02-18-2017, 12:35 PM | #1 |
Rep 4,541
Drives: 2015 328d xDrive
Hey all,
I decided my M2 needed an upgrade in the sound department. Honestly, I really liked the way the stock exhaust sounded, but I thought it was a bit too quiet. Like some of you, I can't justify spending thousands of dollars on an aftermarket exhaust system, but I also didn't want to go catless and risk opening up the can of worms that comes with that: smoke coming out the tail pipes, failed emissions tests, bad smells, CEL's, tuning, voided warranty. Trust me, I know all about it. My 335 was catless and modded up the ass and, well...here’s a video of it lol I really didn’t want a repeat of that, especially on a brand new M car. I want my warranty intact and I'm going for a more low key approach this time around. If you want a racecar set up then god bless, but that isn't what I’m trying to accomplish. I want some balance. OEM+ is what I’m shooting for here. This isn’t my track toy. I want it to sound somewhat composed at low cruising speeds but aggressive when I gun it. It should also be noted that I had momentarily considered a muffler delete but ruled it out because of drone. Just something I personally didn’t want. Some of you may not mind it but I do. I also think dropping weight off the rear of the car without doing the same upfront will upset the balance; just not a good option for me. So the question stands, how does one get a louder, better sounding exhaust without the draw backs of going catless, for a reasonable price? Well, after a ton of research and thought, I chose to go with a 200cell sportcat from Fabspeed, and a midpipe (resonator delete) from Dinan. The sportcat was ~$1200 and the midpipe was ~$260. Shoutout to Bobby from Fabspeed Motorsport who hooked me up with the sale and showed me some videos which ultimately helped me throughout my decision making process. I thought you all would appreciate some home made comparison videos to help you decide if this is the route you would like to go, or if you will take a different path. Here's the stock exhaust: Here's the stock system plus the Dinan midpipe: And finally, here's the Fabspeed Sportcat + Dinan midpipe Conclusion: Sound wise? I LOVE IT! It's not overbearing but it sounds real mean like an M car should. Tons of burbles and pops added without losing the great tone of the stock exhaust. No drone. No smoke. No smell. No CEL. No tune required. Also when I’m in 2nd gear at 4000rpm and floor it to 5000 and then let go of the gas, there is a MASSIVE brrrrrrrrrrrt noise as if an A10 warthog just started doing strafing runs behind me, followed by a loud bang/backfire. It’s fucking brutal. But rest assured, you won’t hear this unless the cars under heavy load, so around town it won’t sound obnoxious unless you’re purposely driving like an asshole. Price? Not a bad set up for ~$1460. Yes, a $500 straight pipe would have been 1/3 of the price, but like I said before, I didn't want to deal with the side effects of going catless. I also didn’t want to spend a fortune on the MPE or something similar. I wanted an affordable, headache free solution, and I think I’ve accomplished that while coincidentally making a little horsepower in the process. This leads me to the last part of my review then... Power? Well, my butt dyno tells me there is definitely less turbo lag and more hp/tq. But if you want some numbers, the dyno posted by Fabspeed says you gain 22whp and 33 ft-lbs of torque at 4250 RPM.* *It should be noted that this was with their muffler delete as well, but that's more for noise, the majority of the power comes from the sportcat. The dyno’d car was untuned. The gains were just from the bolt on exhaust pieces. It was otherwise stock. Here is another dyno. This one is from a forum member, not fabspeed themselves. No before comparison, just two runs with a fabspeed cat and mufflerbypass. Once again, no tune. So again, I love this exhaust combo and couldn't be happier. The sound, price, and power increase are all wonderful and the noise the car makes is balanced between stock and what I would consider over the top aggressive. It’s very tasteful in my opinion. Simply put, for me, this set up is a win, win, win. Update 3/14: short in car clip of MDM mode (low speeds with the windows down) Update 3/29: Finally some nice weather. Sport + with the windows down. That backfire tho... Update 4/11: Flyby clip and some revs Last edited by AndrewC1989; 12-23-2020 at 06:19 PM.. |
19
DrKevM52269.00 CommitConfirm474.50 MTHRAR437.50 Fabspeed Motorsport1003.50 swagon13503.50 twin fed1175.50 slick///m26.50 BAN_M2C4176.00 gtaM2390.50 dtmurf480.00 pmilani43.50 cgukevin8.50 Blurbo311197.00 Dabozo624.50 NYC Bimmer259.50 bmxcamel552.50 m2for2225.00 Poochie9103.00 540ixdrive1.50 |
02-18-2017, 12:46 PM | #2 |
Rep 115
Well said! I just got the same setup and I think this is the most cost effective setup for a good sounding exhaust system that also doesn't drone.
4
02-18-2017, 02:00 PM | #3 |
Rep 2,519
Fantastic! That's the setup I'm having installed next week.
AndrewC198910910.50 Fabspeed Motorsport1003.50 |
02-18-2017, 02:10 PM | #4 |
Chuggin' Along
333
Rep 588
Thank you for taking the time to make and post the videos!
