10-07-2017, 06:52 PM | #1 |
Rep 228
M2 N55 Top End
Why is it that the N55 struggles to retain power at the upper rpm ranges? Unlike the B58 which keeps going strong all the way to redline, our N55 loses substantial power and torque as we approach redline. Is there any mods that can help remedy this? Thanks in advance.
10-07-2017, 06:57 PM | #2 |
Rep 4,733
I'm sure it has been discussed at length somewhere, but I'll throw in my two sense. Usually the loss in top end grunt it from a lack or air or fuel. I suspect that the turbo is the limiting factor. Likely a smaller turbo to minimize lag, but trade-off is top end pull.
rich8566608.50 |
10-07-2017, 07:06 PM | #3 | |
Rep 2,948
CommitConfirm474.50 rich8566608.50 |
10-07-2017, 07:21 PM | #4 |
Rep 549
Drives: The Bus
Heat. You can see the ECU pulling timing on the top end.
Fitting a FMIC allows the ECU to maintain timing for longer. |
BAN_M2C4197.00 |
10-07-2017, 07:22 PM | #5 | ||
Rep 1,644
10-07-2017, 07:51 PM | #6 |
Rep 5,394
I wouldn't say the N55 in the M2 is loosing a substantial amount of power in the upper rpms. Looking at numerous dynos, power peaks at around 6200rpms and holds until 6500rpms then falls over the 500rpms. Those last 500rpms aren't that significant. The calculated ideal shifts points for a stock 6mt are red line on the 1-2 and 2-3 and 6700rpms on the 3-4.
10-07-2017, 08:27 PM | #7 |
Rep 488
Drives: M2CS
The engine is perfect.
10-08-2017, 11:57 AM | #8 |
Rep 796
Well, maybe not perfect but pretty darned nice!
Other than the 'newer is always better' perspective, I have yet to see definitive evidence that the B58 is a significant improvement in the power ranges we are talking about. Bigger turbo means more tuning room - but also more lag. Closed deck means more cooling challenges. Modular construction means losing access to shared S55 parts. |
10-08-2017, 01:06 PM | #9 |
Rep 208
stage 2 hex, fmic, fabspeed HFC. Little rocket. How it should have been. Need M4 size rubber next. The smaller turbo keep the spool times real short, feels much more linear like a NA. The S55 is a beast at 7k rpm, but laggy in comparison down low. For street trim the N55 its pretty ideal and my setup really negates and criticism I could have had before. Pulls alll the way
Stock it was good, but a proper flash and some mods gets the best out of it, an epic epic M car. I have 25k miles now..... |
10-08-2017, 02:50 PM | #10 |
Rep 4,255
Someone drank the koolaid. There is plenty of room for improvement with the N55. Namely total cooling and turbo size.
Though you can see why the N55 was used. Much less laggy than the S55. We can excuse the S55 of this downside as M cars have always been a bit sluggish in the low RPMs except maybe the E39 M5. The M2 is a different beast. Personally I do think the B58 is all round a better unit.
///M Power
10-08-2017, 04:28 PM | #11 |
Rep 577
It's a combination of the frontal area and twin scroll turbo running out of puff! The heat issue is not that bad on the road, the car won't pull timing until 50deg c and above. Maybe in some hot countries cooling will be more of an issue but it would be simmilar for most cars.
If you can't get the air in you ain't going to get the power out! |
10-08-2017, 07:06 PM | #12 |
enthusiasm > practicality
4027
Rep 2,247
Drives: 987 CS | G35x
N55 is very capable. It just needs some massaging.
10-08-2017, 08:11 PM | #13 |
Rep 228
For a quick comparison. B58 Torque doesnt drop off til late and power pulls strong til redline. I know we didnt buy our cars for straight line speed but you can make the same argument about the M240i. It's a more superior engine. Either way rant over. I love this car.
10-08-2017, 10:44 PM | #15 |
Rep 931
I did a BMW M driver training day again last week, and we were driving M4s all day. To be honest, I didn't find there was a huge difference between the top ends of these and my stock M2. The M4 felt a bit faster, but that was strength across the range rather than it being significantly freer-breathing over the last 1500rpm - nothing like a VTEC honda or even the old V8 in the E9x.
Maybe our 98 Octane helps a bit?
John
17 F87 M2 Pure - long beach blue 10 E91 320d LCI - space grey - black dakota - steptronic - innovations - 157s - front PDC - Konis 99 BMW Baby Racer - red; 05 Renaultsport Clio 182 Cup - French Racing Blue - Konis - Eibachs - Remus - Turinis |
10-08-2017, 11:28 PM | #16 | |
Rep 436
10-08-2017, 11:45 PM | #18 |
Rep 796
M3 Adjuster7909.00 |
10-09-2017, 03:12 AM | #19 |
Rep 2,577
What a load of crap...Basically everybody created its own way of bragging about its car here above.
Speaking from experience in extensively testing on N54/55&S55 and a few B58s. Be realistic guys, compared to its competitions, N55 shines only on exhaust notes and reliability. NOTHING else as of yet. Top end...please wake up guys!
Lemania 2320
10-09-2017, 06:22 AM | #20 | |
Rep 931
Maybe if it made sense it would be easier. |
dtmurf486.00 |
10-09-2017, 06:53 AM | #21 | |
Rep 256
10-09-2017, 08:44 AM | #22 | ||
Rep 94
