.
1) Intake air heat
2) Fuel pump stress.
3) The RPM range on WOT is always above 4k, except on 1st gear where power is limited by traction anyway.
To me, low end boost makes nothing valuable but the bragging right of "Maximum Torque" on dyno paper.
Sure buddy, log sent you via PM.
I have not done 1/4 mile testing on STG1 turbo. But my stock turbo constantly did 12.3@115~116mph on 93OCT, beating your time already. haha
Originally Posted by ZM2 View Post
Nice work. What downpipe are you using? How would you compare your results to tehboosts FBO, no turbo upgrade on 91 octane results?
I'm using Euro 6 HJS 300 cell dp. I have a review thread on it. From testing on multiple M2s, we believe high flow and catless make no difference at these boost level. N55 is much more limited by octane, fueling and cooling.
Tehboost's 400whp was very solid. From his log, load is strong all the way to 5k5 rpm on exceptionally good timing for 91OCT (almost capped out all the time). No idea how crappy CA 91OCT holds up that well. I reviewed many other 380-400whp logs and knew they're nothing but hypes, compared to Tehboost.
At 5k5 rpm, Tehboost's peak power point, his boost was 1.5psi lower than mine (corrected to same IAT), but on slightly better timing. That should be some 10whp difference at that point to my guess, which means he'd be 390whp on my dyno everything else being equal.
Lemania 2320
NO_USER_542.00
      01-07-2018, 08:29 PM   #9
SeanWRT
SeanWRT's Avatar
3307
Below is a time I did in Oct 2017 on a conservative map. Probably I'd do 0.3-0.5s better with current map. But not tested yet.
Stock m2 does high 10s from the same testing equipment. BTW 140i stock does 11+s that I guarantee you.
Lemania 2320
Appreciate 4
      01-08-2018, 02:48 PM   #10
mike@x-ph.com
mike@x-ph.com's Avatar
Nice
https://x-ph.com/sale/
Phone number 725-221-5267
NO_USER_542.00
SeanWRT3306.50
      01-10-2018, 09:01 PM   #11
MTWO
Nicely done! Beautiful curve! It must feel really great pulling lineraly all the way up like that.
      01-10-2018, 09:51 PM   #12
Orange fever
Orange fever's Avatar
3688
Drives: E36M,E46M,E90M,X5M,i3,M2,i8,M2
very cool for a STG1 Turbo, since you're the first one
G87 M2 25 Frozen Pure Grey Metallic-Lightweight lip,Macht Schnell stud conversion,KW-HAS,Vorsteiner-VFX-001,Evolution Racewerks Resonated Midpipe,BMC Filters,Mishimoto Skid Plate,CSL Style Yellow DRL's,CS Flash
F87 M2 AW-Lightweight lip,Macht Schnell Springs,VF-Engineering/Hex tuning Stage2,ER DP,BMC Filter,AA Intercooler,FTP Charge pipe+boost pipe
      01-11-2018, 02:01 AM   #13
harkes
harkes's Avatar
China
1153
Drives: M135i, E39 M5, NSX and AE86
Haha I like how Li Wang just had to add the octane booster - I bet he didn't want to accept the 460whp
Great post Sean! Confirm what I have always been saying. Maxing out the PS2 will not net you 500whp - more likely 500 crank hp and change.
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China)
      01-11-2018, 08:35 PM   #14
SeanWRT
SeanWRT's Avatar
3307
Driving M4 all the time, I am familiar with S55 characters. It has a responsive bottom end and a torque blast from somewhere 3k~4k, all the way to fuel cut.
So my motor is tuned like a S55 except for a smoother and earlier power build up.
Lemania 2320
      01-11-2018, 09:28 PM   #15
SeanWRT
SeanWRT's Avatar
3307
You're with me. Always be conservative (or realistic) on numbers.
Wang accepted it, because making record with less power is something to be happy about.
Generally, hybrid turbo is overrated, even more so in N55 world where there's no real competitions as of yet.
Let me be completely unbiased by saying this - STG1 turbo is not a rewarding mod in terms of power. All it nets you is 20whp more in peak and a better top end.
Everything being equal, PS2 flows 3psi more, beyond that it's pushing turbo off efficiency. Plus it's already out of pump gas territory. So credit also goes to higher octane and cooling liquid. PS2 is less restrictive from turbine end for sure but god knows by how much. For 500+whp it's just a little too ambitious if your dyno reads right.
Lemania 2320
      01-15-2018, 08:36 PM   #16
MTWO
What’s the difference in spool up between Stage 1 and 2? You seem to have that boost dialed in really nicely with BM3 on a Stage 1!
      01-21-2018, 07:13 PM   #17
SeanWRT
SeanWRT's Avatar
3307
There is noticeably more wait on power with a STG2 turbo, especially from a back to back driving. Also much more power, make no mistake. I've said it many times - STG2 is every bit worth it to the most.
On stock BW turbo frame, beyond STG1 everything is a tradeoff - well I even thought STG1 compromises spool up a bit until log and dyno prove otherwise.
Along with power goal, you will want to think about what to give. To me, injection kit of any kind and flex fuel are no-goes. Which means, without DI fueling solution, I don't even consider STG2 as an option.
Lemania 2320
NO_USER_542.00
      03-29-2018, 06:59 PM   #18
ceedawg
ceedawg's Avatar
477
Drives: 2k15 335i xdrive MSport 6spd
Thats a beautful curve. Your car must have some nice topend!!
2k15 335i Msport xdrive 6spd
,FBO BM3 Stg 2
2k15 M3 6spd
,FBO BM3 Stg 2H2 tune with Hybrid turbs
NO_USER_542.00
      03-29-2018, 08:07 PM   #19
Mike0105
Drives: 2018 BMW M2
That's the perfect turbocharged power band if you ask me, nicely done!
Mike
NO_USER_542.00
      03-29-2018, 08:39 PM   #20
SeanWRT
SeanWRT's Avatar
3307
See below 100-200kph(62-124mph) time with current map. For comparison, our M4 GTS does 8.5s, consistently.
Lemania 2320
M2C_PLUS1813.00
      03-31-2018, 03:29 AM   #21
Lukeni
Very nice power delivery!
Do you think there are similar results possible (on a lower power level of course) without a turbo upgrade?
99% of all the tunes are losing power up top from 5500 rpm on to redline. I am looking for a tune which makes peak power up top at 6000-6500, but cant find any (except maybe active autowerke, but not sure about their dynochart).
My car is FBO as well. Fuelling won't be an issue since here in europe we got the good stuff.
Cheers!
      03-31-2018, 06:30 AM   #22
Daleb
Not bad for pump fuel. What is the quality of fuel like where you are?
Ever considered meth injection? Should see you nicely in the 7s over 100-200.