I really like the way the resonator delete with Fabspeed DP sound with the stock exhaust. |
02-18-2017, 07:26 PM | #5 |
Rep 556
Sounds pretty awesome for a sub $1500 setup. I was originally thinking of doing the Dinan Exhaust, but I've been eyeing up the sport cat from Fabspeed since they released it. I am definitely pulling the trigger on something early this spring.
Thanks again for the write up and video, it was extremely helpful. |
02-20-2017, 09:36 AM | #6 |
1004
Rep 1,653
andrewc89 Thank you so much for the detailed write up! You really hit the nail on the head of exactly what our Sport Cat is able to provide which is a great bump in power and sound without having to worry about a tune or CEL! You should definitely have a friend do some fly-by videos!
AndrewC198910910.50 |
02-20-2017, 09:37 AM | #7 |
1004
Rep 1,653
Oh and I LOVE, The Office reference too! Such a great show haha!
02-20-2017, 06:10 PM | #8 |
Rep 236
would love to hear some more videos when you get a chance, of in the car and passing by as well. sounds great by the way!
02-21-2017, 11:18 AM | #9 |
1004
Rep 1,653
+1 for some flyby videos!
02-21-2017, 10:13 PM | #10 | |
Rep 4,541
I do have a tripod coming on Thursday however, so i'll get those flyby's done as soon as i can. Cheers. |
Fabspeed Motorsport1003.50 NYC Bimmer259.50 |
02-22-2017, 09:15 AM | #11 | |
1004
Rep 1,653
03-14-2017, 09:51 PM | #12 | |
Rep 4,541
This is MDM mode with the windows down. |
03-15-2017, 08:05 AM | #13 |
Rep 471
Yes is perfect!!!!! sound and $ .. going to setup this with the M performance Exhaust ..any one here with this on the M performance Exhaust ,,, the sound have to be
[IMG][/IMG] Last edited by AGM2; 03-29-2017 at 05:17 PM.. |
03-15-2017, 11:08 AM | #14 |
Doc Brown
1176
Rep 2,174
I love my set up. I even have the same tips, lol
03-15-2017, 11:23 AM | #15 |
1004
Rep 1,653
The cool weather really enhances those pops too! Good luck with the snow as well!
03-29-2017, 12:11 PM | #16 |
Rep 4,541
05-27-2017, 03:53 PM | #18 |
Rep 69
thanks for posting, excellent summary and vids!! I'm going to be putting this set up (with the M performance exhaust) in my mine right away, it will be here in mid July. However I have one question. The parts guy at the dealership I'm buying the car from has cautioned me against the resonator delete. He says the turbo wants back pressure and I'll probably get a drop in performance by adding it. What is your take on this? People seem to say the turbo is more responsive with the resonator delete. Any insight would be helpful, thanks.
05-27-2017, 04:18 PM | #19 | |
Rep 4,541
The M performance exhaust has a midpipe (without a resonator) already built into it. You will be deleting it automatically if you buy it. If bmw is removing the resonator on their performance exhaust i don't see any reason why the dinan resonator delete would be a bad thing. Next, there's no point in getting the dinan resonator delete unless you're keeping your stock muffler or using a dinan one. It would literally be a waste of money. The MPE has a resonator delete/midpipe built into it. You can't use both parts simultaneously. Lastly, I got the dinan res delete before the sport cat so i would have noticed any loss in performance had there been one. I didn't notice any loss in power. Just a gain in exhaust noises and volume. I love it. Also, the power gained from the sport cat is/would be significantly larger than any possible losses from the res delete. It's a non issue. PS. Before you commit to an M performance exhaust (MPE), you might want to know that there are some issues with it regarding vibration during cold starts and drone at highway speeds. So just do your research on the forum before you dive in head first. That being said, a fabspeed sport cat + MPE is an awesome combo if you don't mind the price and those flaws. Last edited by AndrewC1989; 05-27-2017 at 06:55 PM.. |
NYC Bimmer259.50 |
05-27-2017, 05:59 PM | #20 | |
Rep 69
thanks so much for this. I didn't realize the MPE had a mid pipe with no resonators. I missed that and so did all the people at the dealership! Will have to rethink the MPE and weigh the options. It gets shipped from Germany and the MPE gets put on in Halifax before coming out west, so I have some time to make the final call. That said, can't wait to get my hands on the Fabspeed catted DP. |
06-25-2017, 08:06 AM | #21 | |
Rep 3,073
I need to revisit the same dyno again since I ditched the Fabspeed bypass and went with the DINAN Resonator Delete and DINAN Free Flow Exhaust. If you think you love the sound now with the DP and Midpipe only believe me if you added the Exhaust from them it would be a whole new story.. I can't get over my setup.. hopefully it does show perhaps an improvement (perhaps not more power) but making it more quicker on the RPM range. I feel the turbo spools up quicker with less restriction now and accelerates much better. The turbo can be heard much more now.
Follow me on IG
No Boost4021.00 AndrewC198910910.50 |
06-25-2017, 11:20 AM | #22 |
Rep 4,541
Omg i've been waiting for a video of a dinan set up for months now. I really love the way it sounds i just dislike the fact you don't have a choice in exhaust tips, but i'm sure it's something i could get over. I'll be adding the muffler ASAP after hearing that video! Thanks for sharing! |
No Boost4021.00 NYC Bimmer259.50 |
