05-17-2017, 04:03 PM | #1 |
this is the way
18148
Rep 8,527
Driving modes (Comfort, Sport, Sport+, MDM & DSC OFF)
Was sick of getting a headache and not fully understanding the original table. Decided to reorganize and make it more intelligible which really helped me understand the different modes better. If you believe something is not accurate please let me know and I’ll correct it. Also attached a .pdf of the table in case anyone would like a copy
31
recycledAlva290.00 pissclams277.50 Aloha Joe393.00 doug_9992542.50 BruceM984.50 McGary911472.00 Fab_R192.00 mike in o.c.96.00 termigni1081.00 njw58.00 geogerf115.50 Wharf Rat186.00 rich8566608.50 ///Cardia299.50 Shinobi_Dave30.00 qnet681.50 CanadianDriver98.50 seis-speed2430.50 Downunder9955.50 Yiruna393.50 akkando5864.50 M2_AL49.50 AndrewC198910931.00 JackyStuntin154.50 atc556.50 ///Driver59.50 Kikuchiyo114.50 gsm2x373.50 ///MPIRE13.00 M2Petrolhead9.50 Smiler1.50 |
05-17-2017, 06:20 PM | #2 |
Rep 1,726
i have a few questions...
in dry and warm weather i usually drive in sport+ by default, MDM is enabled in sport+, correct? if i press and hold dsc, i turn off all nannies, correct? what happens if i just do a quick press of dsc (while in Sport+)? does it go to MDM on, but everything else comfort at specified?
My Trackable Street Car
2016 BMW M4 GTS |
Euromeister50.50 |
05-17-2017, 09:12 PM | #3 |
Rep 13,102
Tag, I added your table to the dedicated thread (with reference to you): http://f87.bimmerpost.com/forums/sho...7#post19089487 ("DSC settings on the M2: what the Manual, Press Kit and Technical Training say").
///M is art ↔ Artemis
Tag18147.50 |
05-17-2017, 09:16 PM | #4 |
Rep 665
Still isn't straight forward.
05-17-2017, 09:38 PM | #5 |
this is the way
18148
Rep 8,527
There are five columns, with the first three being Comfort, Sport and Sport+. So if you look at the Sport+ column you will see from top to bottom how steering, traction, engine speed etc. are affected when in that mode.
The last two columns just show what's affected when you disable DSC partially or fully. |
05-17-2017, 10:19 PM | #6 |
Rep 360
It is if you have played around in iDrive settings and the traction mode buttons for a recent 1/2 Series or the M2.
There are 2 control buttons: - a rocker switch for selecting drive mode (Comfort, Sport, Sport +) - a traction control button DSC which allows you to switch from M Dynamic Mode (MDM) or turn it off fully (press and hold). In MDM or DSC Off mode, pressing the DSC button turns back DSC. In iDrive, you can configure EACH mode (Comfort, Sport, Sport+) so the changes are for "Drivetrain and Chassis" or Drivetrain or Chassis only. This table tells you what is changed for steering, accelerator, traction etc depending on which Drive mode you select (and how choosing Chassis/Drivetrain or both in iDrive) affects them. This in no way negates the use of an M1/M2 button completely - like those found in the "real" M cars like M3/M4 but it sure gives you a bit more options to find the right sweet spot for you. |
05-18-2017, 09:37 AM | #7 |
Rep 642
Thanks, this helps somewhat. The only thing that still confuses me is when you tap the DSC button only and the dash light shows DSC OFF. This isn't really the case as DSC is only fully off when you hold down the button, no?
05-18-2017, 09:46 AM | #8 |
Rep 3,714
Correct, DSC is only fully off if you hold it down. Tap it once and you get that traction mode which has limited intervention still. The sucky thing about that mode is the throttle feels sluggish.
