08-16-2016, 12:46 PM | #1 |
Rep 568
Drives: 2020 M340i xDrive Sedan
P3Cars Digital OBD Vent Gauge
Simple installation and plugs into the OBD port. All done in 15 min tops. Perfect OEM look.
08-16-2016, 01:15 PM | #2 |
Rep 2,856
Looking good! I choose Awron in the end
MR |
GetAlife75300.00 |
08-16-2016, 09:24 PM | #3 |
Rep 616
Drives: M2, X2 M35i, X6,328i,230i
Garage List 2017 BMW 230i [0.00]
2022 BMW X2 M35i [0.00] 2015 BMW 328i [0.00] 2008 Jeep Commander ... [0.00] 2017 BMW M2 [0.00] 1997 BMW Z3 1.9 Roa ... [0.00] 2014 BMW X6 xDrive35i [0.00] |
Do you still get some air out of that vent?
08-17-2016, 12:46 PM | #4 |
Rep 568
08-23-2016, 01:35 PM | #5 |
Rep 1,835
Drives: 2020 X4M CS
I have the same, Its great for the price...AWRON def kills it though. I may need to upgrade.
2020 BSM X4///M-2016 BSM ///M2- 2011 668 ///M3 |
08-23-2016, 01:41 PM | #6 |
Rep 568
08-23-2016, 02:33 PM | #7 |
Rep 1,835
Drives: 2020 X4M CS
Mine came cracked too and P3 swapped it no problem, so good cust service
GetAlife75300.00 |
11-10-2016, 06:39 PM | #8 |
Rep 13,106
Installed the P3 gauge.
Apart from all the data displayed, it also serves as workaround for the poor readability of the M2 analog instrument dials under some overcast lighting conditions. Now properly showing a digital speedometer in any lighting condition + OBC is now allowed more freedom to show other info than the small digital speedometer (my preference: navigation & Speed Limit Info together). Small question regarding the config menu: according to the P3 car config instructions (BMW section) "Car.7" should be selected as config setting for the M135i/M235i/M3/M4. Anyone experimented with other "Car.#" choices of that particular setting ?
///M is art ↔ Artemis
GetAlife75300.00 |
12-04-2017, 10:05 AM | #9 |
BMW Fanatic
331
Rep 1,076
Will this fit a facelifted M2?
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10 |
12-04-2017, 11:14 AM | #10 |
Rep 1,153
Has anybody run one of these with a piggyback like Dinan? P3 says that you need to tap the MAP sensor on the N55 to get the right readings. Where is it on the M2 and how hard is it to get to, anybody know???
12-04-2017, 01:00 PM | #11 |
BMW Fanatic
331
Rep 1,076
Probably near the passenger footwell area. Check out the AWRON gauge install instructions, you'll probably get a better idea from there.
06-05-2019, 05:18 PM | #12 | |
Rep 39
Thanks for posting the P3 note, I had forgotten all about it. |
06-05-2019, 07:18 PM | #13 |
Rep 780
I find the orange font not that OEM. I called P3 they said that they are coming out with a white readout. They also said they could make me a custom one if I ordered from them.
06-11-2019, 09:17 PM | #14 |
Rep 72
06-12-2019, 11:46 AM | #15 |
Rep 780
I believe so. Give them a call. They are super nice.
06-12-2019, 01:41 PM | #16 |
Rep 2,956
I have to imagine it's simply a matter of purchasing a different color LED display from their supplier. White would be better for an LCI for sure.
01-09-2021, 02:40 PM | #17 |
Rep 1,968
I agree, although I decided to get white for my pre-LCI. I had the all orange P3 in my previous BMW and find the white digits with orange bar graph a nice change.
Biggest problem with P3 is the soft plastic. Too easy to put surface scratches in it when cleaning -- visible when the sun hits the gauge. (Horrible cell pic from flash in a dark garage, looks great in real life). |
01-09-2021, 05:45 PM | #18 |
Rep 403
Hi,
Does it give you both Coolant and Oil temps? Thanks. Karl.
Stock – 997.2 C2S Coupé • Carrara White / Cocoa • Adaptive Sports Seats • PDK w/SC • PSE
Mods – Front 996-GT2 and Rear 997-Turbo Brake Ducts • 3rd (center) Coolant Radiator • 10mm/15mm Spacers |
