BMW M2 Forum > M2 Photos, Videos and Builds > Gelbgrün by iND
      05-26-2017, 12:45 PM   #1
Nate@IND
Nate@IND's Avatar
2868
Drives: BMW
Gelbgrün by iND
BIMMERPOST
     Featured on BIMMERPOST.com
Sometimes, when we present portfolio cars to BMW fans, journalists, even people in the aftermarket industry we are greeted with confused expressions. Why would a business do this to a BMW M car? Why go through all of the effort? Aren’t M cars already some of the most impressively engineered machines in the world?
Many years ago, we at IND learned a simple truth - IND clients are those who seek the exceptional in every aspect of their lives, every day. From their own positions as business owners, parents, community leaders, and much more, our clients demand the exceptional from themselves every day. It is this truth that made us understand that our mission at IND is to deliver the exceptional as well.
Dedicated fans of IND understand that our Portfolio cars are designed to expand the limits of what’s possible, and to drive us to re-interpret already incredible M cars into truly unique machines. The IND M2 is no different.
BMW’s M2 is an interesting base to work from, specifically because BMW had intended to create a low cost alternative to the M4- most of the performance, few of the frills. In this way, it was a perfect canvas for an IND Portfolio car. The items left on the cutting room floor by BMW could be engineered and manufactured by IND and our partners, and would enable us to elevate the M2 from a sports car workhorse to a world-class performer capable of competing with even BMW’s own M4 GTS.
Our M2 is one of our most ambitious projects to date: few IND Portfolio cars have been subject to such extensive development, both of one-off components and production pieces. We knew that this M2 had to rival the M4 GTS and our own Ultraviolet M4, and so the bar was clearly set high. We began by designing the items that BMW could not create during their own development process.
The M2’s carbon fiber roof was perhaps the earliest step toward pushing the envelope for the M2 chassis as a whole. Creating the roof involved scanning the M4 carbon roof, obtaining the precise surface profile that BMW intended, and then re-tooling it to the M2’s less substantial dimensions. The RKP carbon fiber roof panel was created, forever transforming not only our M2, but also many of our client’s own cars. The carbon fiber roof was the first of many components designed to take the M2 from BMW’s no frills sports car into the realm of something truly special.
RKP chose to attack the front of the car from there, shifting their attention to the front lip. The M4 GTS front lip was carefully reverse engineered, re-scaled to fit the much narrower M2, and a completely fresh mounting solution was developed that would enable M2 owners to create a GTS feel and functionality with a much simpler installation process. Fall Line Motorsports contributed to the process at this stage by creating a front splitter that had the shape and adjustability of the GTS piece, but enjoyed the extreme durability of polyurethane.
The aggressive GTS style front lip is complimented by 3D Design side skirts and rear diffuser. Both items are constructed from pre-preg carbon fiber, and have a fit that must be seen in person to be appreciated. 3D Design has been a loyal partner for IND since 2011, and it is 3D’s commitment to perfection in manufacturing and design that has enabled us to exceed our client’s expectations whenever one of their aero items is installed.
IND’s next step was to retrofit the BMW M4 original mirrors to the M2, to elevate the car’s exterior to true M car status. In an attempt to create a lower cost performance car, BMW did not elect to install true M style mirrors on the M2 from the factory, a point that all of us at IND were very cognisant of each time we walked past the car. The original BMW M4 mirrors were carefully modified starting at their mounting base to be compatible with our M2. Once the mirror base fit the M2 properly, we moved onto the wiring. No mirror conversion is complete without all of the original functions in tact, and our M2 would have nothing less. The M4 wiring was modified to integrate with the M2 chassis wiring harness, giving our mirror retrofit full power adjustability and a power folding function. Finally, the European market M4 glass was installed for a wider visibility, finishing our conversion.
To complete the exterior of the car, we directed our attention directly to the BMW Motorsport catalog, and got to work.