05-18-2017, 11:30 AM | #9 | |
this is the way
18148
Rep 8,527
If you reference the table you'll see the reason it feels sluggish when in MDM is because everything else gets set to Comfort. |
05-18-2017, 12:32 PM | #10 | ||
Rep 214
05-18-2017, 01:48 PM | #11 | |
Rep 326
But from our M2 manuals, MDM is explained: M Dynamic Mode MDM The concept M Dynamic Mode makes it possible to drive on a dry roadway with high longitudinal and transverse acceleration but with limited driving stability. Only in the absolute limit area does the system intervene for stabilization by reducing the engine power and by braking interventions on the wheels. In this driving condition, additional steering corrections may be necessary. You may find it useful to briefly activate MDM under the following special circumstances: - When driving in slush or on uncleared, snow-covered roads. - When freeing vehicle from deep snow or driving off from loose grounds. - When driving with snow chains. So MDM I guess is considered 'Traction' mode really.... |
05-18-2017, 02:18 PM | #12 |
this is the way
18148
Rep 8,527
MDM is basically Dynamic Traction Control (DTC) which is a subset of DSC. So when you disable Dynamic Stability Control you still retain Dynamic Traction Control. This actually allows the wheels to slip more before any nannies intervene. This helps when driving in snow as your wheels tend to slip quite a bit. Otherwise it's hard to drive, because the nannies would intervene every time a slip was detected making it difficult to maintain any momentum.
This is also why Sport+ uses MDM, it allows for more wheel spin without the nannies intervening. I'm sure you've run into this before, if full DSC is on and you go WOT you'll feel the car back off on power and even apply braking, because it senses slipping. Obviously not what you want for sporty driving. |
10
M2Nebula547.50 hshot_rooke122.50 M2Dynamic183.50 akkando5864.50 M2guru383.50 Bosozoku693.50 M2Petrolhead9.50 BarrettDB95.50 ///M TOWN16523.00 |
05-18-2017, 05:03 PM | #14 | |
Rep 6,635
05-18-2017, 10:26 PM | #16 |
Rep 360
05-20-2017, 12:43 AM | #17 |
I INDIC8
612
Rep 1,286
Drives: 2018 LBB M2, 6MT
People should really consider short-pressing the ESC button as a "snow traction" function rather than anything performance-related. That's effectively what the manual calls it as well.
If you're trying to have fun, you want Sport+ mode, which "presses the ESC button for you" but also puts everything else into sport mode. AFAIK, Sport+ is effectively the same as putting everything into Sport and then pressing ESC yourself, except the throttle gets even touchier and the "load reversal damping" (which I suspect might only be applicable to DCT?) is in a harsher mode.
Bosozoku693.50 |
05-20-2017, 12:59 AM | #18 |
Rep 372
The car isn't any slower with the comfort throttle you know. It just means that you have more room for error when driving without "nannies". No nannies and super sensitive throttle response isn't exactly ideal.
05-20-2017, 02:27 AM | #19 |
Rep 292
I’m not stupid (PhD, actually) but I’m a Luddite which is why I always drive my M2 in Sport + with those extra button things pushed to turn off all the “nannies”. I like to do my own rev-matching / and double-clutch when down-shifting and I don’t want a computer doing it for me. That said, I’m doing my first HPDE in a few weeks at Lime Rock and would like to know, (without a bunch of tech talk and acronyms please), which drive mode should I be using for the track and (if OK in Sport + which I’m used to) is it really going to be dangerous to turn off all the “nannies” my first time on track with this car? I have done track time before (40 years ago I had my SCCA competition license and raced a Renault Gordini), just not with this car.
Advice please?
05-20-2017, 04:00 AM | #20 |
I INDIC8
612
Rep 1,286
TBH, I would start in Sport (no +). That way the nannies are still active in case you do something hairbrained. Also keeps the rev-match enabled, so you can focus more on proper braking pressures instead of having to worry about getting the rev-match right yourself.
After half a session or a full session, try again in Sport+. Should let you hang the tail out more. From there, turn DSC fully off if you like to live dangerously. That's just my $0.25 as someone who wouldn't want to crumple a shiny new M2, but do whatever you want.
Bosozoku693.50 M2Petrolhead9.50 |
05-20-2017, 07:19 AM | #21 | |
Rep 292
Thanks again.
05-20-2017, 07:57 AM | #22 |
Rep 682
I found the Drivelogic Mode interesting.
My E46 M3 has a button for this (more levels). I guess it exists in the M2 but not controlled by a button, but by different combinations of the settings described elsewhere in the chart? Thanks OP for this, and for thinking to make a download.
