M2 Technical Topics > Cosmetic Modifications > How to replace mirror caps
      10-26-2016, 12:39 PM   #1
J.M
J.M's Avatar
Netherlands
263
Drives: '17 M2 DCT BSM
2017 BMW M2  [0.00]
Removed the mirror caps without tools and installed a pair of CF ///M style ones. Looks good to me
Got them from here: http://bit.ly/2fWzgAS
Sounded bad but I was told this method (pulling out the cap sharply) would work and decided to give it a try.
Check out my M2 YouTube channel: The HyperCar Collective
      10-27-2016, 12:30 AM   #2
Glounk
Glounk's Avatar
Qatar
115
Drives: M2 6mt MG
Man, !!! You are courageous.
      10-27-2016, 02:45 AM   #3
J.M
J.M's Avatar
Netherlands
263
2017 BMW M2  [0.00]
Either that or stupid... But incidentally this time I was assured, by I friend who did this more than 100 times (he says), that this would not break the caps.
Anyway, they look good!
Robban267.00
Glounk115.00
      10-27-2016, 10:54 AM   #4
Robban
Agree, looks great
J.M262.50
      10-30-2016, 07:25 AM   #5
J.M
J.M's Avatar
Netherlands
263
2017 BMW M2  [0.00]
After having these installed for a few days, I honestly do not understand how BMW did not include this at least as an aftermarket OEM part. It transforms the car from many angles and makes it look quite a bit better imho.
      11-03-2016, 01:20 PM   #6
quikM2
371
Drives: 2017 Jahre M3
Nice vid man.. still can't believe that works and doesn't break anything! Where do you get those mirror caps from?
BAN_M2C4180.00
      11-04-2016, 03:17 PM   #7
quikM2
371
Where do you get them?
      11-04-2016, 03:46 PM   #8
Pparana
Drives: 2015 m235i
The video is how he got them.
      11-05-2016, 12:44 AM   #9
M2OG
Drives: a car
Can anyone comment on the LED built into the mirror... If one wanted to removed and frost the clear piece is that glued in or fastened another way?
      11-05-2016, 05:04 AM   #10
J.M
J.M's Avatar
Netherlands
263
2017 BMW M2  [0.00]
got them from http://bit.ly/2fWzgAS.
      11-05-2016, 02:38 PM   #11
SeanWRT
SeanWRT's Avatar
3179
Drives: E90 M3 & F87 M2
OP, I got a pair of m performance CF mirror cap but I lost the screws and washers that come with it. Am I still able to install it using old screws from stock mirror cap?
Lemania 2320
      11-06-2016, 03:21 PM   #12
J.M
J.M's Avatar
Netherlands
263
2017 BMW M2  [0.00]
I have no ideia about which screws you mean. My caps didn't bring any screws or washers and you most certainly do not need to remove any when removing the original caps.
      11-08-2016, 06:26 AM   #13
SeanWRT
SeanWRT's Avatar
3179
See the pics. I lost the bag of screw and washers of one of the CF cap...want to know if I can use the old screw from stock cap.
Lemania 2320
      11-08-2016, 08:41 PM   #14
SeanWRT
SeanWRT's Avatar
3179
Sry for losing the pics. See below.
Lemania 2320
      11-08-2016, 09:49 PM   #15
Smiley1175
Smiley1175's Avatar
281
That's different to what mine looked like and the oem ones I took off. They all had clips which clip into the mirror. Much like in this photo you can see the extended bits with triangle shape clips.
      11-09-2016, 01:59 AM   #16
Prodigy.
Prodigy.'s Avatar
698
Drives: ///M2
How come it says F20/F30 on the covers? It appears they may attach differently to the F22/F87 ones.
      11-09-2016, 02:39 AM   #17
J.M
J.M's Avatar
Netherlands
263
2017 BMW M2  [0.00]
Yeah, that's strange... The clips on mine looked exactly like the originals.
      11-09-2016, 03:21 AM   #18
SeanWRT
SeanWRT's Avatar
3179
They are the same part # 51162211904/51162211905, according to BMW OEM.
I bought it from ECStuning.
https://www.ecstuning.com/ES2569799/
Lemania 2320
      11-10-2016, 02:44 AM   #19
J.M
J.M's Avatar
Netherlands
263
2017 BMW M2  [0.00]
Did you solve the problem yet?
      11-10-2016, 10:54 AM   #20
m2tek
Drives: '17 M2
I'm having the same issue. I bought the OEM CF mirror caps, but they don't have clips, instead have screws.
Getting the existing mirror caps off was simple, but does it require removal of the mirror to put on the carbon fiber oem caps in order to screw them in? If so, that is quite unfortunate. They should have just used clips.
      11-10-2016, 11:56 AM   #21
m2tek
Drives: '17 M2
To follow-up to my own post, you do have to pop off the mirror. It is quite easy. Just use a pry tool to get enough of a gap to get your fingers underneath then work your way around.
After you do that, you put the caps on and screw them in with the washers from the inside, then pop the mirror back into place.
      11-10-2016, 11:56 AM   #22
Norcalmav23
Norcalmav23's Avatar
292
Drives: AW DCT M2
Pretty sure this is the process
http://f30.bimmerpost.com/forums/sho...d.php?t=708155
2017 M2 - AW DCT - BM3 93 oct, Pure Stage 2, FBO, happy
2013 BRZ - was a GREAT car... just not fast enough
2008 VW GTI - first experience with boost
97 Integra GSR - crashed it