M235R 24 hour foglights were a style centerpiece for this project, but were a challenge from the beginning. The original M235R race car has provisions in the bumper to install the fog lights, but for the M2 this was uncharted territory. IND created custom carbon fiber fog light mounts in-house, and carefully positioned the fog lamps in the front bumper. Extreme care was taken to sculpt the fog light mounts in a way that efficiently guides air to the car’s cooling systems- readers will be surprised to learn that the Motorsport fog lamps only conceal the end tanks of the M2’s front mounted cooler, and do not change airflow to the heat exchanger itself. A European foglight switch was installed in the car’s interior, and custom wired to activate the fog lamps with full factory functionality.
IND was able to source a BMW Motorsport M235R trunk, enabling us to also integrate the BMW Motorsport M235R wing package. While the M235R wing is a beautifully functional item as delivered, we felt that the appearance of the wing should be enhanced to truly fit the premium street and track feeling that our M2 deserved. A brushed finish was painstakingly applied to the RKP wing uprights, which were then covered in a tinted clear coat for a subtle appearance. Finally, Cartridge Limited carbon fiber endplates were installed to make our BMW Motorsport wing even more special.
At this stage we knew that our M2 would exude athleticism, and would be a car that would need to function equally well on the street and on a road course. IND’s design philosophy is in many ways very compatible with Porsche’s “RS” line of cars, and so we looked to Porsche once again to inspire the M2’s exterior color. After some deliberation, IND selected Porsche’s classic GelbGrün color. This color is special to us because it has been a Porsche staple since the 70s, and is in some rare instances seen on GT3 RS cars today. The nearly fluorescent green is a celebration of not simply Porsche history, but of Motorsport heritage in general, and to us recalls a time when sports cars were pure with few electronic assists and an engaging driving experience. It was this GelbGrün color that would guide us as we continued to develop our M2.
Of course, no IND Portfolio car is complete without it’s details. An IND black chrome exterior package was installed, complete with black chrome logo front grilles, black chrome side grilles, and a black chrome M2 emblem. Acexxon’s fantastic rear reflector delete was a key addition to the rear bumper, and was painted BMW gloss black to complete the rear of the car.
The M2 is delivered from BMW with a relatively austere interior, and it is in the interior that we felt we could truly allow our imaginations to soar. We knew we had to integrate a host of original BMW Performance and BMW Motorsport components in order to pursue an “OEM track model” feel comparable to the M4 GTS. Two items would become centerpieces for the theme of our M2 interior: the BMW GTS European seats, and the BMW Motorsport roll bar found in the MotoGP pace car. The European GTS seats boast incredibly lightweight and rigid carbon fiber shells, and are a perfect fit for a car that will see street and circuit duty. The MotoGP roll bar, painted GelbGrün is a key element of the M2, giving this car a measure of safety and also integrating the interior feel with BMW’s own approach to Motorsport-enhanced cars. An RKP rear closeout integrates perfectly with the MotoGP roll bar, adding refinement back to an interior that is now missing it’s rear seat.
The M4 GTS steering wheel was a natural addition to our M2, integrating perfectly with BMW’s GTS seats. AutoTechnik shift paddles offer easier access to up and downshifts, and were refinished in GelbGrün to add subtle color to an otherwise relatively dark interior. The GTS fire extinguisher was also added to complete the GTS interior feel. IND removed all original blue stitch from the M2’s door panels, center console, parking brake boot, and floor mats to more easily integrate our own GelbGrün color. Finally, we added a BMW Performance interior trim kit- an original BMW item that many will overlook, but is critical to creating an overall more cohesive interior. Custom programming from Alpine helped IND to eliminate the coding issues created by changing to the European GTS seats.
In spite of the already fantastic performance of the M2 as delivered from BMW M, we knew that our concept would have to offer something more. IND has never been concerned with ¼ mile drag strip times or lofty horsepower figures. Instead, our approach focuses on creating a balanced, dynamic, and beautifully driveable chassis that can be used in the real world. We knew that we had to create an M2 that would demonstrate an extreme level of competence around a race course.
