04-18-2017, 08:20 AM | #1 |
Chuggin' Along
333
Rep 588
Active Autowerke vs. CTS Turbo intercooler
I just bought the AA intercooler, but I'm kind of wondering if the CTS unit is that same damn thing, just cheaper.
Thoughts? https://store.activeautowerke.com/co...55-intercooler http://www.ctsturbo.com/cart/product...-4939-553.html |
04-18-2017, 09:08 AM | #2 |
Rep 2,577
Stepped core design for N55 and N20 application seems to have been industry standard these days. Every one looks identical. Differences are in core efficiency which is finding good balance among cooling, flow and maybe weight.
Lemania 2320
04-18-2017, 10:25 AM | #3 | |
Chuggin' Along
333
Rep 588
And regarding weight, the AA unit is heavy as fawk! **EDIT** Actually, after a quick google search, I see there are a ton of other options that look to be the same exact intercoolers. Of course, I don't know what the build material differences are. What's different is the price. Here's one: https://www.armmotorsports.com/N54-N...p/335-fmic.htm Looking at the video, this one even came in what appears to be the same box and packaging. Last edited by switlikbob; 04-18-2017 at 10:39 AM.. |
04-18-2017, 10:41 AM | #4 | ||
Rep 1,406
Drives: 2020 SO - M2C
Looks like a few branded manufacturers, but who knows.. only thing I care is I'm happy with it. |
04-18-2017, 12:30 PM | #5 |
BMW Newb
582
Rep 903
Where did you get it from? Have you done any other mods?
04-18-2017, 12:43 PM | #6 | |
Chuggin' Along
333
Rep 588
Is it a bar & plate, or tube and fin? I know the bar & plate units are generally much heavier. |
04-18-2017, 03:20 PM | #7 | |||
Rep 1,406
Got it from eBay from yellowspeed last year at the super cheap rate lol I guess he was testing the waters. It's bar and plate I believe when I looked down the inlets. I could be exaggerating about the weight but it wasn't 100lbs or "heavy" by any means but I also havnt felt a light IC either. Either way I enjoy it! |
Ex-MINI582.00 |
04-18-2017, 05:36 PM | #9 | |
24174
Rep 190,750
ER is one of the largest intercoolers on the market with a very high fin density ... It will outperform most FMIC on the market
04-18-2017, 05:38 PM | #10 | |
24174
Rep 190,750
Fin density look to be the same. Once you receive the AA intercooler post you logs so we can see the results
04-19-2017, 11:10 PM | #11 | |
Rep 752
Thanks! |
04-20-2017, 10:15 PM | #12 |
Rep 102
CTS Turbo weighs more than stock shemeld_135 how did your new IC weigh less lol
For the price difference and knowing that Black does not help, I would get CTS Turbo FMIC. I among a bunch grabbed it when it was on sale for $385 shipped with a discount came out total $360 (It was a no brainer for a quality part, and 2-3 days free shipping from Canada). http://f30.bimmerpost.com/forums/sho....php?t=1322795 http://x3.xbimmers.com/forums/showthread.php?t=1355232
15' X5M DG, enzotune
17' M2 *** CTS Turbo FMIC, CTS Turbo DP, CTS Turbo CP, CTS Turbo Intake *** Bootmod3 E30 OTS |
FSociety3812.50 |
04-21-2017, 01:43 AM | #13 |
Rep 2,577
All the aftermarket IC will weigh more than stock regardless of volume and core design.
Simply look at the steel end tank vs stock plastic - aftermarket will not invest plastic injection mold.
Lemania 2320
04-21-2017, 08:42 AM | #15 | |
Rep 3,005
04-21-2017, 01:06 PM | #16 | |
IG @bmwF9xG80
3813
Rep 7,593
Thx m2s63tu for the hookup
60-130mph 6.5s X4M #HCP
04-21-2017, 03:17 PM | #17 | |||
Rep 1,406
I did also say I was exaggerating a bit on weight lol As for black not helping I only picked black bc of the look I don't track so hardcore cooling really isn't something I care about. |
05-04-2017, 05:39 PM | #18 |
Rep 1,835
Drives: 2020 X4M CS
LOL They prove that black does help when stopped as radiation occurs faster with black, so standing still (maybe at a drag strip) maybe itd make a negligable difference...lol..
As for this brand vs that I got a cheap VRSF 7" STEPPED. fits and works great...my IATs lower substantially up top which apparently is a very important factor in BMWS LOGIC on timing advance and boost, as they both are night and day.. ..but if I get hot or really need as much power as possible I can spray my i/c with C02 + WATER/ALCOHOL for 15-20 seconds my i/c goes as low as -40*F (this was in 80*f heat) and the water (alcohol stops it from freezing, although -20 -40*F it'll still freeze) stops it from heating right back up which I found was an issue. Between Water/Meth and a -40*f 7" HD FMIC Im curious to see how much actual whp I get, and how much longer this little turbo can hold 20 COLD psi...Or will it send fuel requirements too high for the HPFP to handle? they say a you get 1% more whp for every 10 degress lower your IAT. Physics says that'll be exaggerated on a car where IATs are a problem... Hitting the dyno this weekend or next (I have a bad 02 sensor)....Im very curious....So I will deff do before/After.... |
05-04-2017, 05:44 PM | #19 |
24174
Rep 190,750
Wagner EVO I Comp weight is 14.5lbs, how much does OEM weigh?
