01-12-2018, 07:36 AM | #1497 |
Rep 91
Here's one for ya: is it possible to code the lane-departure light off when not recognizing any lane?
That small orange light on the left side of the cluster irritates me, looks like a taxi driver's constant flashing check engine light. |
01-12-2018, 08:32 AM | #1498 | |
Rep 2,924
PS: What is an iStep upgrade? Sorry I am not familiar. Thanks.
BMW ///M Club Montreal
BMW ///M Club Montreal Facebook Page |
01-12-2018, 04:49 PM | #1499 | |
Rep 1,718
01-13-2018, 04:13 PM | #1501 |
Rep 4,203
01-13-2018, 04:56 PM | #1503 |
Rep 2,924
Which parameters need to be coded?
01-14-2018, 07:03 AM | #1506 |
Rep 2,924
Thanks! I will try it.
01-15-2018, 11:58 AM | #1507 |
Rep 960
Coded the folding mirrors on unlock and close on lock. Also shutoff radio on driver door open after engine shutdown.
What else is there...that’s useful |
01-15-2018, 12:24 PM | #1508 |
Rep 2,924
Is it easy to put it back ON (in case I do not like ASD off)?
01-15-2018, 12:41 PM | #1509 |
Rep 960
01-15-2018, 12:54 PM | #1510 | |
Rep 2,924
I will try it out once my car is out of storage this spring. Thanks for the info!
01-15-2018, 08:36 PM | #1511 |
Rep 445
So I have an lci instrument cluster and want to code it for use in my vehicle. I have this app is it possible to code the cluster using BimmerCode? Thanks in advance.
01-15-2018, 09:52 PM | #1512 |
Rep 14
Hi, does anyone know how to code so the Air Circulation stays on "M" all the time ? Even when I set the "Air conditioning memory" and "Air circulation setting memory" to active, it still jumps to "A" after a while. Stephan of BimmerCode responded quickly but his suggestion of disabling "AC on with auto" still doesn't do the trick. I've had a professional coder do this on my F10 before but can't seem to figure out how to do this myself on the M2.
thanks in advance. |
01-16-2018, 04:47 PM | #1513 | |
Rep 251
So far I've coded ASD off, folding mirrors, radio off when exiting, and angel eyes at 100%. There were so many other things on the menu. What other neat things have folks coded out there?
BMW M2 2018 LBB
BMW X1 2016 PSM Audi S4 2014 SMG |
01-16-2018, 07:34 PM | #1514 | |
Rep 4,203
Remove seat belt chimes Remove seat belt warning Windows up/down with key (1.5 sec hold) Windows up/down with comfort access (1.5 sec hold) Folding mirrors on lock with key (1.5 sec hold) Folding mirrors on lock with comfort access (1.5 sec hold) Unlock doors when engine off (single pull on door handle, L/R set in I-Drive) Head unit/radio off on car shut down & door opening Disable window up safety feature Force brake flashing Door handle LED on in reverse I-Drive accept off Video in motion via USB in-band ring tone on gong changed to Rolls Royce Disable ASD |
01-16-2018, 08:26 PM | #1515 | |
Rep 4,551
Drives: 2015 328d xDrive
Enable Video Playback Via USB Disable Legal Disclaimers Change BMW Gongs To BMWi Disable Seat Belt Chimes Close Windows & Sunroof w/ Keyfob Fold/Unfold Side Mirrors w/Keyfob & CA Unlock Doors When Car Is Shut Off Radio/Nav Shuts Off When Door Is Opened Angel Eye Brightness At 100% Disable Orange Side Markers Enable Door Handle Lights In Reverse Disable Headlight Washers Fuel Range Warning 2 - Not Active Active Sound Shut Off Brake Force Display Mode - Flashing Brake Force Display Flash - 5 Times/Sec Comfort Closing Delay - No Delay Disable Windows Up Safety Feature LCI Tail Light Retrofit Coding Rear Fogs Enabled Bang & Olufsen Audio Skin Rain/Light Sensor - Sensitive Air Con On w/Auto - Off Air Con Memory - Active Air Circ Memory - Active Variable Light Distribution Last edited by AndrewC1989; 01-25-2018 at 08:06 PM.. |
NYC Bimmer259.50 allenz961.50 |
01-16-2018, 08:35 PM | #1516 | ||
Rep 2,924
01-16-2018, 09:00 PM | #1517 |
Rep 4,551