To this end, we looked to ESS Tuning to give the M2 an increase in horsepower and response without overwhelming the chassis. ESS software focuses on tractability, a smooth and linear powerband, and boost figures that do not overwhelm the turbocharger, giving our M2 a newfound power and response while maintaining the car’s friendly and easy to drive nature.
Eisenmann’s engineers provided an exhaust system that improves sound and exhaust flow while also adding beautiful carbon fiber tips that perfectly complement our 3D Design rear diffuser. The Eventuri air intake complements the Eisenmann exhaust perfectly, giving this M2 an intake roar that is pure sonic bliss when the car approaches it’s redline.
Suspension, handling, and chassis dynamics are key to any IND Portfolio car, and this is the area where our M2 truly shines. The base for our M2’s suspension performance is the KW ClubSport coilover system. The triple adjustable ClubSport dampers are perfectly tuned for mixed street and track use, reducing unwanted geometry change dramatically while maintaining a shocking amount of compliance for both excellent traction and great ride comfort. The complete Fall Line Motorsports catalog compliments the KW coilovers and completely transforms the behavior of our M2. Fall Line’s spherical front control arm bearings dramatically reduce toe change under braking and sharpen the turn-in of the M2 when the driver enters a corner. The rear upper bearings and rear toe link reduce unwanted geometry change at the rear of the car and provide a much-needed means of adjusting toe with ease. Front and rear sway bar links enable us to properly corner balance the car and zero any pre-load found in the sway bars, and the camber shim kit allows for precise adjustment of camber with no movement of the camber setting under cornering load. RKP Corner Braces replace the original BMW items with more rigid pieces, adding more stiffness to one of the most critical areas of the car. Together, these items create a car that is easy to align, razor sharp in its steering response, and yet simple and safe to drive.
Of course, no amount of chassis and suspension tuning will help an inadequate set of wheels and tires, and we knew that our M2 would require a very rigid wheel set, coupled with tires that were able to keep up with this car’s increased performance envelope. IND has had the privilege of being aware of BBS’ new RT88 wheels when the product was still in it’s early planning stages, and all of us have been excited about the new RT since. The RT was an excellent choice for the M2 because of the wheel’s ability to combine an extremely rigid BBS Motorsport-derived center design with the uniquely strong one piece barrels from a BBS LM or LM-R. This allows for excellent control of the tire contact patch under load, and contributes to the M2’s dynamic behavior. The RT88 wheels were custom finished by IND in a multi step process: first, the wheel is sanded to a bare aluminum finish, then each wheel is individually brushed by hand, and finally a beautiful dark tinted clear coat is applied to both the wheel and billet aluminum BBS center cap for a completely unique look. Michelin Pilot Sport Cup 2 tires in 265/30/19 square sizing give the IND M2 incredible front-end feel, and provide very high mechanical grip at all four corners. A Macht Schnell extended stud kit and Project Kics lug nuts fasten the wheels securely to the car and allow for easy removal and installation.
Finally, the car’s performance envelope is rounded out with a Brembo GT brake kit. IND chooses Brembo over all other brake brands time after time because of Brembo’s unwavering commitment to build quality and after sales support. Brembo is the only brake manufacturer in the world to own several metal foundries, producing their brakes to the Brembo standard all the way up from the base material itself. Brembo’s GT kit provides a larger swept pad area than the original BMW caliper and a much higher efficiency disc, giving the M2 a stronger ability to vent braking heat. A myriad of performance pad choices enable an M2 driver to set the brake system to any possible driving condition, from outright street use to endurance use at a track.
So finally, what good are all of these parts? Is our M2 a sum of its components? Are we simply installing parts for the sake of having a longer list of modifications? In our view, no, that is not the case. As tuners, it is our role to provide excellence where BMW was not able. Original manufacturers like BMW can only go so far before their budget runs out- they have to make a profit, after all! For that reason, BMW created the M2 as an excellent performance value, but was not able to integrate every signature M feature. This is where IND steps in. Our job at IND is to continue to raise the bar, every day. Each day that we come to our office we find new ways to push our own definition of excellence, and to drive progress. We do this by creating pieces that BMW may have wished to make, but could not. We do this by creating Portfolio cars that people may want to see, but cannot drive every day themselves. And most importantly, we do this by inspiring our clients to continue their own drive towards excellence- to progress, wherever the road of life takes them.
Modification List:
Acexxon rear reflector delete Honeycomb painted BMW Gloss black
Alpine programming
Autotecknic gelbgrun painted paddles and steering wheel trim
BBS RT88’s in brushed black chrome Michelin Cup 2’s 265/30/19 all around
BBS Custom minum billet center caps + brushed + black chrome
Brembo 380mm front and rear type III Disc + Yellow calipers
3D Design Side skirts
3D Design Diffuser
BMW Motorsport M235R 24 hour fogs + BMW OEM Euro switch + wiring + custom fog mounts by IND
BMW Motorsport MotoGP roll bar
BMW M-performance interior trim kit
BMW Motorsport M235R wing + RKP high rise mounts brushed with black chrome + cartridge limited carbon endplates
BMW blue stitching removed from door panels, armrest, e-brake boot and floor mats
Carbon revolution 19” wheels + Michelin PS4S 275/30/19 + 295/30/19
ESS tuning software
Eisenmann downpipe back exhaust + Carbon tips
Eventuri intake (black carbon)
Fall-line Motorsports F87 M2 Front Mono ball conversion
Fall-line Motorsports F87 M2 Rear upper control bearing kit
Fall-line Motorsports F87 M2 Front and rear sway bars
Fall-line Motorsport F87 M2 Race toe link kit
Fall-line Motorsport F87 M2 rear camber shim kit
Fall-line lower splitter painted gelbgrun
IND M3/M4 Mirror conversion
IND Black chrome cosmetic package (front grilles with black chrome M2 logo + black chrome side grilles + black chrome M2 emblem)
IND full repaint in Porsche Gelbgrun
KW Clubsport 3-Way Adjustable suspension
M4 GTS front seat belts
M4 GTS Euro seats
M4 GTS 6-point harness
M4 GTS fire extinguisher
Macht Schnell 90mm stud kit
Project kics black R40 open end racing lug nuts
RKP corner brace (black)
RKP 1x1 carbon roof
RKP upper carbon front lip
RKP rear closeout
Special thanks to:
3D Design Japan
AlpineMSS
Acexxon
Auto Talent
BMW Motorsport
BBS USA & Germany
Carbon Revolution
Cartridge Limited
Carnucopia / Tuner Theory
Detailers Domain / Nanolex
Eisenmann Exhaust systems
ESS Tuning
Eventuri UK
KW Suspension
Mackin Industries
Michelin
Race Technologies / Brembo
Unscene Media Group
IND DISTRIBUTION | 866-963-4520 • FACEBOOKINSTAGRAMFLICKR
Appreciate 57
      05-26-2017, 12:52 PM   #2
LBBDrew
Drives: 2017 LBB M2
Holy tits. Front Page Please.
      05-26-2017, 01:23 PM   #3
JustChris
General
JustChris's Avatar
Drives: Tesla MYRWD
Oh.
My.
Goodness. I've got a lot to read, great detail thank you. This car is amazing, one of the very best I've seen on Bimmerpost. So many ideas
My car made front page of Bimmerpost
      05-26-2017, 01:28 PM   #4
pissclams
bad ***** poster _
278
Drives: 2011 E93 M3, 2018 F87
Clean up on aisle 2, I just drooled all over the place.
      05-26-2017, 01:59 PM   #5
Aerosoul Bastard
Switzerland
145
2018 BMW X1  [10.00]
2018 BMW M2  [10.00]
I came
      05-26-2017, 02:06 PM   #6
DrKevM5
DrKevM5's Avatar
Drives: G05 X5, F87 M2
W. T. F.
      05-26-2017, 02:07 PM   #7
JEllis
JEllis's Avatar
532
Drives: E36 M3, E92 M3
Well, you guys did it. You out did yourselves again. Over the top in the best way. I love love love love it!
http://www.m3post.com/forums/signaturepics/sigpic14547_7.gif
Instagram: jellismotorwerks
MikeM5263.00
      05-26-2017, 02:11 PM   #8
AGM2
AGM2's Avatar
Drives: M2 LBB 17
F****k Beautiful!!!!!!!
      05-26-2017, 02:17 PM   #9
CHITOWN1series
CHITOWN1series's Avatar
85
Drives: 2018 M2 AW
2018 BMW M2  [0.00]
Need those mirrors in my life
2018 AW M2 - Week 32 build
      05-26-2017, 02:20 PM   #10
joe@ptech
NorCal BMW Specialists
Drives: 17 M2|16 X5M|74 tii
Wow, looks so so good. Can't wait to see it next week at Bimmerfest.
      05-26-2017, 02:27 PM   #11
ORIGIN M.
3161
Drives: ///M
Wow wow wow
Trying to eat lunch over here trying to conduct some business over here ha ha love it fucking love it
      05-26-2017, 02:29 PM   #12
BEM-S4
BEM-S4's Avatar
Wow. Just shared the build with my VIP client rep at corporate.
2022 Macan S
      05-26-2017, 02:35 PM   #13
BSMF87
BSMF87's Avatar
140
Drives: M2 BSM 6SPD
Appreciate 12
      05-26-2017, 02:35 PM   #14
DRTMGRT
DRTMGRT's Avatar
Drives: X3M
  [0.00]
  [0.00]
Bellisima!
///Cardia299.50
      05-26-2017, 02:35 PM   #15
AlexCirci
AlexCirci's Avatar
497
Drives: LBB M2
Stunning! What an amazing build
F87 M2 - LBB - 6MT - Exec Package
insta - @LBB_M2
      05-26-2017, 02:39 PM   #16
MMOTION
MMOTION's Avatar
109
Drives: like you'll never drive again
Another insane build to add to the IND portofolio!
      05-26-2017, 02:39 PM   #17
vpatel867
vpatel867's Avatar
320
Drives: 16 F10, 19 xm40i, 24 x7
  [10.00]
Appreciate 8
      05-26-2017, 02:40 PM   #18
Detailers Domain
Detailers Domain's Avatar
Drives: 20 M2C / 22 X3MC
WOW great job guys!
      05-26-2017, 02:41 PM   #19
F85Matt
F85Matt's Avatar
217
Drives: 2020 X3M / 2018 M3 / 2002 M3
At the M festival, perfect timing!
2016 x5m | IND | Dinan | *GoneNotForgotten*
2002 M3 | ESS S/C w/ Meth | IND 1x1 Cf roof | Homemade Street/Track
2018 M3 | ZCP | 6 speed | IND
2020 X3M Comp | IND | Autoteckic | ?
ice7370.50
      05-26-2017, 02:41 PM   #20
Dandadda
Dandadda's Avatar
Drives: 2014 M5 COMP PACKAGE
wow
2014 COMP PK M5
MSR INTAKES
AMS ALPHA DOWNPIPES W/CATS
JB4 w/BCM
      05-26-2017, 02:42 PM   #21
maddoc
Drives: E36-E82-F87-7P
Lord baby jesus... What were the costs associated with the M mirror retrofit? Would you consider doing it for customers?
This makes me want to the the RKP roof and those mirrors.
AndrewC198910931.00
      05-26-2017, 02:43 PM   #22
twin fed
Doc Brown
twin fed's Avatar
1176
Drives: 2016 MG MT M2
So what does it take to get those mirrors???
